Go Back  Bike Forums > Bike Forums > Fitting Your Bike
Saddle positioning, shortening stem, help me!
Fitting Your Bike Are you confused about how you should fit a bike to your particular body dimensions? Have you been reading, found the terms Merxx or French Fit, and don’t know what you need? Every style of riding is different- in how you fit the bike to you, and the sizing of the bike itself. It’s more than just measuring your height, reach and inseam. With the help of Bike Fitting, you’ll be able to find the right fit for your frame size, style of riding, and your particular dimensions. Here ya’ go…..the location for everything fit related.
Old 05-16-20, 10:41 PM
  #51
Lemond1985
Sophomore Member
Lemond1985's Avatar
Quoted: 1628 Post(s)
Liked 1,059 Times in 633 Posts
Also, keep in mind that you can play around with increasing and decreasing the amount of knee extension, by varying the amount your ankle flexes. Sometimes if I feel pain start to develop in the front of one knee, I can start letting my heel drop at the bottom of the pedal stroke, which allows the knee to fully extend, reducing the amount of stress to the front of that knee. A lot of times just doing this for a few pedal strokes helps reduce knee pain considerably.
Lemond1985 is offline
Old 05-16-20, 10:52 PM
  #52
SlvrDragon50
Quoted: 45 Post(s)
Liked 13 Times in 9 Posts
Originally Posted by Carbonfiberboy
Yeah. Try these stretches every morning :https://www.bikeforums.net/road-cycl...l#post15372967
My pain is more on the anterior portion rather than the IT band, though sometimes it does go laterally. It's predominantly the patellotibial ligament. I'll check it out though. Doesn't hurt to work on stretching.
SlvrDragon50 is offline
Old 05-16-20, 10:53 PM
  #53
SlvrDragon50
Quoted: 45 Post(s)
I'll keep this in mind. I wouldn't be surprised if this is the culprit since my left foot still doesn't feel comfortable while pedaling. I should probably mess with the cleat angle some more since I feel like there is a slight torque while I pedal whereas my right side is entirely good. I did experiment with dropping my heel on my own over the past few sessions, and I found it to be quite alleviating.
Old 05-16-20, 11:04 PM
  #54
Lemond1985
Sophomore Member
Lemond1985's Avatar
My cleats always go all the way back, and it seems like it's still never far enough. Some brands of shoes allow me to get the cleats slightly further behind the balls of my feet than others, but none really seem completely satisfactory to me.
Old 05-16-20, 11:05 PM
  #55
BengalCat
Bikes: 50/34, 11-40, 11 Speed
Quoted: 142 Post(s)
Liked 73 Times in 52 Posts
The only practical thing that will help you is to get a professional bike fit. It is best to get a person whose full-time profession is that of a bike fitter. Good ones have a well-known reputation.
What you describe is off in so many ways and it is clear that you have not had the opportunity to understand the intricacies of all the factors you mention and how they relate to each other.
BengalCat is offline
Old 05-17-20, 09:41 AM
  #56
Carbonfiberboy
just another gosling
Carbonfiberboy's Avatar
Quoted: 3889 Post(s)
Liked 1,938 Times in 1,383 Posts
https://www.mayoclinic.org/diseases-...s/syc-20376113
As was pointed out by another poster in that thread, those stretches I posted have nothing to do with the IT band, chiefly because one can't stretch an IT band. As this link says, gotta stretch and strengthen. The stretches I pointed out are particularly for the knee tendons. That's why I do them. The best tendon strengthening exercises, as mentioned in the link, are eccentric. They don't say, but studies have shown that slow eccentric work with heavy weights works to repair knee tendons and not much else does. IME fitness beats the heck out of bike fit every day. There's a woman who rode PBP inside the 90 hours on a coaster brake bike with a wire basket with flowers and an upright position. She's a very unusual athlete, but still, there it is, that's the point. You could try slow one-legged drops off a chair, trading legs. That and the stretches should fix it, maybe 2 weeks.
Results matter
Carbonfiberboy is offline
Old 05-20-20, 01:53 PM
  #57
SlvrDragon50
Quoted: 45 Post(s)
Well, I moved my saddle back a bit more, and it seems to have solved the knee issue. No more hot spots on the pelvis either. I think time will tell if the saddle works for me or not, but I think it is the one. I do still feel a little uncomfortable on it, but it's not painful or anything. Plus, I figure if ISM is telling people that it will be uncomfortable even if they're experienced with multiple-hour rides, I imagine it'll be even more uncomfortable for me at first. One thing that I do find interesting is that it seems like my hamstrings are being activated more with this saddle. Usually my quads burn out first. The saddle also really punishes you if your pelvis isn't rotated anteriorly. I still feel a little bit uncomfortable on the width of the handlebars, but I'll give it some more time before I change anything else up. As of now, I'm quite happy with the setup!
Old 05-20-20, 08:23 PM
  #58
Carbonfiberboy
For the hams, it might be more saddle position and height that help them work. That's what I find. Sometimes on long rides, I'll switch muscle groups, pedal with my quads for a while, then with just the hams for a while. Lower load on your quads is good. Did you also lower your saddle as you moved it back?
Results matter
Old 05-20-20, 08:40 PM
  #59
SlvrDragon50
Quoted: 45 Post(s)
I did not lower my saddle since I think my body isn't really changing position. Before I had the saddle between my thighs even though it's supposed to be noseless, so I moved the saddle back without moving my butt back if that makes sense. Though, now that you mentioned it, I may lower the saddle a hair. Previously when I had the saddle lowered so that I could do a full heel pedal, I was getting knee pain so I raised the saddle to correct for that. That was with the improper fore/aft positioning though so I'll give it another shot with a slightly lowered saddle tomorrow.
I'm definitely happy with more of a hamstring workout since when I squat in the gym, I feel that my hamstrings are my big weakness.
Old 05-20-20, 08:43 PM
  #60
Carbonfiberboy
Ancient dictum says, "Pain in front of knee, raise saddle, pain in back of knee, lower saddle."
Results matter
