Bent rim = repair or just buy a new wheel?
I picked up a nice old 2005 Scott S1 Speedster but it has a rear rim bent so badly (dented) that it can't be repaired. The wheels are Shimano WH-R550 and the rear is 20 spokes. Specs are here
velospec.com/components/shimano/whr550
I can't find an exact replacement rim online, but a similar DT Swiss rim is about $80 - $100. Add in the charge to repair (I'm not that good with wheels) and it seems I might be better off just buying another complete wheel? Unless there is a source for the original (I'm hoping less expensive) rim? The hub and spokes otherwise seem fine.
Quoted: 2026 Post(s)
Liked 1,096 Times
The WH-R550 wheel sets use straight pull spokes with the nipples at the hub end and a specific rim design that takes the nail-head end of the spokes. I don't think any rim intended to take regular J-bend spokes with the nipples at the rim end will work. so, unless you can source an exact match(or WH-R560 rim) I think you are out of luck. Look here for details and part numbers:
https://techdocs.shimano.com/media/te...9830607425.PDF
https://techdocs.shimano.com/media/te...9830728614.pdf
Thanks for the reply. That's pretty much what I suspected and confirms my wariness with "novel" bike part designs. It may look cool, weigh a gram less and offer a two-second advantage over ten miles, but come next year parts will be unobtanium. I'll keep an eye out for a similar wheel (as I have the "matching" front) used, but otherwise consign it to the parts bin.
Quoted: 454 Post(s)
Liked 104 Times
Nothing novel about any design like this anymore, this type of design has been fairly standard for 10+ years now. For spares, Shimano are better than most for availability, cost effectiveness vs complete replacement is another thing. With Shimano max 10 years / 3 generations is about the norm for availability, being realistic, if you have parts older, they will probably be worn out by that time.
Bikes: 61 Bianchi Specialissima 71 Peugeot G50 7? P'geot PX10 74 Raleigh GranSport 75 P'geot UO8 78? Raleigh Team Pro 82 P'geot PSV 86 P'geot PX 91 Bridgestone MB0 92 B'stone XO1 97 Rans VRex 92 Cannondale R1000 94 B'stone MB5 97 Vitus 997
Quoted: 392 Post(s)
Liked 49 Times
You'll find WH500 wheels and wheelsets where they sell used bike parts e.g. eBay.
Bikes: old ones
Quoted: 26455 Post(s)
Liked 10,415 Times
