Odd Gearing for Crankset?
Bikes: Bianchi Ti Megatube; Colnago Competition; Planet-X EC-130E; Klein Pulse; Amp Research B4; Litespeed Catalyst; Trek Y11
Quoted: 605 Post(s)
Liked 480 Times
A friend just bought a 2005 Bianchi Nirone a 9-speed groupset mix of Bianchi-branded components (brake calipers, wheels, stem, crank arms) and Campagnolo Xenon (shifters, front and rear derailleurs), and with a triple crankset.
The chainrings, which look to have been replaced over the years, are 49t/39t/30t.
The Miche cassette is 14t-26t.
To me this is a weird combination. I'm used to 52t or 53/39t, with a 12-28t cassette, or pretty close to that. I do appreciate a compact 50/34t.
So what's the point of the 49t big ring? The previous owner didn't elaborate much about what sort of cycling they did, I think they probably just suffered along in whatever gear they were in.
Is this something people are doing for touring? I'm just curious if there is a logic to this (the triple to be able to climb up a wall if you want?), and maintaining enough overlap to get whatever ratio you want; or what I feel is more likely, this was just whatever was available that fit.
Thoughts?
Thoughts?
Quoted: 3983 Post(s)
Liked 7,433 Times
It might make sense if you plug all the included gear sizes into a gear calculator.
OM boy
Bikes: a bunch
Quoted: 540 Post(s)
Liked 671 Times
Given it's 9 spd, the 14-26 would have a large group of single tooth cogs up to 19, which means nice, tight gear choices for most road riding between 100 & 60 gear inches, also allowing the rider to stay in one chainring for quite a variety of flat to punch rollers, and solo or group rides.
Not racing gearing, but certainly very nice for even fast group rides between 30 & 14 mph, then having the granny ring for those serious alpine climbs....
I have similar on my older Sworks Tarmac which I keep at my family home in Germany - 50/39/30 & 13-25 covers me for ANY possible ride!
The 49 being a bit 'different', but that may have been because IT was available at the time, and not a 50...
A well set-up Triple is still a thing of cycling beauty... when you want 'One Chainset to Rule Them All'.
If you're not in a 'race' (where an eight yard gap means you're shelled) and have time to consider your options, a triple can't be beat....
unless your self-assurance is tied to your equipment, as opposed to your legs...
Ride On
Yuri
Ride On
Yuri
Likes For cyclezen:
Quoted: 605 Post(s)
Liked 480 Times
But thanks anyway.
Quoted: 605 Post(s)
Liked 480 Times
Ride On
Yuri
Ride On
Yuri
I do agree on the rest, triples have their place and seem to be making a big comeback. My personal preference is for doubles, aesthetically, but also simply because it's just what I've been riding for so long and change is hard LOL
Cheers for that info
Liked 7,433 Times
Sorry, but you didn't ask if it was a common thing, just "what's the point of the 49t big ring?" Again, if you plug the numbers into a gear calculator, it might give you a hint about the previous owner's logic.
Likes For tomato coupe:
pan y agua
Quoted: 1461 Post(s)
Liked 737 Times
Shimano has not made a triple crankset above Tiagra since 2012. Campy last introduced a group set with a triple that same year, and SRAM never bothered with a triple.
With 12 cogs on the back you can cover a wide gear range with close spacing, without the need for a triple
You could get lost and die.
You could hit a tree and die.
Likes For merlinextraligh:
Quoted: 1431 Post(s)
Liked 1,965 Times
Thoughts?
the low gear is not low enough - the high gear not high enough
the tight spacing of the cassette is largely of dubious value on a bike with a triple
this setup does succeed to give triples a bad name
smh
Likes For t2p:
Quoted: 605 Post(s)
Liked 480 Times
all the disadvantages of a triple - and basically none of the advantages
smh
smh
Quoted: 605 Post(s)
Liked 480 Times
In what universe? I do not recall seeing a new bike with a triple for quite some time. Things are going the opposite direction, I’d bet dollars to donuts there are way more 1x’s sold today than triples.
pan y agua
Liked 737 Times
I never drew a conclusion regarding the merits of a triple from their lack of sales. I simply took issue with the assertion that triples are making a big comeback, which appears to a fantasy.
Perhaps in Grant Peterson’s dreams.
Quoted: 605 Post(s)
Liked 480 Times
Your assertion, to which I responded is that triples are making a big comeback. I simply see no evidence of that, and you’ve provided none.
pan y agua
Liked 737 Times
You put out bad information; I call you on it, and you find that to be objectionable?
Quoted: 605 Post(s)
Liked 480 Times
Since you asked: I find people like you obtuse, pedantic, insecure, and insufferable - a troll. "Dollars to donuts" you're a boomer; and if not, you've got the same mentality, you know everything, can't help expressing this to others, and will not be persuaded otherwise. Have a nice day.
Quoted: 7069 Post(s)
Liked 11,143 Times
Edited to add: I see that another poster already pointed this out, and you seem to be taking it as some sort of personal attack. But it’s just a simple fact. Go to a bike shop and look around.
Likes For Koyote:
pan y agua
Liked 737 Times
Now you resort to ad hominem attacks, and ageism. Our disagreement is an empirically observable fact. No reason to get upset, resort to logically unsound attacks, and insults.
So rather than resort to personal attacks, persuade me why I am wrong. Show me some evidence to support a claim that triples are making a big comeback.
Quoted: 605 Post(s)
Liked 480 Times
Liked 7,433 Times
This thread sure went south fast ...
pan y agua
Liked 737 Times
If you can’t support your position with facts or logic, attack your opponent.
Quoted: 605 Post(s)
Liked 480 Times
Liked 7,433 Times
Quoted: 2539 Post(s)
Liked 3,017 Times
The 7 Best Hybrid Bikes For Exercise, Commuting and Casual Fun
Figured triples might be found on hybrids, if anywhere, so I searched for "hybrid triple crank." Bicycling! magazine's "7 Best Hybrid Bikes" report lists two bikes with triples (3x7 and 3x8), one with a double (2x9), and three 1x (one an electric bike).So triples might be well represented among hybrids, anyway. But was there a time when hybrids had lost their triples?
For the record, a hybrid of reasonable quality that has a triple crank is, in my opinion, the most versatile bike ever conceived. Ironically, maybe the only topic that unites retrogrouches and cutting-edge roadies is that both despise hybrids. Makes sense. Neither group, despite the occasional lip service to the contrary, has much use for a people's bike.
Likes For Trakhak:
Forum Moderator
Bikes: Fuji SL2.1 Carbon Di2 Cannondale Synapse Alloy 4 Trek Checkpoint ALR-5 Viscount Aerospace Pro Colnago Classic Rabobank Raleigh C50 Cromoly Hybrid Legnano Tipo Roma Pista
Quoted: 3104 Post(s)
Liked 6,649 Times
Knock it off with the personal attacks and stay on topic.
If you can't post here without personal attacks, then find another thread.
Likes For cb400bill:
Quoted: 1530 Post(s)
Liked 718 Times
Given the Miche cassette, which allowed bespoke combinations like this 14-26 with two 2t gaps and a 3t gap, I'm going to assume the previous owner put a fair bit of thought into ratios and that the 49t was no accident.
The only bummer about it would've been that since big rings need to be made with a specific size of smaller ring in mind and that 49/39 isn't really a thing, front shifting probably wouldn't be great.
Likes For Kimmo:
