Re-plating chain ring gears ?
Old 05-20-20, 01:24 PM
Tomm Willians
Bikes: Ridley X-Fire, Colnago C40, Wilier Trieste, Tommaso, Marin Vicenza, Orbea Orca
Quoted: 35 Post(s)
Liked 60 Times in 29 Posts
I have a Colnago C40 with a mix of Record and Chorus groupset from Campy. The plating is coming off the chain ring gears and according to a local Campy dealer they are hard to find. Can they simply be re-plated?
Tomm Willians is offline
Old 05-20-20, 02:03 PM
CliffordK
CliffordK's Avatar
Quoted: 11373 Post(s)
Liked 886 Times in 692 Posts
https://forums.roadbikereview.com/co...gs-147021.html
RBR is suggesting nickel plating, although I'm not sure about the color. I was thinking anodized, but that doesn't look like an anodized surface coming loose.
You could try to remove the entire coating, and either polish or anodize the rings.
Hmm, that bronze color may be tough to find. E-Bay? Unfortunately the E-Bay pictures aren't very clear either.
I did pick up a set of Stronglight black ceramic chainrings a while ago that seem to be working well. In my cases, 53/34, 110bcd.
CliffordK is online now
Old 05-20-20, 02:07 PM
CliffordK
CliffordK's Avatar
Post a photo of your bike.
Here is mine. It looks like I still had the "standard" cranks on it at that time.
Old 05-20-20, 02:42 PM
pdlamb
Quoted: 1181 Post(s)
Liked 252 Times in 180 Posts
I'd think the time and money to find scarce replacement rings would still present a substantial savings over removing the old coatings and getting them professionally re-coated. Unless, of course, you work at a plating shop.
pdlamb is offline
Old 05-20-20, 02:55 PM
shelbyfv
shelbyfv's Avatar
Quoted: 1585 Post(s)
Liked 805 Times in 485 Posts
The spider part looks pretty awful as well. Time for a new crank?
shelbyfv is offline
Old 05-20-20, 02:57 PM
cpach
Bikes: Too many. Cannondale SuperSix, Trek Remedy 8, Trek Crossrip+ get the most ride time.
Quoted: 343 Post(s)
Liked 113 Times in 92 Posts
I agree that you're unlikely to get that job done cheaper than a set of new rings, even though they're hard to source. They can be found, ex. https://www.ebay.com/itm/Campagnolo-...EAAOSwku9ewsr7
cpach is offline
Old 05-20-20, 03:00 PM
dsbrantjr
dsbrantjr's Avatar
Quoted: 1063 Post(s)
Liked 434 Times in 319 Posts
I agree, the old plating would need to be stripped, the rings polished to remove the pitting (if it could be) and the rings plated with (probably) copper as an adhesion layer then nickel, which would need to be buffed out. Since plating is typically charged by the lot, it would be uneconomical to process just two rings.
dsbrantjr is offline
Likes For dsbrantjr:
Old 05-20-20, 03:12 PM
CliffordK
CliffordK's Avatar
That is what Campagnolo Carbon Fiber cranks look like, even brand new.
Likes For CliffordK:
Old 05-20-20, 03:26 PM
HillRider
Bikes: '''96 Litespeed Catalyst, '05 Litespeed Firenze, '06 Litespeed Tuscany, '12 Surly Pacer, All are 3x8,9 or 10. It is hilly around here!
Quoted: 1396 Post(s)
Liked 212 Times in 170 Posts
Buy a set of new replacement chainrings. Not only is the plating peeling off but the underlying aluminum appears to be badly corroded and may be damaged enough to not be trusted.
HillRider is online now
Old 05-20-20, 04:26 PM
bldegle2
Dangerous Old Man
Bikes: 2 custom built full Carbon road bikes, built by Moi...
Quoted: 28 Post(s)
Liked 12 Times in 10 Posts
Ebay, chainring set 53/39 130bcd, lots of hits. You should be able to replace the chainrings, both of them for $50 to $100 total, best solution other than a whole new crankset (maybe a compact), and certainly much cheaper than a plate job. Plus, you get new teeth, yours are probably worn a bit...
bldegle2 is offline
Likes For bldegle2:
Old 05-20-20, 04:42 PM
Tomm Willians
Quoted: 35 Post(s)
Thank you ! The crank in this case is the single Chorus item and I notice that part you posted was for a Record crank. Is there a way to know if they are interchangeable?
Old 05-20-20, 06:09 PM
cpach
Quoted: 343 Post(s)
This stretches the extent my Campy-dorkery, but I'm fairly certain that all the Campy 135 BCD chainrings will fit all Campy 135BCD cranks, these have the same tooth count, are for the same generation and number of speeds, and are in the same cosmetic finish, and when I google Campagnolo EPS C10 rings things come up advertising compatibility with Campy and Record, like NOS Campagnolo Record / Chorus 10 Speed UD EPS Chainring: 53T, 135mm, Silver/Polished - Bike Recyclery .
cpach is offline
