Rain brake blocks
Edo
Rain brake blocks
Hello,
I’m using brake calipers on alloy rims and I currently have some Shimano pads installed (BR-6403) on them, but since I noticed that they become totally ineffective on wet conditions I decided to swap them with something else.
Doing some research I found that Koolstop Dura 2 Dual compound or Swissstop should be pretty good. Any advice on what I should go for? Ideally I need something good for both wet and dry.
Thanks
Thanks
Quoted: 839 Post(s)
Liked 1,064 Times
You'll probably get some different opinions on pad compounds but I have used many pads and find I like the KoolStop "Salmon" compound best. They stop better in the wet than anything else and 95% of my riding is in the dry and also work as well as any others even KoolStop's black compound. Swissstop's always seemed to lose some of their stopping power when the rims got a certain amount of dirt buildup and I had to clean the rims and pads occasionally to keep them working well.
Likes For OldBike876:
Likes For Moe Zhoost:
Edo
Thanks all for you replies.
is there any reason why the Koolstop salmon seem to be out of stock everywhere? Have they been discontinued by any chance?
Quoted: 2026 Post(s)
Liked 1,096 Times
Likes For HillRider:
Expired Member
Quoted: 3674 Post(s)
Liked 5,441 Times
Available at Amazon as well. I'd prefer the Salmon but I've also used the dual compound and couldn't tell any difference.
Likes For shelbyfv:
Edo
Originally Posted by HillRider;[url=tel:22847177
22847177[/url]]Performance's website shows them in stock both as replacement pads and as complete holders with pads.
Edo
But if you’re saying you haven’t noticed any difference I might go for those.
Likes For edo_999:
Quoted: 839 Post(s)
Liked 1,064 Times
Not sure if you're aware but the KoolStop pads will fit in your Shimano holders. Exact fit replacements.
EDIT: I got that wrong. 6403's will need new pad holders for the KoolStops.
Likes For Crankycrank:
Likes For Camilo:
Clark W. Griswold
Quoted: 4359 Post(s)
Liked 4,000 Times
I like both if it has Stop in the name it is a good sign. You will need new brake shoes and for that you want to find really good stiff shoes that have replaceable inserts which you can get from Kool or SwissStop. I also highly reccommend, good compressionless housing and nice polished uncoated stainless steel cables. That combination will greatly improve braking performance for very little money compared to replacing calipers and levers and such.
Specifically for wet weather the SwissStop BXP would be a good way to go in your case these: https://www.swissstop.com/brakepads/...lflashpro/bxp/
and for Kool Stop these: Kool Stop International - High Performance Bicycle Brake Pads Since 1977
Though getting a set of good stiff shoes and the Salmon compound is maybe a better option for pure wet weather road.
Kool Stop is neat because they make all the pads from modern stuff to total long out of production vintage stuff that is hard to find just as the full item let alone pads. SwissStop is certainly the more purely modern option but really great stuff. Also a useful note at least up to 2017 and probably still today the SRAM road rim pads are made by SwissStop so if for some reason those are tough to find SRAM is the same stuff and I used those for quite a while till I finally got SwissStop branded pads.
For cables and housing Jagwire is my go to and generall I try to go for this when possible: https://jagwire.com/products/diy-cab...link-brake-kit (the picture they show is over the older version of my bike and with red instead of blue links) but if I want a more traditional housing I go for this: https://jagwire.com/products/diy-cab...-pro-brake-kit
The kits generally have everything needed to make it work and usually I am left with a little leftover and plus they come in a bunch of colors to help match the bike or add a pop of color. If I am on a deep budget then the Sport kit is an acceptable option but I would rather upgrade because it will make a bigger improvement for less money.
Likes For veganbikes:
Edo
Originally Posted by veganbikes;[url=tel:22847638
22847638[/url]]I like both if it has Stop in the name it is a good sign. You will need new brake shoes and for that you want to find really good stiff shoes that have replaceable inserts which you can get from Kool or SwissStop. I also highly reccommend, good compressionless housing and nice polished uncoated stainless steel cables. That combination will greatly improve braking performance for very little money compared to replacing calipers and levers and such.
The Wheezing Geezer
Bikes: 1976 Fredo Speciale, Jamis Citizen 1, Ellis-Briggs FAVORI, Rivendell Clem Smith Jr.
Quoted: 414 Post(s)
Liked 922 Times
Kool-Stop also makes the Cross Pad for cyclo-cross racers. It has THREE compounds. Can 4, 5, and 6-compound pads be far behind?
They're expensive, but I bought a set anyway, partly because the pads are narrow, and good for sew-up rims. Don't hold your breath for a rain-performance report, though.
I like the Shimano PTFE Road Brake Cable Set - they're pretty smooth and low-friction.
Likes For Fredo76:
Quoted: 839 Post(s)
Liked 1,064 Times
Clark W. Griswold
Liked 4,000 Times
No worries, always happy to help. Down to a certain point the actual calipers matter a lot less but your pads and shoes and of course cables and housing make a world of difference. When you get some really flexible stuff and really cheap stuff then yes upgrade the caliper but that is usually found on wallymart type stuff.
Quoted: 3514 Post(s)
Liked 2,927 Times
Agreed. I use stock Dura Ace shoes with Aican compressionless housing; and while I have both salmon and black Koolstop replacement shoes, I haven’t really felt the need to swap them out (but I also don’t ride in the rain).
Likes For smd4:
