Replacing headset bearings in 90's Trek 1400
Mad bike riding scientist
Quoted: 6220 Post(s)
Liked 4,221 Times
But that's not the point here, which is to clarify how headsets fail.
Your statements re impact and dimples imply a causal relationship. That would be true IF the dimples were caused by impacts (brinelling). However, the dimples we see in worn headsets are not impact related at all, They're caused by vibration and lubrication failure. The correct term for this is fretting, aka false brinelling, and there's plenty of literature on this subject. (search fretting bearing failure) Headsets fail because there's inadequate movement, so lubrication at the contact points doesn't get replaced and vibration causes abrasion at the dry ball/race interface.
If one is truly focused on headset life, one might bet far and away the most bang for the buck by using any decent quality headset and lubrication with a grease known for it's anti-fretting properties.
This kind of damage almost completely disappeared with the introduction of the threadless headset that didn’t loosen due to vibration of the entire headset/fork system. Denting of headsets on mountain bikes can still occur but it is rare and I would certainly agree that, in that system, it is false brinelling.
Stuart Black
Stuart Black
Liked 4,221 Times
2) It belongs to a teen that rides in a rain forest all winter long and takes occasional side-trips into a river or creek on those rides. 3)he Regularly wheelies and jumps that CX Bike
4) i am his mechanic because he NEEDS a good mechanic...
5) You have Multiple bikes and spread your bulk between them....
and finally 6) Not everyone is you, cycho, although you tend to want to think they should be so.. :-D
PS.. i will not be engaging in your quest to drag meaningless debates out into your typical 30 reply Wastes of time and electrons. Please attempt to find a different victim.
Stuart Black
Stuart Black
Quoted: 4411 Post(s)
Liked 1,566 Times
Having had to replace many headset in mountain bikes during the rigid/threaded headset era, I can tell you that the failure that I am describing is not a lubrication failure nor strictly due to vibration. The failure could happen in a single ride with a new headset. Up to the point where threadless headsets became ubiquitous, headset loosening was a major problem, especially in mountain biking. There was a large cottage industry during that era of making locking mechanisms to keep the threaded headset tight. Unfortunately the locking mechanisms had only limited success. A loose headset in a situation where there is serious stress on the headset that ended with true brinelling where the damage is plastic vs corrosive. Yes, the headset is vibrating but the impacts were causing the brinelling.
Things always seem a bit different in the co-op world.
Liked 4,221 Times
By the way, you can just stop with running down bicycle co-ops. They work on the bikes that you paid mechanics won’t touch. Keeping a broken down bike…piece of junk or just old bike…running is far more difficult than working on the latest and greatest. We co-op mechanics who volunteer our time to work on these wrecks aren’t any lesser mechanics than someone who is paid to do the work. Oft times we are tasked with getting a bike working on a nickel and a prayer…with not a modicum of our own resources…while also teaching people how to keep their wrecks working. Not everyone can afford $75/hour shop rates.
I’ve also taught a lot of people how to be professional mechanics as well as just competent home mechanics through courses that I developed personally. I may not get paid to work on other people’s bikes…and I often pay my own money to get other people’s bikes to working…but that doesn’t mean I’m not a good mechanic just because I volunteer at a co-op.
Finally, just to be clear, I have nothing against bike shops nor bike mechanics. I try and steer people who are looking for bikes and bike parts to those shops. But I also don’t consider every bike mechanic I’ve ever met to be a great mechanic. I’ve met a whole lot of bad mechanics.
Stuart Black
Stuart Black
Liked 1,566 Times
Perhaps you were working on the bikes of the people who were riding their mountain bikes on pavement. My experience with mountain bikes and headset loosening vastly predated my experience in the co-op world. BikePro.com is a “frozen in amber” catalog from the days around the introduction of the threadless headset. They have many examples of headsets with built in locking mechanisms like an American Classic Trilock which says in the copy “…steerer to head thread contact, the bolts, and the mated tapered surfaces all work to hold the headset more rigidly than the common one piece "tighten-against-the-threads" style of locking headset.”. There’s also the Onza Mongo and the Diacomp/Crane Creek Threadhead. You can find other examples like this YST or this Tangle Loose Proof headset lock. The locking mechanisms could be something as simple as essentially a threaded shaft collar or a locknut with a screw. You can even buy a similar product to day from Chop Saw. Granted some of the locking mechanisms that are shown are from a BMX on-line museum but they are very similar to what we used before the wide spread use of threadless headset.
