Dumb question #38
Dumb question #38
Okay gang, someone explain the benefits of 1x over 2x, please.
I figure - 2x means closer ratios between gears and twice as many options.
No front derailleur = less weight, but most of us wouldn't miss those 28 paperclips anyway. 1x means the gear spread from gear to gear is farther apart. You have fewer options.
What am I missing? This isn't a troll thread, I'm sincerely asking. I'm sure I'm missing something in order to understand why this is a "thing", but I don't know what it is.
TIA,
Gary
TIA,
Gary
I am potato.
Quoted: 1798 Post(s)
Liked 1,657 Times
Nope. You've pretty much got it.
2x, in addition to closer ratios, & more of them, also offers a greater total range. With some obvious expensive exceptions. I'm sure they're probably up to 9-56 tooth, $500 wear-item cassettes by now, just to do what 2x & a $50 cassette has always done.
I'm dubious of the derailleur capacity & cage length in such a (wide range 1x) scenario...That's a lot of leverage on the derailleur hanger & asking that long cage to hang down that low to be snagged by a bit of trail hazard is asking for problems, IMO.
3x tends to have even greater range & lower necessary derailleur capacity than either 1x or 2x, but that ship has sailed.
Quoted: 427 Post(s)
Liked 339 Times
It is not that one is better than the other, just that roadies that cross over to gravel are more comfortable with the 2x they grew up with and mountain riders that cross over to gravel like to stay with the 1x they cut their teeth on.
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
Not a dumb question at all, but there have been SOOOO many threads on this subject, I just can't.
Likes For Rolla:
Thread Killer
Quoted: 3195 Post(s)
Liked 1,731 Times
But to the OP, yeah, I think 1x is a rather silly trend. Earlier today, in another thread, I was recalling a bike I had in 1980 which was a 1x2, but the two were up front! What would life be if everything stayed the same, right?!
Likes For chaadster:
Quoted: 576 Post(s)
Liked 1,004 Times
TIA,
Gary
TIA,
Gary
Bikes: Dahon Jetstream p8 (sold), customized Dahon Helios x10, customzed Dahon Smooth Hound x11,customized Dahon Hammerhead 8.0 d7, Planet X Free Ranger (mullet setup 1x11), Planet X Giovanissimi 20 (1x9), Frog 52 (1x9) and Frog 48 1s
Quoted: 275 Post(s)
Liked 244 Times
I have a road biased bike and I set it up as 2x9 (39-53 x 11-25) because on the road, I wanted to keep the same cadence range and swap gear quickly, all nice and smooth.
On the gravel that goes on MTB trails, it is 1x11 (XC setup) because 2x would not work; when I climb a narrow (1.5m wide) rocky hill that keep changing inclines and can go from grippy to slippy, I don't really have to time to go through a closed ratio cassette and a chainring swap...
if the OP needs are road baised, 2x9/2x10 is a good cost effective option
if the OP needs are XC baised, 1x11/1x12 is definitely better
Thread Killer
Liked 1,731 Times
Gravel 1x is a trend born from a fad, not a trend born of necessity.
Quoted: 576 Post(s)
Liked 1,004 Times
Thread Killer
Liked 1,731 Times
It may be better to have more or less closely spaced gear ratios for a particular user in a particular circumstance, but no gearing system is going to be optimized for every possible rider and circumstance. We can either provide more gearing options to cover more possibilities, or narrow the intended use range and gear for a more specific conditions.
That’s the question. Why? Why is 1x “definitely better”? It seems like your main point is that you “don’t have time” to shift a front derailleur??
It’s hard to imagine that’s always true, but I dunno how or where you ride, but it does raise the question why not ride an MTB…or is a drop bar MTB a gravel bike?
It’s all just a matter of definitions and particular user needs (i.e. how and where they want to ride), it’s not at all a matter of 1x or 2x being intrinsically better, something I think we are in agreement on.
For me, as a heavy but strong rider on rolling terrain, I see huge swings in speed constantly, and want to have as finely tuned gearing as possible so I can optimize my output for the competitive, fast group riding I do. It’s mostly on dirt roads, followed by pavement, with only occasional, small sections of track or trail. My fitness, as well as surface conditions, swings seasonally, so in winter and spring I want lower gearing than that which I’ll be using on the same rides in mid-summer. Given my needs and abilities, only 2x gives me the gear range to work whenever I want to.
Every rider needs to make that sort of assessment in order to determine what kind of drivetrain layout is best for them.
