Yet another cross-chaining thread
Quoted: 4409 Post(s)
Liked 1,566 Times
Exactly. It's good though to read about the actual reasons for people to cross-chain. Reading about 1x cross-chaining was entertaining too.
Exactly. I ride my bikes for more than 10 years and has covered less than 10K miles on each of them. Chains and the drive-set (I use the park tool to measure the wear) are still in good condition despite of the cross-chaining.
I service my bikes regularly by myself, however I've heard stories from my colleagues with similar mileage about their mechanics replacing their chains every year as an extra to the service. The wear and abuse is always the quoted reason. Different cycling styles? Bad parts? Questionable ethics? All of the above? Don't really care, these are not my bikes.
Likes For Kontact:
Quoted: 3513 Post(s)
Liked 2,927 Times
Are you really this desperate to find support for your poor shifting practices? Do you not see the utter silliness and futility in using the hardest gear/easiest gear combinations?
Likes For smd4:
Quoted: 142 Post(s)
Liked 34 Times
Less than, no idea how much less. Could be 8K, could be 6K. Point is, with my usage it's still good after 10 years. Doesn't seem to be odd, I grew up in the environment where people were riding old bikes for decades without any servicing or lubing. I service my bikes regularly, so 10 years is fine, right?
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1948 Post(s)
Liked 1,471 Times
I cross-chain with all of my three bikes (2x and 3x) all the time. No rubbing, no chain dropping, no other issues.
According to Bikeradar:
https://www.bikeradar.com/advice/wor...ross-chaining/
- Big-big combo is fine, but I lose a few Watts in low-low combo.
- And yeah, cross chaining in 1x is a thing to discuss
Quoted: 1109 Post(s)
Liked 1,200 Times
I'm probably lucky in that my shifting habits were burned into neuro-muscle memory in the 70s when cross chaining was very noisy and would visibly scar the FD because of rubbing. I'm slowly overcoming some of this as I cross chain more than those days, but still just avoid the extremes on either ring of a 2X because why wouldn't you (avoid extreme cross chaining). One of the reasons I quit using "sequential mode" (front automatically changes based on the rear position... controls simply shift up or down the rear and front follows as needed) on my AXS 2X bike is because I think that it doesn't automatically switch chain rings soon enough and goes to a cross chain I don't prefer, it should change one sprocket sooner, imo, when downshifting to the larger sprockets.
But I - and I'm sure many of you - know riders who have no idea what cross chaining is or means, absolutely no idea that one shouldn't use the extreme cross chain gears. They've never been told, or didn't pay attention. They have no idea and think the bike should just shift like a car, no thought other than just shift it. Actually, when electronic shifting takes over the world, I'll bet that "sequential" mode becomes the default for 2x systems, as will 1X systems.
Quoted: 222 Post(s)
Liked 304 Times
I cross chain occasionally. Mostly big-big, but I would estimate it is less than a minute out of a multi-hour long ride, when I do do it. Mostly just staying in the big ring until I crest a hill. I'd wager that trying to shift to the small ring for a few moments is more wear than just staying in big-big a few moments. I'll rarely go small-small becasue that only happens if I forget to shift the front. So, this occurs even less often.
While there's no question there is more wear the greater the chain angle, I don't think there is any reason to believe that cross chaining is causing extremely higher rates of wear than not cross chaining. And I think plenty of reason to believe it isn't.
Below is a chart from this article ( https://www.cyclingabout.com/drivetr...between-1x-2x/ ). In this case, big-big watts lost is about 10 W compared to the most efficient gearing being about 9 W. So, big-big in this case is causing about a 10% increase in losses. To some degree losses are going to relate to wear. So, perhaps it is correct to assume that there might be 10% more wear in the big-big combination. It's also worth noting that the big-big losses are lower than being in 9th, 10th, and 11th gears.
Looking at small-small, this is certainly much less efficient at a loss of 15 W. If we assume the losses correlate to wear, we could conclude that we get about 2X the rate of wear in small-small compared to the most efficient position.
The big assumption here is that efficiency and wear are more or less linearly related. It's certainly possible, that in the most efficient position, there is very littler wear, and the losses are just going to heating but not causing wear. While, even the 1 W additional loss in big-big is all going to wear and could represent an extremely large increase in wear. But, I think it is more likely that wear and loses are closely related.
In the end, I avoid cross chaining as a general rule, but I don't avoid it as if I'm using up huge amounts of the life of my drive train. All I know, is I have about 10,000 miles on my chain rings, and probably 5,000 on the current cassette and chain, with no noticeable wear on any of them. Tire wear is a much bigger issue for me than drive train components.
Likes For Mtracer:
Liked 1,566 Times
Likes For Kontact:
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,995 Times
I am doubtful of the everything being ok. What I was referencing is customers who come in with worn out drivetrains after a long time without service and wonder why things are worn out and why they should have to replace so much. Chains and cassettes are short wear items, things like pulley wheels and chainrings are long wear items. The more often you replace your short wear items the longer time you get out of everything else. However generally at some point you will probably replace all of it after a given time of having the bike and riding it.
I get it people are cheap and that is fine but it is cheaper to replace a chain and cassette than it is to replace your entire drivetrain. Maybe you are keeping everything really clean often and keeping things nicely lubricated but even still chains wear out and the cassettes wear with them especially in longer periods so while you may think things are OK it might just be well over worn but you are so used to the poor performance it no longer bothers you. I have seen it enough where we replace all the worn out items and people think wow it is a new bike, I didn't know it actually did this when it probably did it a long time ago before they wore everything out a few times over.
If you really don't want to replace stuff then get a enviolo hub and a gates carbon belt drive (CDX ideally) and almost zero maintenance and will last a really long time. You will need to replaces cables and housing (it requires two cables) but you (general) would normally do that on a regular derailleur bike.
If you take care of your bikes they will take care of you, if you neglect them and just let things wear out further and further maybe because a piece of metal told you so those bikes could fail at a bad moment.
Quoted: 142 Post(s)
Liked 34 Times
Some of the responses here are constructive and provide extra info/references, here is a good example. It provides more research data on the inefficiencies of the cross-chaining.
https://www.bikeforums.net/22850088-post33.html
So I've learned here something that I haven't heard before. Potentially some others will find it interesting too.