OBVIOUSLY, I was working on all sorts of MTBs during an era of huge interest and a tremendous amount of trail riding. Not only were many of my customers riding off road and jumping their bikes by their own description - I was one of them. So your suggestion is just insulting nonsense.
As with the old Alpine spoke thread, you always seem to misinterpret the marketing of items as proof that they are necessary because standard bike parts are flawed. And just like in that thread, I will remind you that lots of products exist because enough people bungle doing things correctly.
Liked 4,221 Times
Perhaps you were working on the bikes of people who don't know how to work on bikes - and shouldn't.
Unfortunately, this assembly is difficult to adjust with respect to preload on the bearings. Further, the prior art assembly includes a multiplicity of components which renders it unecesarily complicated and heavy. Most types of bicycling, such as mountain biking, racing, and free style biking can cause the lock nut to become loose in a very short time.
Stuart Black
Stuart Black
Liked 1,566 Times
If loosening headset weren’t a problem, why were there so many locking mechanisms? Why was the threadless headset invented? Don’t believe me? Would you believe James Rader, the inventor of the threadless headset? This is from an article on in Cycling Tips on the invention of the threadless headset regarding the threaded headset lock nuts: “…those two nuts were prone to loosening on rough terrain…” It also has ad copy from the Ahead Threadless and Threadset headsets that says “the Threadset system reduces front end hassles by engineering out the unreliable lock rings and nuts found in traditional headsets.” And from US Patent 5095770 which was the patent for the threadless headset
The patent is from 1990 so, obviously, it was a known problem fairly early on.
I’ll remind you that a whole lot of products also exist because the original product just wasn’t up to the demands…even if people don’t screw them up. You do know that inventions are made to address problems, don’t you? Often an invention is necessary because the standard bike part is flawed. Not all of them, but many are a superior replacement for the previous equipment. Spokes with thicker heads are stronger than standard spokes. If the rider has a problem with breaking spokes, they are a very good solution. Threadless headsets are a demonstrated solution to the problem of loosening headsets. Threadless headsets have other advantages in terms of assembly but they are vastly superior to threaded headsets.
Incompetence is not an excuse to re-write history that everyone's headset was loose up until 1994. Just like the guy who insisted that all freewheel axles bent or broke. Or the guy who thinks 2.0 spokes tend to break.
No headset locking device ever became standard equipment for any popular bike brand or popular headset supplier.
I installed a threaded Ritchey headset on my commuting bike two years ago. Steel fork, 23c tires, pot holes and curb jumps - it hasn't moved. Same with my first two MTBs. Locking cones via the threads is a norm on bikes and other industries that works. It just doesn't work when parts are damaged or the mechanic doesn't do their part. Those folks might enjoy an aftermarket accessory.
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1106 Post(s)
Liked 2,180 Times
Hey guys, let’s stop the one on one bickering and get back to helping the OP
Likes For StanSeven:
Quoted: 3514 Post(s)
Liked 2,927 Times
Yeah, gotta say, loose headset nuts were not a serious problem back when I was wrenching. Still isn’t for me. That said, the elegance and simplicity of the Aheadset was revolutionary at the time.
Liked 1,566 Times
Likes For Kontact:
So I disassembled the bearings (they were caged bearings) and cleaned all the parts. The bearings and races all look smooth and feel fine when moving against each other- so I'm thinking I will just re-grease them and re-assemble. However I didn't pay attention to which cage came from the top vs bottom, and both cages are the exact same diameter, using the exact same size balls, but with a different number of balls!!%@$# Either set will fit in either race and move smoothly. Is there a reason to have more balls on one end vs the other? I'm thinking maybe the bottom end potentially gets more force impacted (even though once clamped they are in fixed width spaces) so maybe the higher number of balls goes on the bottom?
Quoted: 5793 Post(s)
Liked 2,585 Times
Yes, all things being equal, you'd want more balls in the lower bearing.
Likes For FBinNY:
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
Likes For maddog34:
