Cannondale Quick 1 Disc
#102
Deraill this!
Bikes: 18 Cdale Quick 1, 94 S-Works M2, 98 730 Multitrak, and a few others
Quoted: 146 Post(s)
Liked 450 Times
Operation day!
First objective - Swapped the bars. Cut 48mm off of each end of the RF Turbine bars and swapped them onto the bike. I kept the Ergon GP5 grips and will fine tune them when I can get outside. It was easy other making me wish I owned a band saw to cut the bars. The RF bars were lighter than the Cannondale bars before surgery and even lighter after the cut.
Please forgive the messy workspace… still recovering from the move.
#103
Deraill this!
Quoted: 146 Post(s)
Liked 450 Times
Pulled the chain for cleaning. Checked it for stretch and it’s in spec. I’m guessing one good season and it’ll need replaced. Cassette looks good and the original FSA crank has lots of life left in it. The chain is getting a long soak in Park Tools CB-4 and then some brush work. I also cleaned the cassette and rear derailleur.
Likes For Trav1s:
#104
Deraill this!
Quoted: 146 Post(s)
Liked 450 Times
The crank swap proved to be more challenging. The FSA crank removal was easy and straightforward. The right crank arm forces itself off when you loosen the bolt. Pretty slick design!
I know it is really dirty. A good cleaning this winter was in the plans before the move east. Finally making time for it.
#105
Deraill this!
Quoted: 146 Post(s)
Liked 450 Times
Getting the FSA BB out turned out to be a pain. Finally got both sides loose and started disassembly. Bearings themselves were fine.
Then I found a surprise!
Most of the sand was on the drive side
Another of the drive side
I had my own hidden beach inside the BB. No sand in the bearing.
#106
Deraill this!
Quoted: 146 Post(s)
Liked 450 Times
I’m not sure how the sand got inside the frame but it’s out now. The worst part of the new BB install was working the fine sand out of the threads. I can’t find my 3/8” torque wrench since the move and the 1/4” does not allow for the 35-40 NM needed to torque the bearings. I messaged a friend to see if I can borrow his but I’m about ready to go buy a new one and be done.
#107
Deraill this!
Quoted: 146 Post(s)
Liked 450 Times
While waiting for the friend’s response, I cleaned up the frame and applied some Maguires Cleaner Paste wax. It has a mild abrasive in it and brought more shine to it. I’ll keep working on it and hope to reduce the matte finish to more of a gloss. The metallic does show up more with more shine. That’s the top bar after several coats.
#108
Deraill this!
Quoted: 146 Post(s)
Liked 450 Times
I also noticed some frame details while working on it that i previously missed.
#109
Deraill this!
Quoted: 146 Post(s)
Liked 450 Times
The 105 crank greased and ready for install. Torque wrench scheduled for delivery tonight.
Likes For Trav1s:
Likes For TheRailMan:
#111
Deraill this!
Quoted: 146 Post(s)
Liked 450 Times
Glad my project can help others!
The borrowed torque wrench did not happen. Looks like it’s NEW TOOL DAY for me. Home Depot owns me with all the home repairs so what’s another purchase?!?
Likes For Trav1s:
#113
Deraill this!
Quoted: 146 Post(s)
Liked 450 Times
I have a video of the crank free spinning with pedals but not sure how to host it for the forum. It’s quiet, smooth, and turns so easily. Definitely different than the FSA stuff that came on the bike.
Here are links to the parts I used:
BBInfinite BB with the middle grade bearings since I got a $20 off coupon - https://www.bbinfinite.com/products/...hoCHQ8QAvD_BwE
Shimano M7000 105 Crank: https://cambriabike.com/products/shi...crankset-black
Park Tools Poly Lube Grease: https://www.parktool.com/en-us/produ...ant-tube-ppl-1
Park Tools BBT69.4 Socket: https://www.parktool.com/en-us/produ...Bottom+Bracket
I had a great experience with BBInfinite and multiple great experiences with Cambria.
Likes For Trav1s:
#114
Deraill this!
Quoted: 146 Post(s)
Liked 450 Times
Here's a link to a Youtube share.
Likes For Trav1s:
#115
Deraill this!
Quoted: 146 Post(s)
Liked 450 Times
I'm also thinking about upgrading to 105 brake calipers while I'm at it. I like the idea of having all 105 components on the bike. Why? Because I can. I do some research and share my discoveries.
Likes For Trav1s:
#116
Quoted: 1431 Post(s)
Liked 1,967 Times
105 calipers might be flat mount - not sure (?)
I have RS785 calipers on my Q1D - I believe they are considered to be XT / Ultegra level (?)
RS785 calipers are post mount with straight brake hose fittings - so they are a direct swap and permit use of the existing BH59 brake hose (BH90 is recommended but not required)
the better calipers also permit use of the better (narrow track) rotors and pads (I have RT86 IceTech rotors)
Likes For t2p:
#117
Deraill this!
Quoted: 146 Post(s)
Liked 450 Times
For reference:
https://bike.shimano.com/en-EU/produ...R-R7070-F.html
https://bike.shimano.com/en-EU/produ...R-R7070-R.html
The 2018 shipped with M396 calipers and you can read some thoughts here: https://nsmb.com/articles/are-shiman...budget-brakes/
I'll keep researching and see what I find.
#118
Liked 1,967 Times
For reference:
but I have better brakes on another bike (CX1) - so this motivated the upgrade to the Q1D when I was planning to replace brake pads (the new calipers included pads)
also had annoying issue with the front caliper - intermittent pad drag ... caliper (piston) possibly hanging up
Likes For t2p:
#122
Deraill this!
Quoted: 146 Post(s)
Liked 450 Times
yes - the OEM brakes are fairly good
#123
Liked 1,967 Times
#124
Deraill this!
Quoted: 146 Post(s)
Liked 450 Times
After completing some more of the basement insulation work I was able to reorganize the space - now I have more space for bike repairs. Decided to remove the brake pads and check wear. After approx. 3,500 miles, the wear is what I expected and are getting close to needing replaced. Cambria has Shimano pads on sale I ordered them along with some other 105 upgrades.
I want to explore options before I decide on the brake upgrade. I'm still thinking 105 calipers to go with the rest of the 105 goodies. I like things to match...
#125
Deraill this!
Quoted: 146 Post(s)
Liked 450 Times
Pads and upgraded 105 derailleurs are on their way.
The next round of 105 upgrades are on their way along with brake pads.