Thread Killer
Liked 1,731 Times
I took the OP to be wondering why 1x gravel is, as they phrased it, “a thing,” because gravel bikes don’t have swingarms. I don’t know that the origin story of 1x speaks to that or speaks to the OP’s understanding that 1x presents fewer gearing options or why that should be desireable.
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1106 Post(s)
Liked 2,189 Times
Ok guys. I cleaned up a couple posts on arguing and insulting. Let’s keep this civil. The original question is interesting to many and not everyone here is a 20 year cycling veteran. Thanks.
Quoted: 581 Post(s)
Liked 921 Times
- Lack of a front derailleur frees up a lot of design constraints re. seat tube placement (or if one is included at all), BB spindle length.
- Chainrings designed to encourage the chain to jump back and forth also (surprise!) encourage the chain to jump off or not engage correctly some non-zero percentage of the time.
- weight isn't a big part of the issue - 1X drivetrains usually have absurdly large cassettes compared to multi-ring setups, and 1x is also used often on bikes that are not really sensitive to small weight losses, like fat bikes and DH or Enduro bikes. The lightest road bikes still use 2x drivetrains.
- futzing with two shifters can leave your drivetrain knotted up when trying to make too many changes at once; one shifter that can access all drive ratios sequentially does not have this problem.
Sunshine
Quoted: 11033 Post(s)
Liked 7,579 Times
If you do the math, 1x really isnt lighter than comparable level 2x. It saves a front derailleur, some cables, and some left shifter internals...but it replaces that with a massive cassette. Thru the last few years I have found examples where 1x is a handful of grams lighter(like really a handful), even with 2x, and slightly heavier than 2x.
1x is really good for people who cant conceptualize how gears at two different points work. Just eliminate the front variable and go 1x for simplicity. Shifting jumps are bigger, but I dont think these people care.
1x is really good for MTB and CX because mud isnt trapped as easily in the bottom bracket joint and there is left fiddling to get good gearing when inclines are sudden and steep.
I dont find value in 1x for my gravel bike because it is just a road bike for gravel roads. A slightly easier geared 2x drivetrain is all I need. I like the smaller jumps and use my gravel bike on pavement to get to/from gravel since...its still a road bike.
If I bought a gravel bike that I use exclusively to underbike on singletrack, maybe 1x would be my choice.
Likes For mstateglfr:
Quoted: 275 Post(s)
Liked 244 Times
Ultimately, manufacturers are not idiot and on XC bike, they go 1x. on road, they go 2x although some TT are 1x... @ Tokyo game, I didn't see XC mtb running 2x...
Gravel bikes are filling such a wide gap between XC mtbs and road bikes, it is "normal" that depending where the model is in between XC and Road, its transmission will be biased accordingly.
Quoted: 1463 Post(s)
Liked 1,488 Times
I'm surprised no one has mentioned tire clearance (or maybe I missed it). On some gravel/cx frames, the FD is a factor and 1x provides more clearance than 2x. Also worth noting that 1x setups can use a narrow-wide chainring, which helps with chain retention - particularly when combined with a clutched RD.
I like 1x and use it on both my CX and gravel bikes, which also do double duty as road bikes. I live in a flat area and don't need climbing gears, so I can run fairly narrow range cassettes (11-32 is plenty, I also use 11-34).
For me, it's more that I just don't really need 2x. On my 2x road bikes I almost never used the small ring. The large ring on a compact crankset plus an 11-25 or 11-28 road cassette basically meant I used the big ring for 90% of my riding, so why not ditch the FD and extra chain ring, use an 11-32 or 11-34 instead? The fact that the 1x provides better mud clearance, chain retention and frees up some space on my frame is just added bonus.
Don't get me wrong, if I lived in a mountainous area, I'd definitely want 2x on both road and gravel bikes. For flatland riding though... 1x is great.
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
TIA,
Gary
TIA,
Gary
downsides: More wear and tear on chain/chainring/cassette, bigger jumps between gears, you REALLY need a clutch on that derailleur.
The biggest benefit (thanks MSU) is probably that you can use wider tires. With a road Q factor and 2x, you really can't go beyond 40mm (38mm to be ISO compliant). You can also use a narrow/wide chain ring to help keep that chain on.
But the debated downsides are often trivial. Realistically,
1x is
- just easier mentally for a newbie.
- good for people who ride solo or casual group rides (where cadence/speed isn't critical)
- Good for people who REALLY care about their cadence
- Good for people who do fast group rides (where you can't easily choose your cadence and speed).
just a clarification -2x doesn't have twice as many gears. It roughly has 30-40% more as there is a lot of overlap.
(as noted above, 2x can be lighter - mine is).
