A question about front and rear chainring teeth
Old 01-06-20, 08:03 PM
Punchy71
Quoted: 9 Post(s)
I have a question about front chainrings and rear cassette chainrings: What is the range in number of teeth (the count) that is normally available from the highest number of teeth to the fewest that is typically available on both the front and rear chainrings?
Thank you
Punchy71 is offline
Old 01-07-20, 01:19 AM
Retro Grouch
Retro Grouch's Avatar
Quoted: 1572 Post(s)
Liked 643 Times in 364 Posts
That's a moving target. The correct answer to that question keeps changing.
A better question might have to do with what derailleurs and shifters work with the outliers. That's a moving target too.
Retro Grouch is offline
Old 01-07-20, 01:27 AM
bpcyclist
Quoted: 451 Post(s)
Liked 364 Times in 227 Posts
Another pretty good question is, what are you planning on using the bike for?
bpcyclist is offline
Old 01-07-20, 03:11 AM
100bikes
Industry guy
Bikes: To many to name - I ride a custom built steel frame.
Quoted: 115 Post(s)
Liked 80 Times in 48 Posts
From your question, I assume you are trying to re gear a bicycle.
Derailleurs and shifters will be the limiting factor at the extremes and correct chain length will be important as well.
Rule of thumb - the closer the front chainring and rear cogs are to the same number of teeth, the lower the gear and easier to ride.
Less inches of travel per crank rotation.
If the ratio hits 1:1, (32 teeth on front chainring and 32 teeth on rear cog) the rear wheel, whatever diameter, will rotate
one time per crank rotation, traveling a distance forward equal to the circumference of the rear wheel - very easy to ride/climb.
It is possible to get below 1:1 with certain cranks and rear freewheels/cassette combinations.
The converse is equally true - a 52 tooth front ring and 13 tooth rear cog will yield 4 rotations of the rear wheel per crank rotation -
very big gear and difficult to push.
Something a very, very strong rider can push effectively and correctly without hurting themselves!
100bikes is offline
Old 01-07-20, 10:50 AM
subgrade
Bikes: Focus Crater Lake
Quoted: 391 Post(s)
Liked 336 Times in 204 Posts
The frame itself may be a limiting factor on how big a chainring (front) you can fit. A larger than originally intended chainring may touch the chainstay.
subgrade is offline
Old 01-07-20, 02:13 PM
msu2001la
msu2001la's Avatar
Quoted: 1455 Post(s)
Liked 1,477 Times in 867 Posts
Thank you
For a typical on-road bike, a standard 2x crank would have front chainrings with 52T and 39T. A more common "compact double" would run a 50T/34T or even a 46T/36T. 1x single chainring setups usually run around 42T, but can vary widely. The smallest front chaining I've ever seen on a geared bike is 24T. On the rear, you'll find most on-road geared bikes run a range between 11-42T.
Mountain bikes have bigger ranges. I think the SRAM Eagle 1x setup uses a 10-50T rear cassette. You'll see front chainrings in the 28T-38T range on these bikes but you could go bigger or smaller if desired.
BMX bikes run rear cogs as low as 8 or 9T and as big as 16-18T, and front cogs anywhere from 20T - 44T. Bigger gearing is typically used on BMX race bikes, and smaller gearing on street/freestyle bikes.
msu2001la is offline
Old 01-07-20, 02:16 PM
msu2001la
msu2001la's Avatar
Lots of other limiting factors too. Crank size, bolt diameter, number of crank arms, type of setup (geared or single speed? 1x 2x or 3x?), type of shifting, size of rear hub, etc.
Old 01-07-20, 02:49 PM
base2
I am potato.
base2's Avatar
Quoted: 1782 Post(s)
Liked 1,620 Times in 926 Posts
It's a very, very large open question you are seeking an answer for.
What the bikes intended use is means a lot. I am going to answer in broad strokes:
It's hard to go wrong with a 34-50 crankset with an 11-32 cassette for a general purpose road bike with moderate terrain. With practice you should be able to clear mountain passes with out issue.
If your terrain is flatter or you are stronger an 11-28 would work well. More cadence friendly still would be a 12-28 cassette.
If you are super strong or ride exceptionally flat terrain an 11-25 cassette would really let you dial in any cadence you want. Mate that to a 36-52 crankset or 39-53 if you are a professional riding in pancake flat Florida with a strong wind at your back.
Going the other way: It's not uncommon to mate a 34-50 or smaller crankset (or single ring) to an 11‐34 or larger. I think cassettes go up to 50-ish now. If you have super steep climbs or are not strong this may be better. It's terrain & fitness dependent.
I had a 28-44 crankset with an 11-40 cassette. I needed an XTR mountain derailleur and a pull ratio converter from J-Tek to make it work with 11 speed road shifters. The range was from 19 to 109 gear inches...After a year or 2 I decided it was too broad. So I changed it. There just wasn't enough times I needed to carry 75 pounds of camping gear up 20% grades to justify the huge jumps between shifts.
If I were to build another city bike, I've had good experiences with an internal hub like a Nuvinci N380 and also Nexus 7 speed hubs with an 18 tooth cog mated to a 36-52 crankset.
