NR downtube shifter range
Myrtle Beach Crab
Bikes: enough one would think, but thinking isn't my strong point
Quoted: 271 Post(s)
Liked 541 Times
anyone know what the shifting range for campy downtube NR friction shifters is? i have an 8 speed campy cassette that i'm thinking of using.
Myrtle Beach Crab
Quoted: 271 Post(s)
Liked 541 Times
OK, nobody knows, so i'll rephrase.. can a mid 70's Nuovo record downtube friction shifter cover an 8 speed shifting range? (the large cog is 26t) i'm thinking probably not, but wanted to make sure before i source something else that has a time limit to purchase.
Quoted: 3464 Post(s)
Liked 2,829 Times
Maybe. it will depending on the mechanism almost traverse 180 degrees.
Quoted: 18375 Post(s)
Liked 4,510 Times
Each rear derailleur is a little different.
I've used the Campy DT shifters with a Shimano Ultegra 6500 RD, and 9-speed Shimano cassette.
It shifts fine, but adjustment is a little finicky, and the range of movement is essentially full range tube to tube.
Myrtle Beach Crab
Quoted: 271 Post(s)
Liked 541 Times
i'm planning on using an Athena campy rear derailleur. i think i'll just snag the victory friction shifters off ebay that should work for my application. thanks for everyone's input.
Quoted: 938 Post(s)
Liked 2,939 Times
Just for fun I've managed 10 using a Microshift R10 and as CliffordK says, it took some fine motor skills to trim but it worked.
Quoted: 350 Post(s)
Liked 276 Times
As far as the shifter goes, I would think that the width of the freewheel/cassette from smallest to largest cog would mandate how well it works. For instance, okay on 130mm spacing, better on 126mm spacing, best on 120mm spacing. I would think that the shifter doesn't care if its corncob or mega-range gears. Its the derailleur that must match the range of cogs.
**One thing that I didn't account for is the radius of the cable channel on the shifter. A larger diameter means less pullback; whereas, a smaller diameter means more pullback.
Likes For tyler_fred:
South Carolina Ed
Bikes: Holdsworth custom, Macario Pro, Ciocc San Cristobal, Viner Nemo, Cyfac Le Mythique, Giant TCR, Tommasso Mondial, Cyfac Etoile
Quoted: 344 Post(s)
Liked 291 Times
I believe that Velo-Orange sells Dia Compe downtube shifters that'll work with 11 spd