Likes For chas58:
OP here - wow, thanks for the great replies so far!
Background: Cycling seriously for 4-1/2 years. I ride about 6k annually on road and 1k+ on dirt roads with a gravel bike. I don't ride MTB or know much about them at all.
I've been shopping for a new gravel bike and have been surprised that so many are 1x. The one I am buying this week ('21 Salsa Warbird) is a 2x (like my Cannondale Synapse road bike) which gives me lower gearing options for steep hills.
I appreciate all the input - I'm learning, every day!
Gary
Gary
Likes For BrazAd:
Thread Killer
Liked 1,731 Times
I don’t think it’s unusual for standard Q factor setups to run +40mm rubber, is it? 3T Exploro for example, can run SRAM AXS 2x with 50mm tires, and even 55mm with the Wide AXS FD and 43//30 Wide crank setup (https://blog.3t.bike/2020/05/14264/g...l-sram-gravel/), albeit the latter with a 5mm sacrifice to wider Q factor. My own T-Lab X3 runs 42mm but can clear up to 45mm.
The other point is that, if tire width is of primary importance, 650b wheels can be run with rubber in the +50mm range on the same drivetrain setups as the above 700c examples.
I think sacrificing gear range for tire width is not necessarily a tradeoff which needs made. Even with regards to Q factor, it seems inconsequential to move from 150mm road spacing to 155mm to accommodate extra FD space when we ride around on 170mm spaced MTBs all day…. Point being, it’s hard to complain about lost aero benefits from wider Q factor when pushing fat, 2.3” rubber down a trail.
Sunshine
Liked 7,579 Times
My current gravel frame uses a 68mm shell and 142mm OLD, but fits a 47mm 700c tire and wheel.
Guest
Liked 3,270 Times
Anything that does away with the front derailleur represents an advancement for mankind, IMO.
The only reason front derailleur exist was to give more gears back when the largest cassette a wheel hub could handle was five cogs. Now that we can run a 11+ cassette the 2x and the 3x really only need exist for hyper specific applications.
The modern 1x provides plenty of gearing for all but a few that are working at extreme ends.
Also, this idea of closer gaps is silly. The gearing is not sequential on a 2x and in order to enjoy these 'close ratios' on a 2x one must noodle around both derailleurs and this is highly inefficient. It often involves skipping the rear cassette three cogs while droping from large to small on the front.
People that talk gear gaps on 1x are myopic. The only thing lost on a 1x is higher end stuff over 110 gear inches.
I like bike
Bikes: Roubaix Comp 2020
Quoted: 267 Post(s)
Liked 283 Times
Trying to keep up
Bikes: Pinarello Prince, Orbea Onix, Ridley Fenix
Quoted: 79 Post(s)
Liked 136 Times
I don't think anyone above is talking about the close ratio you are referring to. The 'close ratio' is even if the front derallieur is not moving. If you only have 11 gears going from 11-42 vs 11-30 you will have closer gears on the latter. Here is a Shimano 11-42: 11-13-15-17-19-21-24-28-32-37-42. Here is an 11-30: 11-12-13-14-15-17-19-21-24-27-30T. Now lets compute the tooth difference in each shift on these. 11-42: 2-2-2-2-2-3-4-4-5-6. OK now for the 11-30: 1-1-1-1-2-2-2-3-3-3. Now comparing the two you can see that on almost half the gears the 11-42 has double the gap on a single-gear shift compared to the 11-30.
In short, I don't think there is one answer for everyone. A lot of people will benefit from and prefer 2x. That's fine! Many of us prefer 1x on gravel and that's fine too. I'll stick with 2x on the road for the time being.
Sunshine
Liked 7,579 Times
I will just add that in the middle 8 or so cogs on my 2x11 gravel bike, the jumps are smaller than if I had a 1x11. Its sequential, unlike your claim, and its very much real.
I run 48/32 with 11-36. That gives a 121.19 - 24.74 gear inch range.
If I were to run 1x, I would need a 42t ring with an 11-46 cassette to get close to the same range as that would be a 106.18 - 25.29 gear inch range.
Below are by current 1170 cassette and a wide range cassette. Between the 2nd and 8th cog, there is a 13 tooth difference on my setup compared to a 19 tooth difference on the 1x setup. Linear progression and tighter jumps for the 2x.
my current cassette- 11,12,13,15,17,19,22,25,28,32,36
an available wide range cassette- 11,13,15,18,21,24,28,32,36,40,46
ETA- When my current cassette finally dies, I will most likely buy an 11-34. The cassette range will be even tighter for sequential shifting.
