bike rack
Old 09-18-09, 03:33 PM
silvermace
bike rack
I was looking online for an attachable rear bike rack when i found this one:
Axiom Journey, 150lbs, 550g, Black
I saw this one especially amazing because the carrying capacity is 150lbs! All others range from about 25-90lbs, not enough for a human being.
What i was wondering is if any of you know if the Axiom Journey could really support 150lbs, and if there is a better rear bike rack that can hold as much or more. Preferably enough for a teenager so 130-180? something like that
silvermace is offline
Old 09-18-09, 03:57 PM
norwood
GO BIG RED
norwood's Avatar
Bikes: 1996 Bianchi Veloce 1993 Bridgestone MB-3 1992 Trek 700 1992 Trek 820
I don't know if this rack will really carry 150lbs. or not, but I would say carrying an adult human (not a child in a childseat) on a bike rack would be a bad idea. They're not designed for that. I would not carry 150lbs. of anything on a bike rack, even if it would hold it.
norwood is offline
Old 09-18-09, 03:58 PM
operator
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 26 Times in 19 Posts
You're thinking of carrying a body on a bike rack? Wtf?
operator is offline
Old 09-18-09, 04:01 PM
10 Wheels
Galveston County Texas
10 Wheels's Avatar
Bikes: 02 GTO, 2011 Magnum
Quoted: 1350 Post(s)
Liked 1,246 Times in 624 Posts
a teenager
10 Wheels is offline
Old 09-18-09, 04:02 PM
Al Criner
Bikes: 2009 Surly Cross Check Frankenbike
Are you comfortable with the idea of putting a 150 lb person on a rack that is attached with 4 5mm bolts? Actually, I would like to see pictures of your bike with stays and dropouts that are meant for that load.
Al Criner is offline
Old 09-18-09, 04:37 PM
Sci-Fi
Sci-Fi's Avatar
Quoted: 16 Post(s)
Need to add axle pegs for safety reasons and passenger comfort...and that means nutted axles instead of QR. Also have to remember that the front end/steering is going to be light with all that weight on the rear. I hauled about 3-4 sand bags at a time (50 lbs each bag) and it's an interesting ride, esp if the load isn't even or in a turn. Have a Topeak rack w/u-lock with fold-out grocery baskets attached, so it was technically being used well beyond its rated capacity of 55lbs, but the rack held up fine. To be honest, I was more concerned about the tires/tubes holding up.
Sci-Fi is offline
Old 09-18-09, 06:17 PM
silvermace
actually....
i've seen lots and lots and lots of people doing it in china/japan/other asian countries. Its all over the place! america is the only place that doesn't have it from what i've seen 0.0
they actually work...
Old 09-18-09, 08:13 PM
HillRider
Quoted: 2026 Post(s)
Liked 1,096 Times in 742 Posts
I've seen lots and lots and lots of people doing it in china/japan/other asian countries. Its all over the place! america is the only place that doesn't have it from what i've seen 0.0
They don't have the liability lawyers we have. Maybe that's why it works. I think that 150 pound figure is a typo.
You want to carry another person on the back of your bike, get a tandem.
HillRider is offline
Old 09-18-09, 08:24 PM
LarDasse74
Guest
Bikes: I never learned to ride a bike. It is my deepest shame.
Liked 6 Times in 6 Posts
As above, the rack may carry 150 lbs but the bolts probably will not.
Just be ready to stop if one of the bolts lets go.
I say go for it!
LarDasse74 is offline
Old 09-18-09, 08:50 PM
joejack951
joejack951's Avatar
Bikes: 2016 Hong Fu FM-079-F, 1984 Trek 660, 2005 Iron Horse Warrior Expert, 2009 Pedal Force CX1, 2016 Islabikes Beinn 20 (son's)
Quoted: 1242 Post(s)
Liked 94 Times in 65 Posts
I say go for it!
The two M5 screws at the dropouts can easily bear a 150 lb. load. Their combined shear strength is around 2400 lbs. The little ears on the dropouts and the vertical struts on the rack are the likely failure points. If you were able to keep the load perfectly centered on the rack, you might have a chance but that's not likely to happen. Once that load starts trying to twist the rack, it won't be long before it buckles under the weight.
joejack951 is offline
prathmann
Quoted: 659 Post(s)
Liked 7 Times in 6 Posts
So the bolts on this rack:
must be just about to fail?
This is a very common sight in Amsterdam, Copenhagen, and many other European cities. And I don't remember ever witnessing any mechanical failures resulting from such 'overloading'. Nor did the racks look particularly sturdy compared to many that are available in the US. The rack on my touring bike that I bought from Nashbar for a little under $10 supports my full weight without any trouble - but I certainly wouldn't want that much weight on it during an extended tour.
prathmann is offline
Old 06-22-15, 10:53 PM
mraeryceos
Quoted: 8 Post(s)
Maybe those bikes are built with beefier bike rack bolt holes?
mraeryceos is offline
Old 06-22-15, 11:58 PM
SkyDog75
Bikes: Bianchi San Mateo and a few others
Quoted: 634 Post(s)
Liked 13 Times in 9 Posts
I have Axiom Journey racks on two bikes. I like them. They're pretty sturdy for their weight and carry loaded panniers (bags) with no problem. I tend to err on the safe side, though, so I wouldn't count on them to support a person's body weight for an extended amount of time. I can think of too many possible failure modes for me to trust it, such as:
  • If one of the rack's aluminum legs gets dinged, nicked, or bent, it'll compromise the rack's strength and possibly dump your passenger.
  • If the rack isn't screwed into the dropout well enough, the attachment could fail -- especially if the dropout is aluminum and possibly prone to strip.
  • If you're riding on roads that aren't smooth, the rack may not be capable of carrying its full rated capacity. Thorn's web site, for example, states that loads on their racks shouldn't exceed half their rating if riding on rough surfaces like ripio (gravel).
On the other hand, I did plenty of things more dangerous when I was younger and less aware of my mortality.
SkyDog75 is offline
Old 06-23-15, 07:27 AM
HillRider
Zombie thread. You guys just resurrected a six year old thread. I wonder if the "teenager" the OP planned to carry still weighs 150.
The Big Wheel
Commuting
0
10-25-16 06:59 PM
baraadnan1
General Cycling Discussion
5
07-02-15 01:24 PM
long john
Utility Cycling
0
08-06-13 04:51 AM
Schwinnsta
Commuting
0
06-06-11 08:50 PM
_kim_
Commuting
0
04-16-11 05:42 PM
