Removing a freehub body from a hub that is not spoked up onto a bike, possible?
Old 11-16-19, 08:42 AM
jambon
Quoted: 77 Post(s)
Hi ,
I picked up a spare of the hub on my bike to use for parts should the need arise. The need has arisen and I now need to get the freehub off the spare and switch it with the one on the bike.
The problem that I did not foresee is that the spare hub is not spoked up onto a wheel as you would expect. It takes an awful lot of force to turn the hex wrench to remove the freehub body but with having no tyre or rim to hold against it feels near impossible.
I don't see any flat part on the hub that I could use to hold the hub in a vise grip. Mount a cassette and use a chain whip maybe ? Any ideas ? Just buy a new freehub ?
jambon is offline
Old 11-16-19, 08:58 AM
ThermionicScott
7-speed cultist
ThermionicScott's Avatar
Quoted: 2605 Post(s)
Liked 493 Times in 356 Posts
You were wise not to try clamping it in a vise to loosen the freehub bolt. Oftentimes, those are on pretty tight.
The best way I know is to get a spare rim and a few spare spokes, and lace up the drive-side flange to said rim. It doesn't have to be a professional job, just so that you can hold onto the rim while turning the hex wrench.
Originally Posted by noglider
RUSA #7498
ThermionicScott is online now
Old 11-16-19, 09:03 AM
DOS
DOS's Avatar
Quoted: 224 Post(s)
Liked 47 Times in 37 Posts
What kind of hub? Different models require different combinations of wrenches to remove but often you can use two wrenches to exert counterforce. I have never had a problem removing a freehub from an unbuilt hub.
DOS is offline
Old 11-16-19, 09:26 AM
dsbrantjr
dsbrantjr's Avatar
Quoted: 850 Post(s)
Liked 181 Times in 148 Posts
You might try using a rubberized strap wrench such as used on chromed plumbing fittings to hold the hub. https://smile.amazon.com/s?k=strap+w...bnav_search_go
dsbrantjr is offline
Old 11-16-19, 09:33 AM
CliffordK
CliffordK's Avatar
Quoted: 10288 Post(s)
Liked 461 Times in 359 Posts
The first question is whether at least a minimal amount of damage is acceptable. Scrapping anything that isn't useful?
I've removed a couple successfully, and was unsuccessful with at least one. I think I basically wrapped the hub with an inner tube, then put it in a vise and removed the hex screw.
CliffordK is offline
Old 11-16-19, 09:59 AM
mackgoo
mackgoo's Avatar
Bikes: 87 Bianchi X4, 96 Bianchi Ti Mega Tube, 06 Alan Carbon Cross X33
Quoted: 119 Post(s)
Liked 13 Times in 11 Posts
Without actually seeing what you're trying to do. How about a chain wrench, no cogs? A strap wrench?
mackgoo is offline
Old 11-16-19, 10:03 AM
dedhed
SE Wis
dedhed's Avatar
Quoted: 908 Post(s)
Liked 253 Times in 193 Posts
+1 on a strap wrench
dedhed is offline
Old 11-16-19, 10:25 AM
cyccommute
Mad bike riding scientist
cyccommute's Avatar
Quoted: 2903 Post(s)
Liked 355 Times in 252 Posts
Get an axle vise. You clamp the threads of the axle in the vise and can work on the rest of the hub. It costs about what a strap wrench would cost and you can use it on wheels as well. It makes working on cones a dream.
Stuart Black
cyccommute is offline
Likes For cyccommute:
Old 11-16-19, 10:29 AM
CliffordK
CliffordK's Avatar
The axle is the first thing to remove when removing a Shimano type freehub.
Old 11-16-19, 10:38 AM
davidad
Quoted: 376 Post(s)
Liked 31 Times in 29 Posts
Exactly how do you get an allen wrench into a hub with an axle installed?
davidad is offline
Old 11-16-19, 11:26 AM
DOS
DOS's Avatar
Quoted: 224 Post(s)
Depends on make of the hub, which we donít know.
DOS is offline
Old 11-16-19, 11:50 AM
rccardr
aka: Dr. Cannondale
rccardr's Avatar
Bikes: Lots. Just...lots.
Quoted: 1164 Post(s)
Liked 130 Times in 94 Posts
Install a cog, or even an entire cassette, use a chain whip to hold the hub down and keep the freehub from rotating, then remove the freehub using your allen wrench. Should work on Shimano freehubs, perhaps not others...
rccardr is online now
Old 11-16-19, 11:52 AM
jambon
Quoted: 77 Post(s)
Thanks for the ideas , Shimano FH-RM30 , ill try get another hex key in the opposite side if I can find one that fits haven't tried that yet
jambon is offline
Old 11-16-19, 12:21 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds.
