Di2 Wire tight across handlebars
Hi! I just got a new bike with Ultegra Di2. There's not much slack at all in the wire that runs from one hood to the other on the handlebars. Sliding a garmin mount under that wire makes the fit pretty tight. Is this anything to worry about (pressure on it/something popping out)?
If I wanted to fit a bike light on the handlebar there's zero room.
Thanks!
Thanks!
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times
I would be worried to some extent if it's so tight you with a Garmin under it, but at the same time, that's an area that shouldn't ever really move either on its own, though if there was an incident and your hoods moved it could pop out, I guess.
Do you have two wires running to an external junction box or is it internal? The two external wires would probably be about 55 bucks. Not sure about the internal. Up to you if it's worth it for the piece of mind. I'd probably leave it myself.
With the garmin mount it is tight but reasonable. I installed a bike light mount over the wire since there's no way to get it under.
Does that type of wiring for Di2 seem normal? I'm going to call the bike shop when it opens to ask. Pictures of my bike online don't seem to have it that way.
On Your Left
Quoted: 3004 Post(s)
Liked 2,434 Times
Quoted: 6974 Post(s)
Liked 10,975 Times
Do not do this.
Mine is set up the same way. Next time the bike is in the shop and is due for new handlebar tape, I will ask them to put in a longer wire -- or, if there is slack under the tape, to let some of it out. (My bike has about 6500 miles on it, but I got a new headlight this year with a burly mount.)
In the meantime, you have options. If putting your light mount over the wire makes you nervous, move it over a bit so that it is over the tape - that will protect the wire.
Likes For Koyote:
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
Thanks for the response! The junction box is in the bar end. The bike shop could not get a hold of the normal handlebars that this bike comes with (Giant TCR) so they used a Zipp aluminum bar. There is a wire running from one hood to the other and goes across the face plate of the stem (tightly).
There are several ways to wire a cockpit, it depends on the parts you have.
Quoted: 3243 Post(s)
Liked 2,091 Times
If the under stem A junction, it's 4 holes, 2 at the stem, 2 at each shifter.
But why ?, just tape the E-Tune wire alongside the brake housings, it's under bar tape the entire time.
This would certainly be a "I'm really bored this winter" project.
On Your Left
Liked 2,434 Times
Easy solution....
Sram eTap
Problem solved
Sram eTap
Problem solved
On Your Left
Liked 2,434 Times
Likes For Chi_Z:
On Your Left
Liked 2,434 Times
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
On Your Left
Liked 2,434 Times
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
On Your Left
Liked 2,434 Times
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
On Your Left
Liked 2,434 Times
I put 12,000 miles on Rival 10 speed with no problem on a Trek Madone 4.6. 6000 miles in Rival CX1 on a Cannondale SuperX. 4500 miles on Red 22 on a Trek Emonda SLR and 26,000 miles on the same Emonda but with Red eTap.
I can count the number of chain drops on 1 hand.
Your sampling is minimal and I suggest it's "user" error. And you have no problem bad mouthing then entire product line. Sounds fair to me.
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
Well...
Oh and two of my friends crashed at IMWisconsin because of the queued shifts issue. I'm sure that's just user error and small sample size, though. As it is for everyone else who has that issue.
On Your Left
Liked 2,434 Times
I had a shifter fall apart in my hand, which is slightly more memorable than a chain drop. The first thing you've said that's right, though, is that I have no problem bad-mouthing the entire product line. If Shimano can't get the new DA out in time for my new bike (either released or available) I'll probably just go Chorus. SRAM can piss up a rope.
Why not just stick with Shimano? The extra gear can't be that much of a difference. So you'll go with Campy which isn't compatible with your other bikes.
Quoted: 608 Post(s)
Liked 352 Times
Well...
Likes For blakcloud:
On Your Left
Liked 2,434 Times
GlennR is this another thread you are going to hijack that has absolutely nothing to do with the OP's question? You will then post ten times trying to prove how right you are, because your experience is what everyone else experiences and if they don't it's their fault. Give it a break, it has nothing to do with the question at hand. Maybe, you should read post #1 again and if you can solve that problem with the wire then add something useful. Your posts are tiresome and add nothing of value.
When someone posts something as a fact with limited proof, I'll will point it out.
Remember, it takes 2.
I'm also waiting for a reply to post #5.
What did the LBS say, after all they built it.
The optimist says "the glass is half full"
The pessimist says "the glass is half empty"
Th engineer says "why is the glass so large?"
Di2 fanatic
Quoted: 53 Post(s)
Liked 66 Times
Ignoring the SRAM / Shimano arguments (just ride your bike, who cares what groupset people use), I'd like to add:
If the wire is only tight across the handlebars then that is fine. I mean.. I wouldn't want to ride around on a bike with a wire dangling quite a bit below the handlebar. If you're going to run a wire across from left to right, you better make sure it's tight and sticks as close to the handlebar as possible.
I would not run a wire across the handlebar myself, but that's up to you / LBS.
That said, there should definitely be excess wire / slack at the shift lever itself, or anywhere it plugs into another component. If there is not, you run the risk of accidentally unplugging wires if a shift lever moves or if you grab the bars (or that dangling wire).
At the levers it should look something like this:
