So I did an unexpected thing and I want your help.
I知 a little Surly
Quoted: 699 Post(s)
Liked 1,297 Times
I'm an aluminum wheel guy since I'm not fast nor will I ever be fast, I'm the 32 3x guy that wears wool and talks about all the stuff I say on my latest tour carrying x pounds of junk. I have a bike at my real home that I use for fun and to relieve stress by riding up hills on repeats or riding in places that a hard tail mountain bike would be appropriate. Right now the bike has my default wheels set, fat aluminum wheels with a dynamo and boutique hub in the rear but last monday I decided to lose my mind and ordered these (https://www.elite-wheels.com/product...ramic-bearing/) along with (https://www.renehersecycles.com/shop...38-steilacoom/) the wheels pretty much based on Hambini and the tires because I ride RH extra lights on everything.
While thats the long version of I bought cheap Chinese wheels in a effort to lighten my steel bike because "it's easier to lighten the bike than the rider" I would like to actually stop. Koolstop salmon or dual compound are my aluminum wheel default choice what is the Paul mini V carbon wheels brake pad choice?
climber has-been
Quoted: 3502 Post(s)
Liked 3,648 Times
I use the blue Reynolds pads made for my Reynolds wheels.
But a lot of people report liking the SwissStop yellow pads.
Likes For terrymorse:
Quoted: 7058 Post(s)
Liked 11,112 Times
I love it!
I知 a little Surly
Quoted: 699 Post(s)
Liked 1,297 Times
It's going on this Surly, it weighs 11kg built like this, if i remove the lighting, change the wheels, swap the saddle, and swap the bars/seat post, I should be able to save a kilo. This bike is a play bike so I should be able to save some weight and create a training bike.
Likes For Germany_chris:
Bikes: old ones
Quoted: 26457 Post(s)
Liked 10,418 Times
...those wheels say they have carbon spokes. You are well beyond help, and are now in the abandon hope gateway arch.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
I would never use SS yellow pads on a clincher wheel. I'd use their Black Prince pads or the grey Zipp Tangente pads all day every day. Or Enve.
Bikes: Time Scylon, Lynskey R350, Ritchey Breakaway, Ritchey Double Switchback, Lynskey Ridgeline, ICAN Fatbike
Quoted: 474 Post(s)
Liked 554 Times
How much of a monster do you want to create, Dr. F? I have been very pleased with the Campagnolo Red carbon brake pads. I know they make them for Shimano brakes. I don't know if your pad holders are the ones they fit.
If the stars are aligned and you want to see how expensive those cheap wheels can get, try the Campagnolo pads for Shimano brakes on carbon wheels.
climber has-been
Liked 3,648 Times
Quoted: 2333 Post(s)
Liked 2,097 Times
From my experience, the Yellow pads give off a nasty smell that makes me cough when braking hard when dry and seem to stop a little better than the Prince in the dry but the Prince are better in the wet than the Yellow. For those reasons, I use Prince pads.
Bikes: lots
Liked 2,932 Times
They seem to hold heat longer than the black pads so they can contribute to heat damage on carbon rims. It's always a good idea to use pad holders that have holes in the back to relieve heat build up as well.
Likes For cxwrench:
climber has-been
Liked 3,648 Times
But being a thermal engineer (retired), I question the "hole in the brake pad holder" idea. If the holder's made of aluminum, it's going to be an excellent conductor of heat. More aluminum in contact with brake pad material is a good thing. Conduction pad-to-aluminum-to-air is going to be quite efficient.
Bikes: Two Independent Fabrications, a Niner RLT, and a Trek Domane
Quoted: 10 Post(s)
Liked 16 Times
The black prince pads squeal like a disembowled animal on my carbon wheels. The yellow pads were much quieter. Ridng in the rain on carbon wheels and rim brakes here in the Sierras is a combination I don't ever want to try.
Likes For gravelfan:
Quoted: 443 Post(s)
Liked 472 Times
Me, too. I've also used some generic cork pads that, apart from wearing out pretty quickly, seem to do an okay job of stopping me on long descents. The Reynolds Blues work better but sometimes they squeal. No comment on wet weather performance.
Liked 11,112 Times
Bikes: lots
Liked 2,932 Times
Thanks, I figured the difference between those pads was mostly cosmetic.
Likes For UnCruel:
Bikes: 1984 Fuji Club, Suntour ARX; 2013 Lynskey Peloton, mostly 105 with Ultegra rear derailleur, Enve 2.0 fork; 2020 Masi Giramondo 700c, full Deore with TRP dual piston mech disk brakes
Quoted: 324 Post(s)
Liked 81 Times
Koolstop Salmon are the best for AL rims, and the best for any weather condition, plus they last virtually forever; those have been around for many years, going back to at the mid 70's though they were called Scott Mathhauser back then, but they worked excellently back then and they still do today, there is no need to mess with perfection.
I知 a little Surly
Quoted: 699 Post(s)
Liked 1,297 Times
Bikes: lots
Liked 2,932 Times
As I posted previously either Swissstop Black Prince or Zipp Tangente grey.
Likes For cxwrench:
I知 a little Surly
Quoted: 699 Post(s)
Liked 1,297 Times
Thanks for the recommendations because I'm a simple guy I ordered these (https://www.paulcomp.com/shop/servic...im-brake-pads/) they're Koolstop and will fit my brakes, if i'm not satisfied I'll order some that fit in the Koolstop shoes.