In all cases, I find a range of about 28-32-ish gear inches at the low end to about 90-100 gear inches works for the riding I do in the terrain I tend to ride.
So grab an online gear calculator & see if you can get a feel for what will get you in that range.
If you are getting a mountain bike, anything less than 15 gear inches is beyond utility unless you are exceptionally talented with balance, power delivery, and high traction terrain. I'd call 15 gear inches the lower bound for a mountain bike. But others may disagree.
base2 is online now
Old 01-08-20, 10:13 AM
BlazingPedals
BlazingPedals's Avatar
Quoted: 1511 Post(s)
Liked 733 Times in 454 Posts
Other considerations:
1. Front derailleurs are generally made for either road bikes with larger chainring diameters, or mountain bikes with smaller chainring diameters
2. FDs don't like to shift more than 14-16 teeth difference at a time. So 30/52 combinations are out.
3. Rear derailleurs are rated for total teeth difference they can take up slack for; so a 34/50 in front (16 teeth difference) and an 11-27 in back (16 teeth difference) can produce up to 32 teeth of slack. Generally the longer the arm on the derailleur the more slack it can accommodate.
4. RDs also have a maximum size of cassette they can handle. That is, it may be able to lift the jockey pulley over a 34T gear but not a 40T.
5. Like chainrings, too great a difference between adjacent cassette gears makes it shift poorly. So you're not going to find a 11-50T cassette in a 7-speed.
6. If you're changing derailleurs or shifters, be aware that SRAM ESP isn't compatible with everyone else.
BlazingPedals is offline
Old 01-08-20, 12:11 PM
Caliper
Bikes: Many
Quoted: 385 Post(s)
Liked 58 Times in 43 Posts
Thank you
1) Chainrings are only in the front
2) I've seen chainrings from about 60T down to 22T
3) Cassettes have options from 10T to 50T
4) You can't necessarily use all of these together on the same bike, definitely not with an off the shelf combo.
Caliper is offline
Old 01-09-20, 09:03 AM
Notso_fastLane
Notso_fastLane's Avatar
Quoted: 626 Post(s)
Liked 701 Times in 418 Posts
I can give you an example:
My velomobile has a triple front: 30-42-56. I've got a 26 to replace the small ring that I haven't done yet. I'm also going to bump the big ring up to 61.
The rear cassette is a 9 speed 11-34.
It weighs ~70 lbs in commuting trim (tools, spares, water, change of clothes, full electrical system), so going up hill, my cadence will drop to about 60 rpm, and my speed will only be about 4.5 mph.
On a slight downhill, I spin out around 47 mph at about 115 rpms. I want to increase my cadence a bit for the really steep hills, which is why I'm going to fit the smaller ring. The larger ring will let me pedal to about 55 mph before I spin out, maybe a bit more.
Notso_fastLane is offline
Old 01-09-20, 09:26 AM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 3580 Post(s)
Liked 3,392 Times in 1,927 Posts
If your frame has a fixed (aka "braze-on") front derailleur mount, that will also limit both the high and low range of chainring tooth counts.
As others have noted, the gearing you choose depends largely on the type of riding you intend.
JohnDThompson is offline
Old 01-10-20, 07:58 AM
Wildwood
Veteran, Pacifist
Wildwood's Avatar
Quoted: 3895 Post(s)
Liked 4,821 Times in 2,226 Posts
@Notso_fastLane - Just wondering what drivetrain components would support the gear range you are proposing? 56/11 and 26/34 Road or Mountain bike derailleurs?
Wildwood is offline
Old 01-10-20, 09:24 AM
base2
I am potato.
base2's Avatar
Notso_fastLane Yeah, I too am curious what derailleur setup handles 49 chain wrap in your current state & 58 in your proposed state.
Intermediary chain tensioners somewhere? Why not a Schlumpf, paired with a Nuvinci or Rolhoff?
Curious in Seattle.
base2 is online now
Old 01-10-20, 10:08 AM
DrIsotope
Non omnino gravis
DrIsotope's Avatar
Quoted: 4905 Post(s)
Liked 1,731 Times in 958 Posts
Unless he's changed it out, the Strada Velo comes with SRAM X5 up front and a SRAM GX-11-A1 in the back. I'm guessing the wrap isn't an issue because the GX-11-A1 can handle a 42T cog, and the chain is (guessing here) about 12 feet long.
DrIsotope is offline
Likes For DrIsotope:
Old 01-10-20, 10:21 AM
Notso_fastLane
Quoted: 626 Post(s)
I'd have to look to which exact derailers are installed, but yes, they are stock. Most velos have a mtn bike style setup because we usually want as large a gear ratio as we can get.
And DrIsotope is correct. It's a very long chain (recumbents typically have about 3x the chain length of a DF bike). That probably helps. I've gotten some advice from other velo owners and the 61T up front is about as large as I can go with the stock chain.
I would like to try a Rohloff someday, but those are pretty pricey. I'm more inclined to probably go with a ~80T single up front, and get a Schlumpf Mtn drive.
