Hydrophobic spray/coating for glasses?
Bikes: SuperSix Evo | Revolt
Quoted: 733 Post(s)
Liked 815 Times
Has anyone tried anything like this? Did a wet/muddy gravel race yesterday and had to repeatedly spray my glasses with my water bottle so I could see! (I wear contacts, so taking my glasses off was def not an option).
Just not sure if it's advertising hype, or if these sprays/coatings actually work, and whether or not they interfere with the clarity of the lenses. But if they help mud/water slide off, then might be worth a try.
For those wondering, no, the kit did not come clean. Thankfully our new kits are black, and should be here soon! lol
Likes For 10 Wheels:
Quoted: 6963 Post(s)
Liked 10,963 Times
My experience: In those conditions, those coatings are only minimally helpful.
Bikes: Niner RLT RDO, Trek Remedy 9.8
Quoted: 108 Post(s)
Liked 117 Times
More than dirt or mud, sweat always becomes a problem on my glasses when it is hot. I don't really have a good way of cleaning them while riding so this is a good question that I guess i have been wondering about too.
Quoted: 714 Post(s)
Liked 800 Times
Rain-X should work for rain, but I doubt it will help with mud. I've found that glasses don't even protect my eyes in those situations. The mud always seems to find its way under the glasses and into my eyes anyway.
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
Yeah and no.
Yeah, I have it on my glasses.
No, it doesn't do what you are asking.
I have it on because I clean the glasses with water, and never towel them dry. Water rolls off them rather like Rain-X (shout out to dsaul )
Doesn't work in mud. In the rain I usually get those tiny little specks from misting that don't roll off either. I guess I should try it in a heavy downpour, but I'm fine just riding without my glasses in those conditions.
Quoted: 733 Post(s)
Liked 815 Times
Thanks guys, might try some RainX, but won't expect miracles. Guess it's just a hazard of muddy racing.
This race is also now known as "how to kill your chain in one ride".
Might have to use goggles to completely seal out the mud!
Likes For dcee604:
Thread Killer
Quoted: 3143 Post(s)
Liked 1,707 Times
I can suggest an automotive product called Gyeon Q2 View, which I tested on the plastic lens/visor of my Giro. I use it on my car, and have been impressed by its hydophobicity and ability to keep the windows clean. I’ve not given the visor the mud test yet, but I think the great benefit will be that a blast of water from a bottle will do a good job of cleaning them off. That’s my guess, anyway, based on its vehicle performance, and once I get a group ride in on wet dirt roads this winter, I’ll report back with findings.
One note: I wouldn’t advise using the Cleanse included with Q2 View, because it’s an abrasive polish. Just clean your glasses with those single use wipes and then apply Q2 View.
n00b
Bikes: Surly Karate Monkey, Twin Six Standard Rando
Quoted: 428 Post(s)
Liked 466 Times
this is a good solution as well. I would not recommend a conventional "wheel eyebrow" fender you find on most urban bikes because that would clog up with mud. I somehow acquired this Bontrager fender from a kids' bike years ago and it works well. under the downtube and right above the front wheel means it blocks most fo the mud spray that would go directly toward my face. it's not 100% effective, but it certainly helps.
Likes For mack_turtle:
Thread Killer
Liked 1,707 Times
So it’s not that I disagree— I did not intend to imply it’s like properly cleaning glasses— I just want to emphasize that not all hydrophobic coatings perform in the same way.
Quoted: 733 Post(s)
Liked 815 Times
Likes For Rides4Beer:
I used the Oakley / Zeiss stuff. It didn't perform miracles. It was good at getting all the hard to remove stuff off you lenses. It's probably best for getting misty rain to turn little beads into big beads so it'll run off your lens. If anything, that coating would make drying dirt harder to remove as it'd provide a better suction cup for the goop - this happens with ceramic car waxes.
As for the dirty kit..... I heard the belgian CX secret is to hit your white uniform with the powerwasher, then throw it in the laundry. You want that high pressure water to move the fibers around rather than sliding over it.
Thread Killer
Liked 1,707 Times
cleaning easier.
Any reading at all, but certainly legitimate sources, will confirm that.
Fresh stuff and dust.... yeah easier to remove..... Stuff you let baste, harder.
The ceramic stuff isn't thick enough to fill in all pore, so things can still grab onto the surface. Bugs, tree sap, eye gunk (glasses)... anything that has moisture will bond better to the smoother surface as it dries. It's harder than the paint underneath it, so that dried up stuff doesn't form any gap in the bond or surface; water&soap will have a much tougher time getting 'under'/into the dried up gunk, the surface isn't flexible enough to release the gunk.
Thread Killer
Liked 1,707 Times
I hear you. I haven't tried it myself. It's hard to get past the thousands of bits of BS sales sites out there to get real information. I've seen it in a few of the more non-sales bits of info I found out there when I was looking at it for the car I bought just a bit ago. 99% of the 'information' out there is clearly sales BS, so it's hard to know what's good information. I know they've changed quite a bit in the past few years (making it much harder -which sounds stupid on a flexible surface) and there's a thousand different variations of it. Common themes were "any imperfections in the prep are there forever", "doesn't do anything for rock chips or scratches", "car looks amazing all the time", "gotta wash it in some special way", "consumer versions only last 6mo", "retailer stuff is expensive, lasts years, and only as good as the prep"
Anyway for specs...... the Oakley stuff is good for fog and mist, not for mud and allergy eye gunk.
Thread Killer
Liked 1,707 Times
ceramics are touted like some kind of miracle, which they certainly are not, in the sense that a car will get dirty and need washed. Someone in Vegas will have a totally different experience than someone in Detroit because of the weather, too, which is another variable to sift through and one rarely mentioned by anyone.
The Oakley AFR, if that’s the stuff you’re referring to, isn’t at all like a ceramic coating, so no surprise it’s only good for anti-misting.
I’m struggling with arthritis in my knees right now, and I’ve fallen off pace with my gravel gang, but if I can fight back to some reasonable fitness by spring, I’ll be able—hopefully— to provide the kind of feedback on the Gyeon Q2 View as you have on the Oakley stuff, rather than just extrapolating from car experience.
Quoted: 427 Post(s)
Liked 699 Times
Jockeys (horse racing) use peel-offs on their goggles, as there can be quite a bit of mud/dirt thrown during a race. Would think that you could find some that would fit over glasses, and have ventilation (sure they get hot riding too). Goggles going over temple pieces seems that it could be a problem, but might be worth looking into. Might also check a motorcycle shop for goggles used for moto-cross--should have tear-off capability, again, fitting over glasses, and ventilation, may limit what will work.
Quoted: 108 Post(s)
Liked 117 Times
Quoted: 427 Post(s)
Liked 699 Times
Don't want anyone to think I'm advocating with littering up a trail. I am very "leave no trace"-usually carry out more than I carried in when riding trails. My recommendation was in response to the OP's post-which was racing oriented. Any race course could, and should, be cleaned up after a race, so anything discarded, or broken off a bike, would be cleaned up. Don't think you'd need a tear-off when just trail riding, as you most likely wouldn't have anyone close in front of you throwing up mud, and if just trail riding, not a big deal to stop and clean off lenses, as opposed to losing time or place when racing.
