Bianchi TSX - What tires sizes?
vintage Bianchiist
Bikes: Bianchis, 84 Superleggera, 86 Giro, 87 SportSx, 87 Campd'Italia, 87 Limited, 88 Proto, 95 TSXChorus, 94 TSX105/DAax, 94 Super Grizzley RC, 94 Genius Record, 06 Pinella Boron, 18 Volpe Avanti, 00 Megapro ST Veloce00 EM Strada OS
Quoted: 35 Post(s)
Liked 13 Times
I have 700x23c right now for a bianchi TSX and these are pretty tight. I would like to go to 700x25c, the roads are really bumpy where I live the vibration off the 23c is pretty bad. Will 700x25c fit on the TSX frame?
Here are some shot with 23cs..
File_001.jpge shot with 23cs
Thanks!
Thanks!
Bianchi Goddess
Quoted: 2926 Post(s)
Liked 2,921 Times
Yeah I agree sadly trial and error will be the only way. You may have better luck with something race oriented rather than say a Amradillo or Pasela.
Sugar "Kane" Kowalczyk
Quoted: 4722 Post(s)
Liked 3,036 Times
And,what starts out fitting OK, may cause problems after a period, when the cords start relaxing and the tyre grows fatter. This is one case where you're better off spending the dollars for a premium tyre, as the higher grade and number of threads are more resistant to increases in girth.
Bikes: Trek 400 Elance, Losa Winner, 1994 Schwinn Paramount, Specialized Tarmac Pro, Miele SLX, Ibis Ripley, Colnago Oval CX, 84 Masi GC, 1986 Schwinn Voyageur, 1988 Schwinn Tempo, 1998 Schwinn Peloton, 1991 Paramount Ser3
Quoted: 150 Post(s)
Liked 90 Times
My Bianchi TSX was so tight on the rear end, with 23s, rocks would stick to the tires sometimes and scratch the back of the seattube right there. Consider spending a little more if needed to get some really great tires, maybe with a higher thread per inch, to get a better feel. Maybe something like Michelin Pro4s or something (they seem to be on sale everywhere...great tires.)
vintage Bianchiist
Quoted: 35 Post(s)
Liked 13 Times
Thanks for the advice...I might try some 25s (cause I already ordered them) But I think 23 are the most realistic. I want to keep it racey, and all Italian I'm really only considering Vittoria Rubino pro, or Corsa.
Quoted: 5888 Post(s)
Liked 3,471 Times
That's really tight for 23c tires.
vintage Bianchiist
Quoted: 35 Post(s)
Liked 13 Times
I never fitted 25's. I put on Vittoria Corsa G 23mm which actually measure 24.2mm. So 25mm could fit if you seat the tire a bit lower in the dropouts. The clearance to the rear brake is super tight, I was running with Chorus monoplanners for a bit that were sitting slightly lower on on side when I braked the caliper arm would hit the tire and twore a chuck out of the aluminum! tire was fine. Depends on the brand, a tire that is exactly 25mm maybe, but say a corsa 25mm or grand prix 4000 25mm, no way.
feros ferio
Quoted: 1391 Post(s)
Liked 1,322 Times
True on both counts. My Bianchi works fine with 700Cx28 Continentals, which run small (about 1", i.e., between 25 and 26mm), but would not work with 700Cx28 Armadillos, which run at least full size, if not 1 mm larger.
vintage Bianchiist
Quoted: 35 Post(s)
Liked 13 Times
vintage Bianchiist
Quoted: 35 Post(s)
Liked 13 Times
Jerome Reddy
5
08-18-10 07:05 AM
