R6800 > R8000 Front Derailleur - Worth the upgrade?
Canadian eh?
Bikes: 2020 Specialized Roubaix Expert
Quoted: 131 Post(s)
Liked 96 Times
I've been reading that the R8000 Front Derailleur offers substantial shifting improvements over the R6800.
Thoughts on upgrading? Any other improvements to be had?
My shifters are R6800 and my chainset is FSA SL-K Light.
SE Wis
Quoted: 2741 Post(s)
Liked 3,388 Times
Likes For dedhed:
Canadian eh?
Quoted: 131 Post(s)
Liked 96 Times
The cable tension setting seems interesting as well, no more specialized tools required. I figure its more reliable then messing with the barrel adjusters.
Expired Member
Quoted: 3657 Post(s)
Liked 5,393 Times
I think it's worth noting Shimano made a pretty big change in the FD when moving from first to second generation 11 speed. Maybe they weren't so happy with first gen? The 8000 did seem to be easier to set up aside from corralling that last bit of cable on the top. FDs are relatively inexpensive so why not give it a try? Update with results is always appreciated
Likes For shelbyfv:
Canadian eh?
Quoted: 131 Post(s)
Liked 96 Times
That was my thought. It's not an expensive investment but was wondering if anyone else did the same.
Quoted: 303 Post(s)
Liked 136 Times
A comment on my experience with the similar R7000 FD. I was really surprised by the increase in shifting effort
needed by the R7000 over the previous 6503 triple it replaced. Since my L hand has arthritic problems in the
thumb C-MC joint this was really apparent, where previously the 6503 shifted easily up the triple,
the R7000 requires maybe twice the effort for an upshift, granted 32->48 is a bigger one the 39->50 but it
is a bit annoying. I queried another cyclist who had an R8000 and he had a similar experience with some
increase in shift effort. For those with normally functioning hands, this may be de nada.
The trim capability is nice in theory but sometimes results in inadvertent downshifts to the 32.
Expired Member
Liked 5,393 Times
I was surprised at the effort needed to shift my 8000.
Canadian eh?
Quoted: 131 Post(s)
Liked 96 Times
Quoted: 131 Post(s)
Liked 21 Times
My r8000 FD is snappy and shifts faster. It is better but only by a small margin. I don't think it's worth it to upgrade alone. 6800 is a still good FD.
Canadian eh?
Quoted: 131 Post(s)
Liked 96 Times
It's also possible one would only get all the benefit fro the 8000 if using the matching shifter.
Expired Member
Liked 5,393 Times
Quoted: 303 Post(s)
Liked 136 Times
Perhaps, but I really studied the Shimano tech lit and took the install down 3x and redid it and had a real bike mechanic check
the work with no change........ The brifters are 7000 series as well.
Likes For sch:
Canadian eh?
Quoted: 131 Post(s)
Liked 96 Times
Overall, sounds like its not worth the upgrade or effort.
Maybe I should just get a Di2 bike
Quoted: 513 Post(s)
Liked 445 Times
The R6800 derailleur has a dual-position pin that is set based on the angle of the cable span between the end of the arm and the the exit point behind the bottom bracket. The wrong position for this pin can result in stiff upshifts or lack of movement for trim. Shimano makes a tool for determining the correct position of this pin, but an experienced mechanic can usually eyeball it.
R8000 replaces this dependency with an esoteric linkage and cable routing on the derailleur. Proper setup requires fastidiously following the rather non-intuitive instructions, plus a couple tricks of the trade. I won't say adjusting R8000 is easier, but it is more consistent. Once properly set up and adjusted, performance of R8000 is marginally smoother. I wouldn't necessarily recommend the upgrade. I've never met a 6800 FD that I couldn't make work perfectly. Before springing for an upgrade that might be equally or more confounding, try bringing it to the most reputable shop in your area and insisting their derailleur whisperer look at it.
Likes For oldbobcat:
Setup procedure is significantly different between both. Both have very good shift performance when set up correctly. The cable tension adjustment on the newer toggle derailleurs is nice because you just do not need any inline cable tension adjustment, but it's not particularly better aside from the cleaner routing. It is not a wortwhile upgrade inofitself.
Likes For cpach:
Well, for what it is worth: my 8000 shifters were working perfectly and were both smooth and easy to shift with minimal effort - front and back. After about a year, after the cables change (done in the bike shop), front shifting suddenly became MUCH harder and LBS mechanics were not able to make it shift as easy as before no matter what - and they've tried lots of things, including replacing cable again. After a few rides with such stiff shifting, the front shifter simply stopped working and was replaced under warranty. Replacement shifts nice and easy again.
