Show me your cruiser.
#1176
I like bikes
Ha similar bars here!
Just a non-descript bike here with added springer fork. I did not know there were different springers for different head tube lengths. So I have a bandaid fix to make these forks work, even after taking close to an inch off the headtube. Not perfect but it works. Two speed kickback coming, then grey tires with blackwalls. Done.
Just got a Schwinn Corvette to fix up, much as the Hawthorne above, which is very cool.
Edit: Changed out to grey/black tires.
#1178
K2ProFlex baby!
Location: My response would have been something along the lines of: "Does your bike have computer controlled suspension? Then shut your piehole, this baby is from the future!"
Bikes: to many to list
Quoted: 16 Post(s)
Liked 56 Times
Thanks! 😁 The brakes are decent enough, even though the first few rides were a bit scary! 😂 just like any brake it just took a little time for the new brake shoes to break in, then I got used to them. 😉
#1179
I like bikes
I have 700c on my old 1957 Schwinn Corvette (I did not do the change). I am taking it back to 26x2.125 for a bmx cruiser bike, klunker style.
My project is just starting and will take a couple of months.
I measured the diameter of the 700c (32mm I think) and its the same as 26x2.125, but the rim braking surface is about an inch shorter.
Edit: I wasn't ready to post in here as my bike is at pre build - just how I acquired it.. My build up has not yet started. Mods moved it. Its an example 700c can fit on a 26" bike.
In the next month or so I will get it back to 26" and more inline with a cruiser bike.
Last edited by Maxacceleration; 11-19-20 at 11:49 AM. Reason: Post moved from another thread
Likes For Maxacceleration:
Likes For Unshore:
#1181
Bikes: Cannondale M500, Electra Cruiser 7, Schwinn Cruiser 3 2003 retro, Trek Calipso Cruiser 7sp, Dyno Taboo Tiki, Dyno Moon Eyes, Dyno Duece, Dyno Moto 7
Quoted: 79 Post(s)
Liked 17 Times
Custom for a purple lover
I had a request from a neighbor who loved everything purple. She found me outside wrenching on my own bike and asked if such a thing existed, a very purple bike. I took it as a challenge and found a piece here and there. Should have seen her face when she saw it for the first time.
#1182
Quoted: 79 Post(s)
Liked 17 Times
Likes For Crossthreaded88:
#1183
Quoted: 79 Post(s)
Liked 17 Times
I was struggling with some shoulder issues and could not ride my normal road bike. So I took some older parts and updated my cruiser to be a little more road friendly. The upright position has helped me get back and riding.
i added 700c wheels, 9 speed thumb shifters, and a nice set of 3 piece cranks.
#1184
I like bikes
And now...
Out today
#1185
For the brakes I tried 2 different things. I started with some adaptors that bolted on the bike, then the brakes bolted on to the adaptors. I only did that to the fronts to test it out and it worked ok. I then found some long adjust brake arms and switched to those. They had more distance to adjust and made it easier to line up the pads. They were an amazon special and marketed under "folding bike brakes".
#1186
Quoted: 79 Post(s)
Liked 17 Times
Thanks Crossthread. The process has already started, but is reversible of course, pretty easily. At least with bars stem seat & post. Wheels will go to 26". I will have a couple sets of tires in time. Thing is it does roll pretty fast & easy on 700c.
And now...
Out today
And now...
Out today
So you pretty much did everything that I would never do and that's totally cool everyone is their own Captain and sets sail in their own direction. Funny the one item I would have replaced first you saved. I'm talking about the red and white stiff Schwinn seat. The fork may change the frame geometry I can see in the pics the wheel is closer to the down tube. Again not being critical, how does the phrase go, "I'm just saying" I kind of thought it was almost perfect as you found it except for grips and a seat. The lean back post is a nice touch. Thanks for sharing your bike pics and continue to do it your way.
This is a 1980 Schwinn that I just sold with a modern alloy wheel set
#1187
I like bikes
Sorry to disappoint Crossthreaded! I am going for a slightly different look than some... Fresh refinish, fresh decals, keeping the chainguard, and the seat... yes, to keep a factory cush deluxe bmx style. The seat is certainly not for comfort! And I paid a fair amount for that cherry 1959+ seat. I do have a diamond stitched bmx saddle also.
