Nexus 8S hub with a Shimano 8S barend shifter?
Bikes: (shortlist) Cyclops, Marinoni, Mariposa, Air Firday, Pocket Rocket Pro, NWT, SLX Fuso, Claude Pottie (France) x3, Masi Team 3v, Lemond Zurich, Bianchi OS
Quoted: 168 Post(s)
Liked 34 Times
I can't stand twist shifters and flat bars so I want to swap my flat bars for drop bars (from a Bike Firday Tikit) and I would like to use a standard Shimano 8S STI indexed bar end shifter.
should this work?
I have the barends installed for a test but so far the hub is not shifting well. I only get about 2 or 3 shifts in the range of 7 clicks.
Now, the cable length might beed to be adjusted (shortened) and I know I have to algin the yellow markers on the hub.
But I have run out of daylight and so will look at all that more closely tomorrow.
peter
should this work?
peter
Senior member
Quoted: 943 Post(s)
Liked 659 Times
should this work?
peter
should this work?
peter
Here is one that will work. Jtek Bar End Shifter for Shimano Nexus and Alfine 8 speed hubs
Really Old Senior Member
A standard 8 speed shifter will not work as overall cable pull and increments are different.
https://www.sjscycles.co.uk/gear-shi...-hubs/?geoc=US
should this work?
peter
should this work?
peter
https://www.microshift.com/products/.../igh-shifters/
Not lost wanderer.
Quoted: 886 Post(s)
Liked 1,000 Times
I have one of those microshift shifters on my market bike, gugie set it up with a brazed-on stud on the top tube.
Cambodia bikes, Bridgestone SRAM 2 speed, 2012 Fuji Stratos...
SB-N080 will work with Nexus and Alfine. The overall cable pulls between the two are the same, but the shift paddle actions will be opposite. In short, SB-N080 will work with Nexus. Thank you for reaching out!
Hope this helps, and best of luck.
Senior member
Quoted: 943 Post(s)
Liked 659 Times
I bought some cones from this vendor about 10 years ago and their shipping & prices were excellent.
From my correspondence with Microshift, iirc, shifters marked Nexus or Nexus/Alfine will work correctly with Alfine SG-S500 & SG-S501. Those marked Alfine will work correctly with Alfine hubs later than SG-S501.
Correctly: 1 is 1 and 8 is 8.
With a different generation of Alfine: 1 is 8 and 8 is 1
