Capable chain repair tool? Does one exist that can be carried on the bike?
Old 05-19-19, 11:15 AM
woodcraft
woodcraft's Avatar
Quoted: 1814 Post(s)
Liked 923 Times in 569 Posts
Originally Posted by HillRider
Yeah, I have a couple of those and have them on my daily ride bikes. I used it one time to repair another rider's chain and it worked but it certainly isn't a "shop quality" tool. I haven't seen them for sale in years and wonder if they are still being made.
ooh, want. That would save 10g over my current one.
woodcraft is offline
Old 05-19-19, 12:09 PM
JanMM
rebmeM roineS
JanMM's Avatar
Quoted: 653 Post(s)
Liked 347 Times in 226 Posts
I started carrying a Park CT-5 a few years ago and have used it twice on club rides. Once to help another rider by removing the mangled part of a dropped chain and then joining the non-mangled ends back together. Got my hands dirty but she was able to finish the ride. Second time I let a stranded rider use it to fix his chain. Can't remember his problem but he was able to fix it and finish the ride. Kept my hands clean that time.
JanMM is offline
Old 05-19-19, 12:25 PM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 4201 Post(s)
Liked 3,857 Times in 2,305 Posts
Originally Posted by fietsbob
Modern bushing-less flush rivet head derailleur chains are never lengthened,
only shortened and joined with a quick link.
to effect repairs you bring a section of the same chain and more quick links...
So for pressing out the rivet pin, the chain tool can be simple , though it needs to be reliable..
gave a trusty, but not the lightest one, to a friend , he found a lighter, more aluminum one , brought it instead ..
and somewhere in the southern Argentine Andes foothills he had to find a nail and use a rock ,
when the lighter chain tool broke.......
I take it you have never worked on a tandem or recumbent. Both are well known for their longer the common single up right bikes use. Andy
AndrewRStewart
Andrew R Stewart is offline
Old 05-19-19, 12:27 PM
krecik
Quoted: 137 Post(s)
Liked 86 Times in 54 Posts
krecik is offline
Old 05-19-19, 01:10 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
We deal with them , Andy.. specialist recumbent shops buy 100 foot reels of chain ..
out in the Goondocks we use more quick links and join together the boxed chains for single bikes..
fietsbob is offline
Old 05-19-19, 04:16 PM
HillRider
Quoted: 2026 Post(s)
Liked 1,096 Times in 742 Posts
Probably save more than that. The Chain Pup weighs only 25 grams!
HillRider is offline
Old 05-19-19, 05:06 PM
Sapperc
Bikes: Specialized Roubaix SL4 Comp, Trek 930, Nishiki International
Quoted: 64 Post(s)
Liked 25 Times in 15 Posts
Check out Topeak multi tools. It’s the only thing o use how installing links and repairing chains. It works that well!
Sapperc is offline
Old 05-19-19, 09:14 PM
drlogik
drlogik's Avatar
Bikes: '87-ish Pinarello Montello; '89 Nishiki Ariel; '85 Raleigh Wyoming, '16 Wabi Special, '16 Wabi Classic, '14 Kona Cinder Cone
Quoted: 699 Post(s)
Liked 409 Times in 255 Posts
I use a Top-end Hozan C-371 chain tool in my home shop; however, I keep a Park CT-5 in each of my bike saddle bags. I have rarely had any trouble using this tool.
This tip is a good one and spot on:
But I'll add a tip. Once the chain is positioned in the tool, the pin is screwed onto the chain's rivet and it begins to move slightly. Then back off the tool's pin and restart the screwing in. What this does is let the tool's pin better center on the chain's rivet before plunging into the chain's holes.
Another tip is make sure the pin on the tool is straight to start with and go slowly and carefully until you are sure the pin is being driven out straight. A mistake some folks make is going too fast. Slow and steady is the way to go.
Working in shops years ago I figured that out by myself as do most mechanics. This tip is good for all chain tools btw.
drlogik is offline
Old 05-20-19, 07:31 AM
JanMM
rebmeM roineS
JanMM's Avatar
Quoted: 653 Post(s)
And some recumbent/tandem owners purchase chain by the foot. But joining sections with quick links as needed is fine.
JanMM is offline
Old 05-20-19, 08:58 AM
well biked
well biked's Avatar
Quoted: 140 Post(s)
Liked 162 Times in 89 Posts
Another vote for the Park CT-5 chain tool for carrying in your tool kit. Reasonably small and light, works great, have carried the CT-5 for years on my bikes.
well biked is offline
Old 05-20-19, 09:20 AM
KC8QVO
Bikes: Surly Disk Trucker, 2014 w/Brooks Flyer Special saddle, Tubus racks - Duo front/Logo Evo rear, 2019 Dahon Mariner D8, Both bikes share Ortlieb Packer Plus series panniers, Garmin Edge 1000
Quoted: 405 Post(s)
Liked 115 Times in 99 Posts
Thanks for the info All.
