Brooks Bar Tape Ends
Retired dabbler
Location: Acton, MA (20 miles west of Boston) - GORGEOUS cycling territory!
Bikes: 2007 Specialized Roubaix Elite Triple - 1st ride = century 9/19/2010 , Ultegra
Quoted: 46 Post(s)
I have always had trouble inserting plugs into the bars after wrapping. But now I need to figure out why. I've watched numerous videos, and everyone just folds the bar tape in and sticks the plug in, sometimes using a mallet.
Yesterday I used some Brooks micro-fiber leather look tape. I really like the look and feel and the plugs (not so much the cotton cloth finishing tape - it looks like it will look dirty quickly).
Also, I want soft bar end plugs because my handlebar ends hit my CF top frame tube at full lock.
Any suggestions are welcome. Thanks for your patience.
- It's fairly thick with a pronounced somewhat thick blue strip covering about 2/3 of the with of the tape and an adhesive strip down the middle of that.
- I found it slow-going - I don't really understand why (bulk? stretch?), but I go it wrapped.
- They fit into my handlebars firmly with no tape. They are snug enough in an empty bar to require a screwdriver to remove.
- On one, I scraped away the blue for the tape extending beyond the end of the bar, but there is no way that tape is going to fit inside the bar and then have the plug inserted.
- I've managed to get one plug in through brute force and a 20 ounce wood mallet, but some of the tape does not get pulled in evenly (there's a bulge)
Quoted: 4558 Post(s)
Liked 2,798 Times
Skiving the ends of the leather wrap would help -- just where it tucks into the bar ends. That'll thin it enough on the inside where it won't show. But be sure to measure accurately. Although at worst skiving the inside of the leather wrap would only make the wraps lay flatter, not a bad thing.
Quoted: 560 Post(s)
Liked 546 Times
Life is good after going exclusively to the bar end plugs with hex heads screws to tighten into your bars, they always fit and not come out until you want them out, and they are reusable. Amazon has dozens of styles.
Quoted: 1018 Post(s)
Liked 1,246 Times
Since I have bar end shifters, I have never put the bar tape into the end, I simply install the bar end, then tape from the end going up. I have never had the end unravel. I am using Brooks leather bar tape.
Quoted: 1438 Post(s)
Liked 1,092 Times
What about carving properly-fitting plugs out of old wine bottle corks? They should blend well with the tape and make a good cushion against your frame.
Likes For dsbrantjr:
When I put on new tape I cut the end to match the angle and use carpet tape to hold it while I wrap the bar. Plug the bars with these: https://www.benscycle.com/Nitto-Bar-...SABEgJI-_D_BwE
Expired Member
Quoted: 3635 Post(s)
Liked 5,311 Times
IMO thicker tape works best w/o the end overlap and tuck. There really is no reason to tuck it, just makes a bulge.
Likes For shelbyfv:
