Do these parts fit together?
Hi everyone, im struggeling with putting together (renewing) a bike.
I bought a threaded 1 1/8" SUNTOUR XCM V3 fork for a bike. Then i realized i should have bought threadless :/
Now im trying to make it work so i will buy this:
Threaded headset
But i also need a quil stem but im not sure, would this be okay for that:
Quil stem
So my question is would these 3 work together and fit ? I know i also have to saw off parts of the fork but that is just another problem for the future.
Threaded headset
Quil stem
Quoted: 1074 Post(s)
Liked 295 Times
The fork and the headset will work together, but the quill stem/threaded-to-threadless adapter you’ve linked to will not. It’s for an 1” fork, with a 7/8” ID.
Yours is an 1 1/8” fork with an 1” ID.
Clark W. Griswold
Quoted: 4328 Post(s)
Liked 3,949 Times
The most important thing is getting the correct parts. Just admit you made the mistake, try to sell the fork and get the correct fork for it. That fork is a cheaper coil fork so nothing to start changing parts over. If it were some amazing air shock in good shape or something super rare and high quality maybe but even then I would rather just have a newer fork that is under warranty and not used and possibly blown out or tough to get parts for.
Thank you, but then this one should be okay no ?
https://bikeshop.no/xlc/2501568800/x...gaffelr%c3%b8r
Clark W. Griswold
Liked 3,949 Times
Forget about adaptors and different headsets and all of that, just accept you made a mistake, we all do, I have made more than my fair share. Then sell the other fork and buy the correct threadless fork. Maybe take the bike to your local shop and ask if they can help you source the correct fork
Likes For veganbikes:
Yes i see your point and thank you for helping me... but i already said in my first message, when i started the thead:
, which means i admit i made a mistake
My question is still the same, if i were to go with my MISTAKENLY bought fork, would this product fit with the MISTAKENLY bought fork, and the headset i linked
(I was already considering to buy another fork before making this thread, but i might choose the other path. This is why i made the thread.)
Quoted: 1813 Post(s)
Liked 1,692 Times
One thing to keep in mind with threaded forks is that they have to be exactly the correct length for the head tube length. If too short, the headset will have nothing to thread onto. If too long, you run out of threads before your headset reaches the correct adjustment, If you bought a threaded fork by mistake, it is also very possible that you didn't buy the correct length steer tube. Threadless forks are easier in this respect, they are all too long when purchased and simply have to be measured and cut to length
Likes For alcjphil:
Clark W. Griswold
Liked 3,949 Times
Yes i see your point and thank you for helping me... but i already said in my first message, when i started the thead: , which means i admit i made a mistake
As alcjphil said you may have the incorrect steerer length so the incorrect fork you purchased may be even more incorrect for your I screwed up let's keep going down that path idea. As I said just go for the correct fork, sell this fork and be done with it. No need to keep down that path.
Seriously just get the correct THREADLESS fork in 1 1/8" it is way easier and much smarter. Trust me threaded forks aren't worth the time and hassle. There is a reason I didn't keep my Klein frame, finding a fork was a nightmare, 1" threaded suspension fork that has a long enough steerer tube. It would have been much worse if I was having to convert it to something else because I bought the wrong part. 1 1/8 threadless parts are easy to find threaded stuff is not.
That part may or may not work but it really doesn't matter when you have the wrong fork in the first place. I won't stop saying it because there is no point in swapping stick with threadless, plenty of options and well supported and easy to find parts for all over from the cheap to the high end. If I walked into my shop and said I want to convert from threadless to threaded 1 1/8" they would laugh their asses off and rightly so because they know I would have lost my mind at that point.
I get it, it sucks you made the wrong purchase and maybe can't return it, I have done that plenty of times but I moved on and just accepted it or resold the item later and made some or all of the money back.
Liked 295 Times
Yes you did sort of admit that but then you haven't moved on and that is the problem.
I know that it is easier to buy threadless. Thing is that this threaded fork is :
- brand new
- perfect size for the bike (even though it needs to be cut maybe a little)
- would be nearly impossible to sell it, and im currently not in the position that i can do so
Clark W. Griswold
Liked 3,949 Times
Thank you for your answer
- brand new
Your "solution" is a tougher prospect. You have to remove the old headset which requires removal tools and then install a new headset which requires the proper headset presses. If you just get the right fork you don't need to remove what could be a perfectly good headset for something else that is potentially less reliable for off road situations.
Spending more money on parts and labor (or tools to DIY) to make a screw up sort of work is silly. It is not like this is an upgrade for your bike it is actually a downgrade even if your old fork wasn't working there are tons of options for 1 1/8 threadless forks in all sorts of combinations of brakes, axles, and even suspension and non-suspension and suspension corrected.
