Between the sizes - road bike
The general advice is that if you are between the sizes and you want more comfortable ride, you should choose the bigger size. However, apart from a higher (more comfortable) stack, the bigger size will come with longer top tube and longer reach that will stretch forward the body with possible issues of the lower back. How can it be fixed in case of “frozen” geometry with integrated handlebar (no replaceable stem)?
Habitual User
Quoted: 4957 Post(s)
Liked 8,098 Times
If you need a shorter reach, the solution is to replace the integrated handlebar with a new integrated handlebar, or bar/stem combo, in the size that is correct for you.
Yes, but those days of ordering bikes with customized components are gone. The producer sells exclusively the configurations on the website and don't want to switch to similar but shorter handlebar, even if they use it for lower size bikes.
Quoted: 1248 Post(s)
Liked 1,323 Times
Habitual User
Liked 8,098 Times
There are still custom-build options out there. However, if you're locked in to that bike from that source, it may be that your only option is to replace those parts yourself (or with the help of your LBS) after you buy the bike. This is also a reason why buying a new bike from a LBS can be a better choice. They will help you with putting the right parts on the bike to fit your specific fit needs.
Likes For Eric F:
Not necessarily locked, but I had to exclude LBS due to their very limited offer (and still very pricey) compared to the offers of the producers over the internet. A few years ago it was easy to customize stem, saddle and cassette on an order for a new bike, free of charge. But now producers don’t allow that anymore and they excessively use integrated handlebars (I’m not a fan of those) even for middle tier carbon bikes. I was trying to stay on the budget – not tossing a new handlebar due to its length.
Habitual User
Liked 8,098 Times
hoppipola
Bikes: fausto coppi
Quoted: 512 Post(s)
Liked 227 Times
Habitual User
Liked 8,098 Times
Longer tubes mean not as stiff (theoretically). My choice between too small or too large would based on the racer-boy mentality where you pick the smaller option because it's lighter, stiffer, and easier to maneuver (theoretically). However, a long carbon seatpost possibly offers more ride compliance than a larger frame. Also, a long seatpost and a long stem tends towards a hot-bike appearance, which I also like.
Likes For Eric F:
Quoted: 4409 Post(s)
Liked 1,566 Times
Bigger sizes are, if anything, going to be stiffer for heavier riders.
Quoted: 1279 Post(s)
Liked 1,393 Times
My take on the whole size thing is that reach is a body proportion thing. And you can't compensate for body proportions. Once you've tapped out bike adjustments, ie. going to a shorter stem will compromise handling, the bike has to fit. If it still doesn't, it's too big and shouldn't be used.
Drop on the other hand is a mobility thing. Typically going a bit lower can be achieved by increasing mobility and/or easing other bike adjustments so dropping the saddle a bit.
Too much drop is also far easier to correct than too much reach by using a riser stem etc. I understand in this case that's not an option.
All in all, if neither size works with the given integrated components, I'd look for something else.
Industry guy
Not sure where this comes from, but the mention of "General advice" being go to a larger frame is innaccurate - IMO.
I am not going out on a limb when I state that:
There is virtually no benefit to a larger frame than needed for a bicycle rider.
A stock bicycle with a frame to large will actually cause the fit to be compromised(stem length, crankarm length, etc)
resulting in potentially difficult handling.
Not to mention a larger frame has more inherent flex.
Since there are no standards for frame geometry, the design philosphy of top tube length
relative to frame size/standover height and frame angles are what the makes various manufacturers
frame offerings unique.
Materials, components and paint are pretty interchangeable.
I know of a Colnago that was painted Bianchi Celeste -with Bianchi decals - to meet the needs of a team rider.
Result - looked like a Bianchi and rode like a Colnago.
Rational - the Colnago "fit" this riders needs better than equivalent Bianchi, equipped exactly the
same and one with similar frame materials.
Keep in mind- the top bar always wins!
rusty
(45+ years selling and fitting bicycles)
rusty
Liked 1,566 Times
Going with a shorter stem isn't going to compromise handling. The difference between two frame sizes is generally one stem size - so a 100mm stem on the larger size and a 110mm stem on the smaller one. That's all.
Larger modern bikes aren't more flexy. I don't know where people get that idea. It isn't really true of old steel bikes, either.
Likes For Kontact:
Habitual User
Liked 8,098 Times
I agree 100% that bike fit is critical. Too big or too small beyond minor height/length/width adjustments is a bad idea.
