Trek 2020 Domane as an all purpose ride?
Quoted: 27 Post(s)
Liked 18 Times
I am looking for a comfortable ride for the back roads and an occasional rail trail,which are fairly decent, well packed clay, and or crushed limestone. Reading reviews it seems to be a decent ride by most opinions. The only downside according to many is the weight which I can live with. I would like to run this with a 46x 36 set up. One poster here had an issue going to a 46 ring yet the SL7 is standard with a 46 Sram. A quick call to Trek said it should be no problem with Shimano ? My other concern is the frame itself. Being a bit old and old school I am pondering the viability of carbon fiber and it's durability for this purpose. Is carbon that susceptible to nicks and dings from the occasional stone? I have always shied away from carbon for this reason, but maybe it's time for a change of thought. Besides I just really like the looks, and if it rides half as well , why not. Currently with this virus issue getting to check these out in person or test ride one will be a while but still would like to be a little more informed . Guess I am just looking for that little push.
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
I think the frame will be fine. The gearing you describe sounds too high, if it is 1X with a 46T chainring. I have a 46/30T 2X crank with an 11-36T SRAM cassette on my off-road wheelset, and I frequently need that lowest gear. The advantage of the 2020 Domane is they finally made it capable of taking wider tires, which is a major advantage for riding off-road (and on, in my case).
Quoted: 27 Post(s)
Liked 18 Times
I am looking at the 105 version with a double chain ring. Hoping to run a 46 x 36 up front or possibly 46 x 34, with an 11-32 casette. It should give me enough to run the hills of western P.a..
Bikes: 50/34, 11-40, 11 Speed
Quoted: 142 Post(s)
Liked 73 Times
A road bike isn't a gravel bike no matter what modifications you make to it. That doesn't mean with modification it will not be adequate but one will never equally replace the other.
Bikes: Trek Checkpoint SL6
I test rode Domane and Checkpoint SL6
I'm in Western PA and wanted a top notch bike for all the great rail trails here. The Domane is faster but the Checkpoint is made for trails, with its tires and places to add more equipment etc. I put over 1500 miles on my Checkpoint SL6 last year and love the bike. I would recommend Trek bikes in Robinson (where I test rode and bought mine).
Quoted: 1461 Post(s)
Liked 1,486 Times
The stock 32mm tires should handle those surfaces just fine, and the bike will still be plenty fast on-road. The frame can accommodate up to 38mm tires so there's loads of options if the OP wants something with more tread.
I wouldn't go out and race Dirty Kanza on one, but for this situation it seems like a great choice.
Likes For msu2001la:
Quoted: 27 Post(s)
Liked 18 Times
Not looking for a heavy duty gravel bike. The trails I would use are probably smoother and in better condition than many roads. I have ridden them many times with 32's and have seen others with much smaller tires having no issues. As msu2001la stated I am just looking for a comfortable ride, 32's are probably as big as I will go. This will be used as a road bike for all intentions. Recently the road has just started to become a little rougher for me, old age, road conditions, who knows. This bike just caught my eye and everything I can find on reviews seem to be quite positive ,especially the smooth ride quality . Lynskey Ti was my only other consideration, I have a 2000 Tuscany with Campy that I really enjoyed but it just sits collecting dust. The roads and needs have changed I have thought about trying something new like the Sportive. Have always feared carbon fiber as delicate and it still worries me but maybe it's time for me to take a leap of faith. This bike, the Domane, just seems to have so much to offer for my needs. CORB52 thanks for the heads up on the dealer. Went to a local dealer and it was a bit sad. Treks were being touted as merely adequate but the Specialized Diverge was being pushed six ways to Sunday by them. They seemed to be clueless on the 2020 Domane changes. Was not impressed. May have to take the wife to Ikea for a shopping trip
Likes For pattrick:
Quoted: 3243 Post(s)
Liked 2,091 Times
You are in the same position. The Domane is a good choice for what you have described as intended use, so I would have the shop work out correct sizing and order one.
No issues whatsoever with rugged offroad use. Keep in mind the frameset was promoted for the pros to use in Paris Roubaix 7 years ago. Hitting those sectors at 32mph is probably more abuse than any of us will ever dish out.