As far as the fork... it looks no closer than your bike pictured, although it may have less rake possibly. I have rode it like that, and it is stable and good turning. I am not the first to do so!
Keeping the 3 spd SA for hills. Of course I am swapping to 26" wheels.
The reason I go this route is this bike was/is missing many original Corvette pieces. Instead of going back to original (searching for used parts) I am going newer bmx cruiser/klunker style (using many new parts).
I can't ride as aggressive with one gear or beach bars.
I am looking for two more cantilever 26" frames to build up. One for my adult kid, and one for my childhood teenage Sting Ray neighborhood terror friend.
All good.
All good.
#1188
Bikes: Modified 26 inch frame Schwinn Varsity with 700c wheels and 10 speed cassette hub. Ryan Vanguard recumbent. 67cm 27"x1 1/4" Schwinn Sports Tourer from the 1980's. 1980's 68cm Nishiki Sebring with 700c aero wheels, 30 speeds, flat bar bicycle.
Quoted: 131 Post(s)
Liked 141 Times
Here's my 1950's Ward Hawthorne, 3-Speed / BMX / Klunker. Did the rust patina myself, ground off the outer teeth of a Lamber Viscount crankset to make for a cool chainring guard, and just had loads of fun putting this bike together. Perfect chill neighborhood cruiser.
Likes For tallbikeman:
#1189
Here is my Sanctuary 7 in stock form.
I've always wanted a bike with an internally geared hub though, so when the time came to address a few shortcomings I added a Sturmey 5 speed with drum brake, cantilever brakes up front to go with the short throw Sturmey levers that matched the rear hub, and added a QR front hub too since I was already changing the rims to get away from the painted ones that came on it stock. I got some alloy bars for it but they likely won't get installed because they are a little narrower than I was imagining. The alloy seatpost got installed but may not make the cut either, with the seat tube angle on a cruiser it is at the limit of it's adjustment, and I'm not sure if that's enough.
All of this started with the intent to get rid of a very persistant brake squeal. Things may have gotten out of hand.
I had to keep a derailleur on it since it has vertical dropouts and the tensioner I bought doesn't have enough reach to match the chainline, but I've since ditched the stock plasticy one for an older all metal number with a short cage. Forgive the red pulleys, it was used, I'll make them black or silver eventually.
I oriented the shifter and brake arm along the seat stays instead of the chain stays so I could use the stock braze ons for the cables. I'm kinda bummed it has vertical dropouts but the whole bike was something of an experiment anyway. If the right vintage bike comes along I may move all these parts over to that frame and ditch the derailleur. Yes, I did consider adapting an eccentric bottom bracket to it but come on, you have to draw the line somewhere. This bike was under $200 delivered to my door after all.
I've only ridden it once since finishing it.
The front brake still squeals.
I haven't done any further adjustments to the new cantilevers to eliminate it yet but I'm starting to wonder if maybe the cheap fork lets the arms vibrate on the mounts...
#1190
Quoted: 131 Post(s)
Liked 141 Times
Going down the squealing brake list of possible suspects, first the pads, sometimes pads are squealers. Second the brake arms on a big box store bikes can be cheaper knock offs. The metal may not be as good or there may not be enough of it to do the job or some sort of engineering crippled the design. Better quality brake arms might quell the squeal. These rims look clean and unpainted so I would look at pads and the brake arms themselves. There are plenty of good quality cantilever brakesets out there. I buy used a lot of the time and save money. At one point in my Internal Geared Hub fantasy I bought a Sturmey Archer 5 speed hub and used it. It had a thumb trigger, old school, and the gear changing chain going into the axle from the drive side. Yours looks to be the model that has a rotary shifter. I had an issue with first gear slipping when power was applied to it. Couldn't use the gear to go uphill. It would slip out of gear no matter how I adjusted it. Tried it for a year and gave up. It sits in a box at my house. I finally gave up on Internal Gear Hubs after my Shimano Alfine 11 speed debacle. That hub had nothing but problems and no mechanics to fix it. Leaked oil from day one, slowly got harder and harder to pedal********** I changed the oil on schedule with Shimano Alfine oil and it slowly turned into a horror story anyway. That one sits in a box too. Back to derailleurs and cassettes. Much better. I still own a 3 speed Sturmey Archer hub on my Worksman LGB cycle truck and it works great. Hard to put derailleurs on Worksman bicycles. But the siren song for Internal Geared Hubs doesn't call to me anymore.
