[Nexus 7 gear hub] Replace core assembly?
Quoted: 573 Post(s)
Liked 118 Times
[SOLVED] [Nexus 7 gear hub] Replace core assembly?
Hello,
Someone I know rides a bike with an old Shimano Nexus 7 gear hub with a coaster brake, possibly an SG-7C18.
We'd like to remove the coaster brake for a lever-actuated Roller Brake instead. Apparently, this requires replacing the assembly as the two cores are incompatible, ie. you can't install a "lever brake" on a Nexus that used a coaster brake.
To avoid building a new wheel, does someone know if that old hub is compatible with the latest Nexus 7 gear hub for lever brakes (SG-C3001-7R), so that all it'd take is swaping the core assembly and avoid building a new wheel?
Thank you.
Edit: It looks like the hubs are incompatible → build a new wheel with a new hub
"SG-7 series hubs went through several minor design changes, resulting in new model numbers and parts incompatibilities. The newer C3000-series hubs are significantly different from earlier ones, with pawls on the axle rather than the insides of the sun gears. […] Replacement parts availability is a concern, and so you may have to substitute an internal assembly from a different model. The internal mechanism of these hubs is complicated, and the usual repair is to replace it in its entirety. It can usually be replaced with a newer version as long as the hub is of the same basic type (with or without coaster brake) and in the same series."
https://www.sheldonbrown.com/nexus7.shtml
Thank you.
Likes For Dan Burkhart:
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1237 Post(s)
Liked 324 Times
Roller brakes are the stupidest thing ever invented. More drag than the Titanic. LOL.
Quoted: 980 Post(s)
Liked 584 Times
As a rear brake, the roller is adequate, and I've had no issues with drag. And no rim replacements!
Roller brake replacement for V-brake eliminated rear rim wear.
Quoted: 573 Post(s)
Liked 118 Times
Thanks for the infos.
Coaster brakes are very much useful on a handcycle, something I didn't mention.
The goal was actually to add a mid-drive, but it turns out that, unlike Bafang, a Tongsheng is available in a version that's coaster-brake-compatible, so the user won't need to replace the Nexus.
Hello,
Thank you.
Thank you.
Likes For ign1te:
