Help me choose between unique centerpulls...
Old 02-15-20, 01:15 PM
TenGrainBread
TenGrainBread's Avatar
Quoted: 1136 Post(s)
Liked 650 Times in 336 Posts
I have an upcoming special build that requires a normal, center mount centerpull brakeset. I could go with tried and true MAFAC Competitions or Gran Compe but I sort of want something unique.
Help me choose between brakes:
CLB 2
CLB 1:
Weinmann solid straddle:
TenGrainBread is offline
Old 02-15-20, 01:27 PM
madpogue
Quoted: 2364 Post(s)
Liked 1,751 Times in 1,193 Posts
What's the time period of the bike? If it's '70s or earlier, I like the Weinmanns. Esp. if it's French, British, etc. The CLBs would be more appropriate to '80s, to my (mostly untrained) eye.
madpogue is offline
Old 02-15-20, 01:33 PM
alexnagui
alexnagui's Avatar
Quoted: 157 Post(s)
Liked 113 Times in 64 Posts
Those Weinmanns look interesting, which model are they?
alexnagui is offline
Old 02-15-20, 01:41 PM
3speedslow
3speedslow's Avatar
Bikes: A few
Quoted: 1942 Post(s)
Liked 1,073 Times in 637 Posts
Weinmann would be my choice.
3speedslow is offline
Old 02-15-20, 01:42 PM
TenGrainBread
On Velobase they are referred to as model "737". Not sure how accurate that is.
As far as the frame, it's actually a late 90s bike, a fillet-brazed Jean Paul Routens. The frame and fork are Columbus, probably one of the Nivacrom tubesets. Notably the fork is a fillet-brazed unicrown.
Old 02-15-20, 01:53 PM
bikemig
bikemig's Avatar
Quoted: 5888 Post(s)
Liked 3,472 Times in 2,079 Posts
The CLB 2s look space age cool; I'd use them on the Routens.
bikemig is offline
Old 02-15-20, 05:23 PM
Kuromori
Quoted: 237 Post(s)
Liked 83 Times in 64 Posts
CLB2s are self energizing and therefore different from most center pulls. Whether or not this is a good thing may vary on rider preferences.
Kuromori is offline
Old 02-15-20, 06:08 PM
nlerner
Quoted: 3811 Post(s)
Liked 6,717 Times in 2,614 Posts
I have several sets of those Weinmanns and like them a lot. Problem for me is that the reach is fairly short, but hopefully that’ll work for you.
nlerner is offline
Old 02-15-20, 06:09 PM
madpogue
^^^^ +1 CLB2s for that frame.
madpogue is offline
Old 02-15-20, 08:20 PM
Bad Lag
Bikes: 1974 Bob Jackson - Nuovo Record, Brooks Pro, Clips & Straps
Quoted: 1104 Post(s)
Liked 794 Times in 452 Posts
Show us the matching levers, too.
Bad Lag is offline
Old 02-15-20, 08:51 PM
mkeller234
Rustbelt Rider
mkeller234's Avatar
Quoted: 261 Post(s)
Liked 372 Times in 177 Posts
My vote is for the CLB2 calipers
mkeller234 is offline
Old 02-15-20, 09:43 PM
Hudson308
Mr. Anachronism
Hudson308's Avatar
Quoted: 526 Post(s)
Liked 256 Times in 165 Posts
Whichever you bolt on, that thing will be wild. What are you thinking for derailleurs?
Hudson308 is offline
Old 02-15-20, 10:16 PM
desconhecido
Quoted: 403 Post(s)
Liked 144 Times in 107 Posts
At first glance I thought they were like the 610s, but at second glance, they do look shorter. Other than the look, can't see how they would work differently from typical Weinmanns. Been thinking about it and I've tentatively concluded that all Weinmann brakes with the same pivot points, straddle cable, and geometry above the pivot points will work the same for any effective arm length. That is, a 610 and 750 will work the same on a given bike (brake bridge and wheel diameter).
If I wanted a real distinctive and uncommon brakeset on a very special build, I might opt for a real high quality (or NOS) set of those MAFAC Competition 2000s in gold with matching levers. Kind of "Pricey", depending on the current value of the variable "Pricey". "Pricey", if the project is a gaspipe Falcon with stamped dropouts and a derailleur claw may not be the same as "Pricey" if it's something "Extraordinary". But then we have to eveluate the current value of the variable "Extraordinary". I've long liked the looks of the gold MAFACS but have never owned a bike that I thought desrved them. Putting those on one of my bikes would be like putting C Record on a Schwinn Suburban -- assuming that C Record came with an Ashtabula crank.
Speaking of Suburbans, I've seen ads for them in the hundreds. Oh Lord, the price of electroforged goodness.
desconhecido is offline
Old 02-15-20, 10:28 PM
noobinsf
noobinsf's Avatar
Quoted: 1088 Post(s)
Liked 1,205 Times in 701 Posts
All nice choices, but the CLB 2’s get my vote. Kuromori , what does it mean that these are self-energizing?
Beautiful frame, can’t wait to see it built!
noobinsf is offline
Old 02-15-20, 10:47 PM
TenGrainBread
The pivots are at a 45 deg angle so that the rotational forces of the rim contribute to the braking force as the pads make contact.
Old 02-16-20, 08:24 PM
crank_addict
Quoted: 1361 Post(s)
Liked 424 Times in 283 Posts
CLB 2 gets my vote. Not sure of compatibility, but would try CLB aero brake levers.
crank_addict is offline
Old 02-17-20, 11:46 AM
rando_couche
Quoted: 228 Post(s)
Liked 170 Times in 111 Posts
On a French bike, French brakes! Aesthetically, I'd say CLB2.
rando_couche is offline
Old 02-17-20, 11:55 AM
clubman
Phyllo-buster
clubman's Avatar
Quoted: 2298 Post(s)
Liked 2,055 Times in 1,255 Posts
The CLB2 centre bolts were somewhat short so make sure they'll fit your fork before committing money to it.
clubman is offline
Old 02-17-20, 12:03 PM
Ferrouscious
Some Weirdo
Ferrouscious's Avatar
Bikes: '86 Schwinn Prelude, '91 Scott Sawtooth, '73 Raleigh "Grand 3"
Quoted: 223 Post(s)
Liked 141 Times in 92 Posts
CLB 2s if you plan on a super-ultra-mega-lightning modern build. If you plan on a twine and T.A. crank build, the Weinmanns would better fit.
Ferrouscious is offline
Old 02-17-20, 12:49 PM
USAZorro
Señor Member
USAZorro's Avatar
Quoted: 1492 Post(s)
Liked 1,096 Times in 642 Posts
Based solely on looks - for that frame, I'd vote the CLBs.
USAZorro is offline
Old 02-17-20, 02:29 PM
rhm
multimodal commuter
rhm's Avatar
Quoted: 1908 Post(s)
Liked 574 Times in 339 Posts
CLB 2, just because they're so cool.
www.rhmsaddles.com.
rhm is offline
