Painting over engravings
Slowfoot
I'm planning to DIY SprayMax a steel frame. Any ideas on how to keep delicate engraving/stamping on the fork crown from filling with primer and base color - I would like to fill with another color. I considered filling with spackle and then cleaning it out after painting, but maybe not a good idea if the paint forms a tough film that might tear or peel.
Edumacator
Quoted: 2444 Post(s)
Liked 3,141 Times
There’s paintable masking fluid. Randy Jawa has used it before I think.
So, do a test as part of your planning for the painting. You may find your fear of infilling unjustified. You may find there's a time during paint cure when removal CAN be done and may find a time when removal CANNOT be done.
How about masking the engraved and painting it separately, where it can get special attention?
How deep is this engraving? Is it delicate filigree work or is it a deep logo?
Fuji Fan
I wonder if candle wax would work. I worry about being able to get all the residue out afterwards, when you actually want to fill the void.
Maybe some sort of pourable rubber might be an alternative.
Quoted: 3464 Post(s)
Liked 2,831 Times
Let's see what you want to preserve.
when new, maybe a thinner coat but OEM paint rooms did not go to great lengths
Friendship is Magic
Bikes: old ones
Quoted: 26427 Post(s)
Liked 10,386 Times
...on every bike I have ever painted that had pantographed designs on it. the pantographs were deep enough that this was not an issue. The layer of primer and the color coat together, do not fill the engraving. At worst, they might impact the clarity of line, but this has never seemed an issue to me. You do need to be careful doing the contrasting color infill, to get a crisp, clear result. I usually just let the color coat dry and cure, and do this pantograph color as a final step, along with adding the decals/stickers. You fill with color, using a slightly thickened (drier) paint, then use some sort of rag or paper towel dampened with mineral spirits. stiffened with a piece of cardboard cut to the curve of the surface, to do a quick wipe of anything outside the pantograph.
Quoted: 4513 Post(s)
Liked 6,392 Times
No grease, wax or the like around paint, migrates and leaches. Ideally frames are absolutely oil and grease free. Never framesaver a frame that is to be painted.
Most good painters scrub with acetone or lacquer thinner right before paint. Merz hot tanked his, this can be the most critical step in a top level paint job.
Slowfoot
Good thoughts, thanks. I'll post project photos later. A '79 Sannino.
