Hitch rack recommendations
Old 03-31-23, 01:08 AM
Duuuuuude99
Quoted: 8 Post(s)
Liked 9 Times in 5 Posts
We have a Thule t2 hitch rack. I discovered I can move the two trays closer to each other.
then the trays can be shifted so the two front wheel holders, when used for single bikes, are now used for both wheels on the tandem.
the entire bike barely hangs over the edge of our Toyota sequoia because it’s slightly angled due to the trays not being completely aligned.
like some others, having to hoist our tandem on the roof seems like something I would have difficulty doing due to height.
I save the roof racks for our single bikes.
Duuuuuude99 is offline
Old 04-06-23, 09:14 PM
tgot
Bikes: 1986 Centurion Ironman, 1997 Trek 2120, Trek T1000
Quoted: 138 Post(s)
Liked 208 Times in 119 Posts
We use a Thule 5-bike hitch rack. It's rated for 150lbs of bikes.
I made sure that the Trek T1000 was the first bike on; with wheels off it isn't much wider than the SUV.
With tandem+three regular bikes, not-light hybrids, I'm not sure I'd be comfortable doing aggressive driving. But 90 minutes of mostly highway was totally fine.
tgot is offline
Old 04-06-23, 09:18 PM
tgot
Quoted: 138 Post(s)
I should have mentioned that the tandem had a kid back stoker setup on it. Including kid-backrest. Which in total weighs quite a bit!
A regular tandem I would have worried about a lot less.
tgot is offline
Old 04-11-23, 01:58 PM
PittsburghBill
Originally Posted by surak
I've a steel Santana 26" with full fenders, just installed a 2" receiver and thinking of getting a rack instead of jamming the whole thing into my HR-V in long-mode. Wouldn't be used that often or for epically long trips, but not looking for bottom of the barrel. What have others used and would recommend?
I'm aware of the Draftmaster but it's both overkill from a price and functionality perspective (wouldn't trust using it near its multi-bike carrying capabilities since my car likely can't handle the weight).
I have used a Yakima roof wrack. Easy load. As shown in #23.
1. Swing out front fork connector.
2. Remove front wheel of Tandem.
3. Stand on rear wheel and connect front fork to wrack mount.
4. Lift rear of bike (I do it with one arm, my wife needs both arms to lift the bike) and rest on cradle. Tighten straps.
5. Attach bike front wheel to mount, You are done..
PittsburghBill is offline
Old 04-14-23, 09:56 AM
bblair
Bikes: Lynskey R230, Trek 5200, 1975 Raleigh Pro, 1973 Falcon ,Trek T50 Tandem and a 1968 Paramount in progress.
Quoted: 380 Post(s)
Liked 395 Times in 234 Posts
"I have tired of hoisting a 38lb tandem onto the roof, even with the articulation offered by the Sidewinder. I'm also tired of removing the front wheel to mount the tandem. So I'm looking for another solution."
Same here. Our tandem is a 25 year old Trek. We get it to the roof of my Honda Crosstour, but it's getting more difficult every year. And it seems that every year cars get taller and we get shorter. And older. Following this thread, for my next car.
bblair is offline
Old 05-31-23, 11:35 AM
dave s
Quoted: 5 Post(s)
We use an older Hollywood rack like cyclocommute , but it is a three bike rack. I electrified our 1999 Cannondale RT1000 with a front hub motor, so I don't want to take off the front wheel unless absolutely necessary. Our tandem is a M/S, and sticks out about an inch past the mirrors on both sides of on our Nissan Xterra. Rack works great, we tie a small red flag to each wheel for added visibility
, have not had any issues. Have carried the tandem at the back spot and 2 1/2 bikes on the other two, rock solid
dave s is offline
Old 08-10-23, 05:06 PM
Chilepines
Bikes: 1984 homemade 531SL road bike; 1988 Ritchey TimberComp; 1997 Nashbar tandem; 1998 Kona Explosif; Specialized Epic, Scott CR1 Pro; Salsa Beargrease; Curtlo custom Tandem, Curtlo custom S3 steel gravel bike.
Quoted: 67 Post(s)
Liked 49 Times in 37 Posts
Designed this rack to mount our tandem sideways behind our van. On top was not an option as it is too tall and we're driving more than 5000 miles in an 89 VW Westfalia. 3000 miles in and the rack is great.
Had some 3 inch aluminum extrusion previously used for a roof top rack and had this welded by a local welder. He charged me $50 to weld it. Added the front triangle after finding that the aluminum was twisting a LOT under load. Super stable with the added triangle which is further supported at the steel step.
Really happy with how this worked out and hoping someone else can use this idea.
Rack behind Westfalia - overhang is less than it appears. Just about 2 inches to each side.
Side view
Wheels are mounted on Fix-Fork wheel holder which can handle QR or thru axle hubs.
The whole thing is in a Kuat Pivot 2 swing-out rack.
Rack is built of heavy channel aluminum bolted to a 2 in receiver extension with step.
Fix-Fork for wheel mounts is really nice, reasonably priced, but needed to be ordered from the company in Belgium and was expensive to ship.
Chilepines is offline
Old 08-12-23, 08:00 AM
cavediver
Nice, I think that it's much better when people think things through and come up with their own ideas. You will always run into naysayers. Your rack looks like it should work well.
cavediver is offline