#1191
Quoted: 131 Post(s)
Liked 141 Times
I also forgot to mention that some brakes squeal their whole lives while stopping the bike just fine. A lot of older drop bar 10 speeds with center and side pull brakes squeal. There was a lot of instructions about towing in the pads and other adjustments but they still tended to squeal. I think the calipers themselves were to blame because of a lack of rigidity on those designs. Idle speculation on my part. I just let them squeal, warns the pedestrians of my presence.
#1192
Quoted: 131 Post(s)
Liked 141 Times
Here is one of my favorite Cruiser Bikes. It started out as an Electra Punk (2008). It has an alloy frame and a 3 piece crankset. The Punk paint job was not a selling point with me but these "tank" models were hard to find so I bought it. The first thing I did was paint it flat black. I rebuilt both wheels using the original rims. On the rear, I used a Nexus 8 speed internal gear hub. I don't remember if the Alfine 8 speed version was around then, but what I got was the Nexus version which used the Shimano Roller Brake. At first, I was not keen on the clunky looking roller brake, but after using these on multiple bikes over the years, I have come to believe these are good brakes and definitely better stopping than caliper brakes. On the front, I put a new hub for a disc brake rotor. These bikes did not come with a front brake at all, only a coaster brake on a Nexus 3 speed rear hub. I made a fork mount for a Shimano disc brake and with that and the roller brake installed, the bike had very good stopping power. The tires are the original 24 X 3.0 Fatti-O white wall versions. I made a shorty fender and added it to the front wheel. I added a headset extension with a medium high riser type handlebar because I like to ride in a vertical position. Various "Flame" decals gave it a vintage Hot Rod look IMHO. A Streamride "flame" seat completed the mods.
#1193
Quoted: 131 Post(s)
Liked 141 Times
My first Cruiser Bike. It is an Electra Rally Sport (2002). The paint is powder coat in anti-freeze green. Rear wheel has a Nexus 7 speed rear hub with coaster brake. Front wheel has a King disc brake hub and Shimano disc brake. Both tires are Fatti-O 24 X 3.0. Three piece crankset. High rise handlebar. Electra bike rack. Note: the simulated suspension forks were an Electra option.
The Old Peddler
The Old Peddler
#1194
Quoted: 131 Post(s)
Liked 141 Times
#1195
Quoted: 131 Post(s)
Liked 141 Times
Very nice lines on this bicycle. We have a BMX/Lowrider club here in Sacramento CA and this bike would rule. You have a very good eye for design. On another note how floppy is that front wheel when riding?
#1196
Quoted: 131 Post(s)
Liked 141 Times
#1197
Bikes: Schwinn Panther Alfine 8 speed klunker MTB
Quoted: 11 Post(s)
Liked 5 Times
2000 Schwinn Panther
This is my 2000 Schwinn Panther. I bought it off of craigslist in stock condition for $75. It's my little trail bike, and still a work in progress.
Some issues with it. The u brakes limit tire width in the rear to 2.1 inch. Also, the u brake bosses affect my chainring size: stock, it's 45 teeth, but I'm not sure if I can go below 44, or the chain will contact the u brake bosses. So, currently I'm running 45x19, but will change to 45x23 for better climbing. Right now, this bike is geared for road riding; it's fast.
I put a Surly Sunrise handlebar on and cut off about 3/4 of an inch on both sides.
The tires are nothing special, and a little heavy, but good for the local fire roads.
2000 Schwinn Panther https://imgur.com/a/J1tK18S
#1198
Old and rusty
Bikes: 1983 Lotus, 1989 Haro Escape, Quax muni, KHS?, Nishiki Olympic 12
Quoted: 66 Post(s)
Liked 111 Times
JC Higgins I picked up as a frame set. I have the fenders and chain guard too, but can’t use them with the 700 x 32 wheelset I put on it. I’ve been enjoying the ride so much I may build it it’s own set of 26” wheels
Likes For Swampthing:
#1199
Quoted: 131 Post(s)
Liked 141 Times
#1200
Old and rusty
Quoted: 66 Post(s)
Liked 111 Times
My son’s new cruiser. We just “finished” the build yesterday.