Tapping out a road bike in terms of stem length for me is somewhere around 80mm. Below that it starts getting sketchy. Personally I prefer 130mm
Likes For elcruxio:
Quoted: 6196 Post(s)
Liked 4,811 Times
On my 2020 Tarmac I was between sizes too. 56cm and 58cm. I went with the smaller size. More sporty handling, more fun.
I changed from the 100mm stem to a 70mm stem. And the first two or three rides were different feeling. But not any different than what I've experienced riding entirely different bikes. You just get use to it. Unless you are the type that doesn't like getting use to things and quickly put everything back like it was.
As for the OP about reach. Well reach to the bars from the saddle does increase, but probably not as much as the stack increases. Especially if one is willing to shorten the stem an overcome the initial difference of feeling they'll have until they get use to it.
For me an off-the-shelf bike is a starting point. I often replace the stem and the handlebars on my road bikes and always replace the cassette. I always replace the pedals and grips and tires on my mountain bikes. With the exception of a custom road bike frame for touring I have bought my bikes from local shops and then had them make the modifications if special tools were required. Bike geometry has changed so much over the years that ther is no "rule of thumb" that can be relied upon.
For my part I do not want to be scrunched up on the frame and want sufficient distance between the seat and the handlebars. That usually means changing out the handlebar stem with a new one. I view this as a good time to upgrade the handlebars and handlebar tape as well. With road bikes I like to add additional material along the top of the handebars before starting with bar tape and this makes this section fatter and provides more surface area for my hands and minimizes hand nerve pinch from long rides.
I took a deeper look on the geometry:
"Reach+" is 18mm longer for bigger size (10 mm probably come from longer handlebar - call it “stem”, although it is integrated).
"Stack+" is 21 mm higher for bigger size.
Are those significant differences for comfort?
And regarding the “inseam” measure: if I press a little more, I am at the lower limit of the bigger size bike. Arm span minus height ratio - which I have just red that it counts - is +2 or 3 cm.
Habitual User
Liked 8,098 Times
Quoted: 581 Post(s)
Liked 921 Times
I have never heard this 'general advice' that bigger is better. It doesn't even make sense because every person has different proportions, flexibility, comfort requirements and expectations. Two people of the same height and body proportions are not necesdsarily a perfect fit on the same bike. I used to do fittings for custom assembled bikes and the fitting was always considered a 'starting point' - we expected and just short of demanded the customer come back after riding to discuss changes to be made to get it closer to 'optimal'. Occasionally this even meant swapping the frame size or going from a drop bar to a flat or riser bar, or other such major alterations, but normally it would be switching a 90 mm stem to a 110mm stem or the like.
My suggestion is to take a tape measure to whatever bike you currently ride and find comfortable and compare to the published geometry specs for whatever bike you are considering.
THere is generally a range of 2 or 3 sizes that a person can fit with a bit of tinkering - the 'ideal' size, one size bigger, and one size smaller. THe difference between two adjacent sizes is generally only a cm or two on any dimension, and this can almost always be compensated for with adjustments or a swap of standard size components. If you have a bike that is comfortable to ride for the distances you want to ride, and the bike you are considering is available in a size that is within a cm or two in most dimensions, then it will almost definitely be workable.
If your you feel your current bike is NOT comfortable enough, try to estimate what adjustment - bar height, reach, saddle fore-aft, crank length, etc -needs to be done to get it closer to what you think would work better, measure that bike and see if an available size of the new bike you want would bring you closer.
Likes For ClydeClydeson:
Liked 4,811 Times
Of course you did use the term Reach+ and Stack+. So maybe you should enlighten us or at least me as to what they say those terms mean.
Reach in geometry charts is measured from the extended vertical centerline off the BB horizontally to the head tube. Stack is from the horizontal extended centerline of the BB to the roughly the top of the head tube.
For me, 18mm longer and 21mm higher are pretty big changes. For a road bike, I might not be able to get the stem as low as I prefer, and might end up with a shorter stem than I prefer, as well. That said, my preferences might not align with yours. Part of the challenge here is that is sounds like you don't know what your fit preferences are, and how/if they might be limited by the frame's dimensions. This is - again - why buying a bike from an LBS has valuable advantages. They can help you figure out which frame size is right. For your online retailer of choice, it's a much bigger gamble if you don't already know what your preferences are.
I should add here that my body proportions are absolutely normal, so normally it should not be a problem to find an "out of the shelf" solution, but I'm still struggling with that.