As far as having a durable tool and using it a lot - I have not had any luck with the one I do have, not that I have used it very often, but found it worthless when I did try to use it. So I don't anticipate needing to use it "a lot", but I need something that I can trust will work when I do need to use it. To that point is why I want a durable tool - something nice that will last and be reliable.
The hydraulic press I have is a 20t floor mount. I use it for pressing truck parts - ball joints, bearings, seals, etc. One tool with a bazillion uses. I've fixed chains before with it too - with a bit of finesse, chainsaw chains not bike chains.
KC8QVO is offline
Old 05-20-19, 09:39 AM
KC8QVO
Quoted: 405 Post(s)
What are everyones thoughts on the CT-3.3 and CT-3.2 tools? I'm not sure what the difference is, maybe the anvil?
For what it is worth, the main bike I have is a 2014 Disk Trucker. I am not sure what chain is on it but the new models on their website show KMC x10 chain. The other bike I have is a Dahon Mariner D8 folder. No ideal what the chain is on it, either. I don't think any of the chain pins have the divots in them with the outer edges peened. They are flat pins, but not sure how much of a flange there is on them, if any, after being pressed in? Will that affect tool selection any?
KC8QVO is offline
Old 05-20-19, 09:41 AM
fietsbob
Bikes: 8
https://www.parktool.com/product/min...category=Chain
I had this on my last bike tour.. in my tool bag, in a pannier.. CT-5
fietsbob is offline
Old 05-20-19, 09:43 AM
88Tempo
Quoted: 76 Post(s)
Liked 19 Times in 15 Posts
A long time ago when I used to buy chainsaw chain by the roll I owned a chain tool that looked like a modified pair of vise grips. I've often thought something like that would be nice for bicycle chains. For shop use of course.
88Tempo is offline
Old 05-20-19, 10:39 AM
fietsbob
Bikes: 8
when chains had to be narrower to fit in smaller spaces,, (9+ speeds)
the pin/rivets had to no longer be proud above the side plates..
fietsbob is offline
Old 05-20-19, 11:03 AM
goldensprocket
Quoted: 17 Post(s)
Liked 5 Times in 4 Posts
goldensprocket is offline
Old 05-20-19, 11:13 AM
88Tempo
Quoted: 76 Post(s)
That looks like it would work pretty well. When I went looking for a chain tool I ended up with one like Fietsbob posted. Right now it serves double duty for both work in the garage and getting tossed in a bike bag when I remember it.
88Tempo is offline
Old 05-27-19, 08:38 AM
Last ride 76
1/2 as far in 2x the time
Last ride 76's Avatar
Bikes: Yes, Please.
Quoted: 499 Post(s)
Liked 285 Times in 222 Posts
Originally Posted by Bill Kapaun
The OP wanted a LIGHT WEIGHT TOOL to carry.
Not a heavy chain.
oops...
I guess I should have read the thread more carefully.
Last ride 76 is offline
Old 05-29-19, 06:27 PM
djb
Quoted: 2738 Post(s)
Liked 970 Times in 793 Posts
KC, consider getting a really good quality multi tool, Mine has a chain breaker and its what I use to size chains when I put on new ones, and it works great.
I have a couple of old crappy ones that have busted pins or whatever and cant use them anymore but my Lezyne multi tool chain tool works wonderfully.
I know you are looking into touring, and I highly recommend getting a lezyne or other good quality multitool that has one in it. yes, they are more expensive than cheap multitools, but totally worth it, and small and compact.
https://ride.lezyne.com/collections/multi-tools
I dont recall whtich one I have, but they all appear to have the same chain tool.
and a good multitool is worth it in the long run anyway.
djb is offline
Old 05-29-19, 08:25 PM
Mitkraft
Quoted: 62 Post(s)
Liked 14 Times in 11 Posts
I carry a Topeak Hexus II and it has worked great on a few chains including one that broke my dedicated chain breaker I’d had for a while.
Mitkraft is offline
Old 05-29-19, 10:31 PM
Darth Lefty
Disco Infiltrator
Darth Lefty's Avatar
Quoted: 3126 Post(s)
Liked 2,105 Times in 1,369 Posts
Originally Posted by Last ride 76
oops...
That’s clearly a forgery
Darth Lefty is offline
Old 05-29-19, 10:37 PM
Darth Lefty
Disco Infiltrator
In the world of today with quick links I think it would be pretty good to have a chain tool that’s only designed to push the pin out. The links could be held more securely since there’s only one position and the pin could be a tiny bit larger. Only on a multi tool, let the traditional tools stay versatile
