what is the benefit to riding in the drops
Bikes: 2016 giant advanced carbon disc bike ,w HED belgiums,dt swiss 350 hubs,all new ultegra drive train etc
Quoted: 10 Post(s)
I've gotten to really like riding in my drops ,and wanted to see what the consensus was ,being a Clyde n not a clyde
Bikes: Kuota Ksano. Litespeed T5 gravel - brilliant!
I'm mostly on the top but I move to the drops on occasion. I've got relatively long arms so it isn't a question of reaching them comfortably, I just don't like putting that much weight on my wrists for any extended period of time. The exception is descending; I like being in the drops then.
I agree, when descending I go into the drops, it improves the flight characteristics of my aero-belly.
Sometimes when sprinting.
Often I go in on long rides just to mix it up.
Bikes: Steel 1x's
Quoted: 632 Post(s)
I find I'm faster in the drops for the same output. So when I want to be faster/more efficient, I go there.
I do not feel more confident in the drops on descents. My road bike gets a little more twitchy there.
I did notice on my new AWOL that with the flared out drops, I feel much more confident in them. Wondering if I need wider bars or maybe some with flared drops like that on my road bike.
Mad bike riding scientist
Quoted: 6201 Post(s)
Liked 4,204 Times
The second...and more important...reason for using the drops on a downhill is that it drops your center of gravity and makes your braking more effective. That can be very important when you are edging up towards 50 mph. Pulling down on the drops and braking can almost double your deceleration capacity. In a "normal" position, a bike generates about 0.5 g of deceleration (half the deceleration due to gravity, not grams). Moving the CG of the rider down (and back) as in the drops, increases the deceleration to 0.9 g.
That's far more important than any gain you get in aerodynamics.
Stuart Black
Stuart Black
Bikes: 2006 Raleigh Cadent 2.0, 2016 Trek Emonda ALR 6, 2015 Propel Advanced SL 2, 2000 K2 Zed SE
Quoted: 115 Post(s)
If you're looking to be fast then it's good to work on for reasons other than speed, you need more core strength and flexibility to stay in a more aggressive position. Even in the drops your core should be carrying almost all of your weight, not your hands and wrists. That strength carries over to less fatigue on the hoods and less upper body fatigue on really steep climbs.
Being lower and somewhat more stretched out can also make it easier to get big, deep breaths in.
Bikes: Specialized Tarmac SL3, Nishiki Pro Hybrid SL
Quoted: 24 Post(s)
I love riding the in drops personally. I have a somewhat bad back and for whatever reason I feel just as comfortable if not more when in the drops. Plus it's great if there is a good wind as your more aero and efficient. On downhills I almost always stay in the drops. Often up to 10 minutes at a time. When riding in a group I have passed many riders by just getting in a good tuck as they continue to peddle. When the descent is over I'm fresh and ready to peddle hard and I often end up in the front of the train.
I even feel comfortable in the position below. I had one guy tell me I'm crazy for riding downhill like that as I don't have as much control, but I actual feel more firm and stable in that position.
Mainly, you lower the size of the hole you punch through the air, which is a big deal at higher speeds because the effect wind resistance has is exponential with speed. With drop bars in a somewhat aggressive position, at 15mph you probably won't feel much of a difference on flat ground. At 25mph you would really notice it.
In general I agree with you but haven't spent a day in the drops for a very long time.
Bikes: Schwinn Broadway, Specialized Secteur Sport(crashed) Spec. Roubaix Sport, Spec. Crux
Quoted: 179 Post(s)
Liked 167 Times
The drops may or may not make you more aero. Riding the hoods with your elbows bent at 90° might get you just as aero. I have noticed that I naturally have a higher cadence when in the drops. I spend a fair amount of time in the drops these days, just 2 years ago it was an almost never thing. Shrinking belly and improved flexibility have made it more comfortable.
Sir Mark, Knight of Sufferlandria
Quoted: 4792 Post(s)
Liked 3,918 Times
These are most likely to happen when you are drafting someone or when you are tired. One of the statistics no one gathers is what hand positions were being used when crashes happen. I'll bet a lot of routine collarbone fractures might not have happened if that rider was in the drops.
My bikes all have long mile comfort in the drops and when I am setting up a bike, that's the first thing I work to get right on the cockpit setup.
Ben
I wonder if they make Clyde stems? You know ones that can handle our loads perched out like that...?
Just Keep Pedaling
Bikes: 99 Schwinn Mesa GS MTB, 15 Trek Domane 5.9 Dura-Ace, 17 Trek Emonda SL6 Pro & 18 Bianchi Vigorelli
Quoted: 251 Post(s)
Liked 67 Times
I have aero boobs to help make my aero belly more efficient when in the drops.
Serious now I actually ride in the drops often to change positions, get out of the wind and descending. I find I feel more in control when in drops...especially descending.
Quoted: 115 Post(s)
It's interesting learning this stuff for me, I didn't really start riding seriously until I was just about to turn 40. I've been a fan of racing since I was a kid, and trying the different skills out and feeling how they actually do work is fascinating. When I could finally hold a wheel last year on a city limits sign sprint it was all "this is like cheating!"
Quoted: 5223 Post(s)
Liked 3,579 Times
when I wanna hit it, I git down in there, open my lungs and stretch the legs, then it's spiderman time
Quoted: 10 Post(s)
It just seems to me when in fixing to hit a slight incline ,that I can drop down and don't struggle as much as if I was on the hoods . I just drop 1 gear n spin more ,where as if I was on the hoods I'd drop 2or 3 n spin like the Dickens ,
On another note I always drop down on descents but since I'm loosing a lot of belly it just feels better to me .
Plus ...when I get shelled by another rider their always in the drops
got the climbing bug
Bikes: one for everything
Quoted: 632 Post(s)
Liked 908 Times
better power position to the bike geo
easier to hide from the wind or while drafting @ speeds
better braking modulation and cover
better cornering at high speed or sharper angles
bit more aero position w/o putting pressure on my bad shoulder
less use of core muscles vs over the hood since my arms are straighter and taking more of the load
more leverage on the bars when sprinting 40+
because it's comfy
~this is how I set my bike up, you result may vary~
because it's comfy
Rule #10 // It never gets easier, you just go faster.
Catching Smallmouth
Bikes: 1990 Specialized Sirrus Triple, 1985 Trek 460, 2005 Lemond Tourmalet, 1984 Schwinn LeTour 'Luxe, 1988 Trek 400T, 1985 Trek 450, 1997 Lemond Zurich, 1993 Diamond Back Apex, 1988 Schwinn Circuit, 1988 Schwinn Prologue, 1978 Trek TX700, Sannino
Quoted: 88 Post(s)
Liked 134 Times
I probably spend 3/4 or more of my time in the drops. Aerodynamics is what puts me there.