Quoted: 869 Post(s)
Liked 113 Times in 84 Posts
RM-30 takes a 10mm hex Wrench on the FH side.
Depending on what hub you want to switch to, it may not work. It uses a totally different spline arrangement than the "older" hubs.
Compare yours to an an older with these docs.
File Type: pdf
File Type: pdf
Bill Kapaun is offline
Old 11-16-19, 05:48 PM
Slightspeed
Slightspeed's Avatar
Quoted: 639 Post(s)
Liked 404 Times in 231 Posts
I got a free spare set of large flange Campy hubs with a bike buy, and the spokes were cut on the freewheel side. So far I haven't needed it, but someday it needs to come apart. I was considering a vice with wood protectors, but the old rim and spokes deal is probably smarter, providing I can get the spokes threaded into the drive side.
Slightspeed is offline
Old 11-16-19, 05:55 PM
mpetry912
aged to perfection
mpetry912's Avatar
Quoted: 190 Post(s)
Liked 106 Times in 77 Posts
on those hi flange hubs you can set up something in your vise to pick up the flange holes. No need to re-lace it.
Be sure to do all of the "best shop practice" stuff on the freewheel first - PB Blaster or Aero Kroil, and maybe even a little heat (heat gun)
and then jig the thing in your vice and have at it.
Mark Petry
Bainbridge Island, WA USA
mpetry912 is offline
Old 11-16-19, 06:05 PM
mackgoo
mackgoo's Avatar
Quoted: 119 Post(s)
I don't understand. Why can't you loosen the nuts on each side, loosen the lock nuts screw of the cone nuts, pull out the axle and pull of the hub body?
mackgoo is offline
Old 11-16-19, 06:13 PM
mackgoo
mackgoo's Avatar
Quoted: 119 Post(s)
This is the way.
mackgoo is offline
Old 11-16-19, 06:29 PM
Bill Kapaun
Quoted: 869 Post(s)
You still have to remove the fixing bolt which is the whole point of this thread.
How do you keep the hub secure?
Old 11-16-19, 06:40 PM
mackgoo
mackgoo's Avatar
Quoted: 119 Post(s)
Use the 10 mm allen, loosening works against the pawls.
mackgoo is offline
Old 11-16-19, 07:07 PM
jambon
Quoted: 77 Post(s)
Thanks for the ideas above , just to be clear ; the how to of removing this particular freehub is not the problem. The issue is that the hub is not spoked up to a wheel and so it is very difficult to find a way to hold the hub still while applying the force on the wrench(possibly with an extension bar). There is no recess on the opposite side for a hex wrench to work as a counter force.
jambon is offline
Old 11-16-19, 07:16 PM
DOS
DOS's Avatar
Quoted: 224 Post(s)
Maybe try putting the handle of the hex wrench in a vice then slide the hub on to the wrench and turn the hub with your hands (gloves for better grip) Kind of like opening a pickle jar.
DOS is offline
Old 11-16-19, 08:19 PM
trailflow1
Quoted: 109 Post(s)
Liked 3 Times in 3 Posts
a homemade rubber strap wrench with a inner tube and trouser belt ?
trailflow1 is offline
Old 11-16-19, 08:49 PM
mpetry912
aged to perfection
mpetry912's Avatar
Quoted: 190 Post(s)
I thought about this and I can think of a way that will work.
remove the axle and bearings.
get 2 oak blocks, drill a hole that is the size of the hub center body in the middle of the two pieces so you have a way to clamp the hub into your vice.
you can tape up the hub if you want to prevent scuffing. tighten down to beat HECK.
then take the 10 mm allen (which I think is the tool for the freehub attach nut), put it in the hub.
Get an air powered impact wrench and break the nut loose.
I think you need the peak torque and shock impact to break it loose.
Strap wrench / inner tubes etc probably not going to work.
that's the way I'd do it
Mark Petry
Old 11-16-19, 09:12 PM
Bill Kapaun
Quoted: 869 Post(s)
Mark Petry
Not necessary! IF it's clamped decently, it doesn't take that much force. (China built)
This is all pretty moot, since there are few parts that are interchangeable to this VERY LOW COST hub.
I built a couple wheels using this hub because of price.
They all eat the poorly finished DS cone.
