Schwinn LeTour, Raleigh, or Bianchi?
My son wants "an inexpensive steel racy road bike" to workout on the local bike paths. I found a "never used" Schwinn LeTour, lugged steel road bike in his size on a social media site for $90. Appears to be 1987 (or a little earlier) as it has non-aero brake levers. It appears in very good condition. Is this model good and safe enough for his purposes and is it worth rebuilding with some upgrades? I believe it is made in Japan. I also found a few Raleigh and Bianchi road bikes of about the same age for about $150 to $200. Would they be a better choice to upgrade and rebuild? I want to stay away from sew-up tires/rims. Any other advice? I do my own mechanical work. Thanks for your help. --Leo, Long Beach, Ca.
I think I know nothing.
Quoted: 233 Post(s)
Liked 290 Times
I don't want to express an opinion on any of the bikes mentioned. Not that there is anything wrong with them, rather it depends on the actual and specific riding conditions your son will be using the bike on. We have in my neck of the woods bike trails that cover the gammot of conditions, from smooth level pavement to rock strewn single track mountains..
As far as upgrading bikes. I have two (2) mid-80s steel frame bikes that I have owned since they were new, so long paid for. I decided to start riding again so I repaired one of them (new tires/tubes/chain/seat), complete teardown and upgrade with new brakes and aero levers. The frame is in very good condition and I have 1000s of miles on the bike. Did all of the work myself. But I can draw a direct comparison to the amount of money I put into my classic steel bike with a 10 year old, much nicer "craigs list" bike I purchased for $300
In short in my opinion and personal experience if budget is the thing find something used that exactly meets the needs rather than upgrade. If any of the bikes under consideration are good to go just figure the cost of new tires, chain and brake pads plus a tune up and then get riding. Must have accessories like helmet, gloves, trail tools and general bicycle bric-A-brac along with riding pants and so forth will cost more than probably what you will spend on any of the bikes under consideration.
But on the other hand once you accumulate all of the stuff the cyclist can have a life long pastime that is quite satisfying.
Quoted: 1572 Post(s)
Liked 643 Times
You're asking for advice on 30 year old products that we can't see. I have no facts to work with, only my personal biases.
Forum Moderator
Quoted: 3091 Post(s)
Liked 6,600 Times
Thread moved from General Cycling to Classic & Vintage.
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
Reinforcing the message: hard to say without pictures.
You have to wait til you've posted 10 times before you can post pictures, but you can upload pics to google pics (or other free image hosting sites) and post the URLs here.
You can narrow down the year of mfr by comparing your LeTour with catalog cuts here:
https://bikehistory.org/bikes/letour/
Once you've narrowed it down, check out the more detailed catalog images here:
https://waterfordbikes.com/w/culture/schwinn-catalogs/
The LeTour was started at about 31 lbs, and lost a little weight as the years rolled by. From about 1985 to the last year of mfr (1988) they were 25 lbs. with a Tru Temper chrome-moly double-butted frame (that is, pretty good frames). The wheels, while perfectly rideable, are 27" and not 700c size, so you have a smaller (but still very ample IMHO) selection of tires. I think that the derailleurs and such were Shimano or Sun Tour, with Sugino Cranks and a 6 cog rear. In good shape, any Le Tour should be comfortable to ride. These were never intended for racing, but the later models (1985 and later) and the "Super Le Tour" bikes are probably closer to the "racing type bike".
Undamaged with no rust or corrosion and properly serviced, these bikes are eminently safe. An "unridden" one would not have rust and it's a steel bike after all - should be fine.
A similar (maybe better) Raleigh bike from that era would be a Raleigh Super Course or Grand Prix or Super Grand Prix.
But right now, there are too many degrees of freedom. Post the pics, or a URL of the pics. Good luck.
Quoted: 822 Post(s)
Liked 1,961 Times
Rode 1986 and 1987 Le Tours both new for a few years each. Solid bikes and if in great condition should not be any problem.
With new tech tires/tubes should be a much smoother ride than what I remember. Imagine a newer seat would also help ride quality.
I thought of upgrading one with modern brifters/brakes/drive train but the cost is not worth it compared to just buying a newer steel framed bike with modern components.
Quoted: 4236 Post(s)
Liked 2,949 Times
It really depends on the surface type of the paths, the condition of the parts and what work needs to be done.
Quoted: 637 Post(s)
Liked 1,287 Times
If the Schwinn was made in Japan it was almost certainly built by Panasonic. Depending on year and frame material it could be an excellent bike. There are different levels of Le Tours through the years however. You would need to know the exact year and version, some are a lot better than others.
Likes For Murray Missile:
Señor Member
Quoted: 1491 Post(s)
Liked 1,090 Times
Honestly, your son will be the one who makes the final call, but since you asked for helpful opinions, I'll offer mine.
Even though my personal preference is for Raleigh's, there's absolutely nothing wrong with a 1980's Le Tour, and it will be hard to find one that's in the condition you describe at the price being asked. They are well made and durable, and when maintained and cared for should last a long time (consumables will need to be replaced now and then, but that's the case with any bicycle)..Given what you've described as the intended purpose and usage, I would probably pick the LeTour.
Quoted: 796 Post(s)
Liked 522 Times
First off figure out what fits your son and find a bike in that size- a free bike that doesn't fit is no kind of a deal. Secondly expect for any used bike in that you will need to replace consumables: tires chain, cables bar wrap etc and that can cost $75 to $100 (at least) assuming you do the work yourself -lots of great info out there on how to that, and a project you could do with your son, if a shop does it the costs escalate. I love vintage bikes for many reasons but one is they are simple enough to work on that even I can do the maintenance. If you have a bike co-op in your area that is another option, they sometimes sell refurbished bikes with warranties for about what you would pay for a used bike and the replacement parts YMMV. Good luck and post pics when you find a bike.
Quoted: 1950 Post(s)
Liked 2,012 Times
How tall is your son? Or what length pants does he wear? We can look over CL and select a few to chose from with pros and cons. I see a couple Schwinn Tempos which are "racy".
Quoted: 1591 Post(s)
Liked 1,018 Times
Without additional information, I'd buy a Raleigh or a Bianchi before a Schwinn. But there's personal bias involved. For the intended purpose, they are all suitable brands. Look for the best fit in the best condition.