My build 2020 Domane SLR specifically for gravel racing.
https://www.bikeforums.net/cyclocros...vel-build.html
Likes For Emilio700:
Quoted: 27 Post(s)
Liked 18 Times
That post was trouble!
That post pretty much pushed me over the edge. You certainly seem to be making the most of the new ride. Such a beautiful bike ! I had contacted Trek after reading your post and they said there should be no problems with a 46 ring with 105? If there is I may just have to follow suit with your build. I will either thank you or curse you but either way I truly enjoyed your post.
Likes For pattrick:
The vertical adjustment slot in the braze on mount for the front derailleur is sized for a 50T at minimum. Probably a 54T on the other end. I found a round file that was the exact same size as the slot and lengthened that slot downward about 1 mm to get the correct derailleur height for my 46.
Occam's Rotor
Liked 2,331 Times
I wish I hadn't clicked that link, but maybe as a Coronavirus Pandemic survival present.
Quoted: 45 Post(s)
Liked 7 Times
If you have any doubts or want to learn about other options and live in W PA you should go to SweetWater bikes in Ambridge, near Sewickley. They specialize in just gravel and have something like 20 different models of gravel bikes there on the floor, and also sell used ones. Some big brands and lots of high-end specialized gravel brands too. They have monthly shop gravel road rides I have been on. (I think suspended right now due to Coronavirus though). They even sell Open and Bombtrack brands which are hard to find in the area. My wife got her Jamis Renegade there and loves the place as they are really helpful and are gravel fanatics. They have dozens of gravel routes all over W PA if you ask them... It is unbelievable how much gravel they have mapped out within an hour of Pittsburgh. If you want to get into gravel in W PA they are definitely a shop to check out.
Bikes: Diamondback Cross Campus (1993), Trek Domane 2.3 (2016), Cannondale Topstone 105 AL (2020)
Quoted: 19 Post(s)
I've read that 40 mm tires on a 2020 Domane are a 'squeeze'.....Probably depends on the tire, as many are not true to size.
Does anyone know why the 2020 Domane is not offered in aluminum (other than with Sora and lower end group sets) ?
In previous years, the Domane's were offered in aluminum at the higher component levels.
Quoted: 27 Post(s)
Liked 18 Times
Memories
Pizzaiolo Americano
Likes For Pizzaiolo Americano:
Quoted: 45 Post(s)
Liked 7 Times
I have actually spent more time and money there than I am willing to admit. That was when Larry owned the shop. Such a gentleman to work with. Anything I could want he was able to obtain at decent prices. High end bikes? He either had them or sold / knew enough people that he could locate an example for me. If for some reason I can not get along with the Domane I may very well have to venture down that way again. I had heard the place slipped a bit after Larry retired, glad to here it is doing well. Unfortunately that was always a hike for me. For a reference I am twenty five miles from AGH hospital .
They kept the best parts about how Larry ran it and made other parts much better actually. (They cleaned the place up quite a bit too!) They will do anything for you and still will turn around something in a day if you really need it fast. They specialize in gravel now and do have just about everything you would want or will get it for you. They let my wife take a Renegade out for an overnight test ride before she bought it, and they even offer free beer and whiskey at the shop if you are so inclined (they run the Whiskey Rebellion Gravel 200k ride). My wife and I spend a lot of time there and they have a huge library of gravel routes around Pittsburgh that they have developed. I never knew there was so much gravel within an hour drive of the city. I just hope they come out okay after this COVID-19 quarantine thing that has just about all retail shut down in the prime biking season.
I ride a 2018 Domane SL6 (on road) with rim brakes, added a set of Aeolus XXX carbon wheels and love it. Just ordered a 2021 Checkpoint ALR 5 to kick around on off the beaten path.
Dont know how helpful this is, I recently got a 2020 Domane, my other bike is a Cannondale Slate.
Can i go on unpaved bike paths with the Domane? Yes. Is it as good as my gravel bike? No
The domane is capable, but the ride is bumpy and the smaller tires track roots
With the split of road/dirt you mentioned the Domane should be just fine, especially if you put some larger tires.
Sunshine
Quoted: 10971 Post(s)
Liked 7,498 Times
