Do I need this?
Bikes: Giant Contend SL 1 Disc
Quoted: 155 Post(s)
Liked 78 Times
Do I need this?
can remove? Seems to be a chain guard so if the rear derailer is properly adjusted should be no concern to remove this ugly plastic ..... correct??
jag
jag
Likes For sdmc530:
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,217 Times
It depends. What do you reach for when the shifting goes wonky? If the answer is a screw driver, leave it in place because you are likely to need it. If you say the little black screw thingy on the back of the derailer (bonus points if you know what to call it), then take it off.
Stuart Black
Stuart Black
Likes For cyccommute:
Quoted: 2604 Post(s)
Liked 1,928 Times
It can preserve the wheel if something happens -- for instance, the derailer gets out of adjustment or a stick throws the chain. OTOH after a few years the spoke mounts can break and it'll rattle. I've left them on until they start rattling and I wear out a cassette -- it's not worth the effort to remove, for me, until both those occur.
If you're more concerned about style points, remove it immediately. If you throw a chain, then you may have to replace a quarter to a half of the spokes on the rear wheel, but you're cool in the meantime.
Likes For pdlamb:
Likes For AlmostTrick:
Quoted: 155 Post(s)
Liked 78 Times
no not a screwdriver...
Quoted: 155 Post(s)
Liked 78 Times
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times
Not joking. I am poking. I would never turn any of my bikes upside down to remove wheel. Ruins leather saddle instantly.
If you don't mind saddle marked up.....go for it!
Quoted: 1438 Post(s)
Liked 1,092 Times
You don't NEED it but you might be glad you have it if a stick or other mishap puts your chain inboard of the cassette and into your spokes, as pdlamb mentioned earlier. Even if perfectly adjusted your derailleur can get bumped while parked or otherwise without you knowing it. I put/leave them on but I am a belt-and-suspenders kind of guy and I don't care about being stylish.
SE Wis
Quoted: 2746 Post(s)
Liked 3,390 Times
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,980 Times
Liked 4,217 Times
Stuart Black
Stuart Black
Liked 4,217 Times
As for “sticks”, in nearly 40 years of mountain biking, I’ve never had a stick jam into the derailer and push it past the limit. None of my bikes have spoke protectors and few of the ones that came with spoke protectors every stayed on for long. Properly adjusted, the rear derailer is next to impossible to get to move the chain into the spokes. In my experience...about 10 years at my local co-op...the overshifts have almost always been caused by someone trying “fix” the shifting with a screwdriver.
Stuart Black
Stuart Black
Quoted: 5224 Post(s)
Liked 3,581 Times
someone say stick in a derailer?
but the spoke protector did not come into play
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
No problem, that'll buff right out
Exactly. I had this happen to me once - the bike fell over and bent the derailleur hanger in the process. I didn't notice it being bent at first, and when soon after that I tried to shift into the large cog, the derailleur cage got caught in the spokes and the hanger snapped in two, while the chain didn't move past the casette.
Quoted: 569 Post(s)
Liked 581 Times
I despise upside down bikes also for the damage done to shifters, especially Shimano name plates. When I see a cyclist working on the side of the road on a tire I always ask if they are good, but if they have their bike upside down I slow down as they are much more likely to actually need help.
