Vacuum Dent Removal
Quoted: 392 Post(s)
Liked 564 Times
Vacuum Dent Removal
Anyone ever tried that? Saw a kit for cars but I'm sure it's way too big to try on a bike.
Gonna be pretty difficult on a tube but would probably work with the right rig.
Just Pedaling
Bikes: YEP!
Quoted: 338 Post(s)
Liked 532 Times
The tin on a car body is thin, soft, and flexible compared to tubing on a bike. Car body not structural per se. Bike frame structural, Good luck
Quoted: 3464 Post(s)
Liked 2,831 Times
I returned to my car and some yahoo doubled my aluminum car hood with a piece of lumber...
might have to try.
or just pay the price.
might have to try.
Quoted: 964 Post(s)
Liked 1,451 Times
Trouble with vac is it's limited to the pressure the atmosphere can push on the other side. If you completely evacuate the area over the dent, you'll get about 1atm of pressure. 1atm = 14.7psi. If the dent is a whole square inch (huge for a bike!), you're only going to get 14.7 pounds on it. Which probably isn't enough for a dent even a fraction of that size.
I recommend the Sheldon Brown solution...
Quoted: 1088 Post(s)
Liked 1,206 Times
I tried it. It sucks.
I’ll see myself out.
Likes For noobinsf:
seńor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3901 Post(s)
Liked 6,511 Times
Vacuum dent removal
Likes For SurferRosa:
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4690 Post(s)
Liked 5,837 Times
Quoted: 640 Post(s)
Liked 1,313 Times
I've done it on the thin sheetmetal of a late model car, it got "most" of the dent out. I've also removed a dent from a bicycle head tube with a steel bar a few thousands of an inch smaller than the I.D. of the head tube and I can say with total confidence that even if you COULD get it to seal on a tube there is NO way any vacuum or suction cup will pull a dent out of a bicycle frame.
curmudgineer
Bikes: 2 many 2 fit here
Quoted: 263 Post(s)
Liked 112 Times
Maybe a super epoxy or light cured acrylic adhesive and the vacuum dent puller combined with a slide hammer might get you somewhere, but I doubt it.
Best bet would be a tiny exhaust valve from a 4-stroke model airplane engine brazed onto the dent site, combined with a slide hammer. That might work. But then you would have to unbraze the valve from the tube when you're done.
Quoted: 1572 Post(s)
Liked 1,745 Times
Has anyone tried to use a stud welder/dent puller on bike tubing?
This is pretty routine in autobody work. You weld a stud to the dent, then pull on it with the puller (or better yet pull on the puller while hammering from the front). After you float the dent out you can cut the brass stud off and sand it flat.
Quoted: 359 Post(s)
Liked 582 Times
Vacuum or otherwise dent removal...
They have a pretty wide skillset and truly unique tools.
How they'd get inside the tubing, no way of knowing.
The least they'd do is look at it and shake their head.
Quoted: 964 Post(s)
Liked 1,451 Times
Braze the tube shut at both ends with a zerk fitting on one end, then pump grease in with a grease gun. Hydraulic dent removal!
Be careful of high-pressure injection injuries...
Back in my youth, I used a grease gun to push the pistons out of stuck brake calipers. Once I built up a ton of pressure and then the piston exploded out, flying across the room and embedding itself in a ceiling joist. Learned something in that moment...
Likes For SpedFast:
SE Wis
Quoted: 2751 Post(s)
Liked 3,407 Times
PBP Ancien (2007)
Bikes: Cannondale CAADX (for commuting), Cannondale CAAD12, Cannondale CAAD12 Team CNCPT, Giant Contend 2
Quoted: 77 Post(s)
Liked 156 Times
Back in the late 90's, I stacked big time in Mallorca whilst descending on hairpin bends and my (then new) road bike* flew through the trees until it hit one leaving a tidy dent in the top tube. Back home in the UK my frame-builder drilled a tiny hole in the opposite side of the top tube, pushed the dent out, filled the hole and touched up the paint.
* Columbus Max tubing, ovalized, lugged BB and fillet brazed elsewhere. Lovely.
