Geometry is Killing us. Literally at one intersection.
20+mph Commuter
Bikes: Surly LHT, Surly Lowside, a folding bike, and a beater.
Quoted: 1434 Post(s)
Liked 331 Times
For you guys out there, ever find yourself cycling along and notice an attractive woman walking toward you on the sidewalk with a tree between you and her? The tree is so close to the woman that as you cycle at say 15 mph and she walks at 2 mph, the tree will STAY between you and her foiling any chance you might have for a better look. Unless of course you, or she, alter speed.
There is a scientific phenomenon where this occurs with a cyclist (the woman), a car (the man), and the front pillar post of the vehicle (the tree). Only instead of resulting in frustration it often ends in tragedy.
If you like geometry, and want to learn how to avoid crushing or getting crushed at an intersection with clear lines of sight, then this is for you. Enjoy
Collision Course: Why This Type Of Road Junction Will Keep Killing Cyclists
» Collision Course: Why This Type Of Road Junction Will Keep Killing Cyclists
Bikes: 2010 Trek 7100
Quoted: 697 Post(s)
20+mph Commuter
Liked 331 Times
Funny. Tree is solid. Woman is spied far up the road briefly, then disappears behind the tree forever. Even though both people keep moving at a steady rate of speed the woman and the tree remain in "eclipse".
Quoted: 4399 Post(s)
Liked 1,556 Times
This is a problem for pedestrians as well - I see it all the time.
That said, I am now firmly anti-geometry.
I am also against molecules.
There are many decent roadway design guidelines available.
All of them specify having intersections meeting at 90°, flat, level w/ unobstructed view. As any of those deviate from that ideal, then other changes are required to maintain safety, such as decreasing speed or adding stop signs.
The linked, unimplemented modification is okay, but a better solution would be to have modified both minor roads so that both met the major roadway at 90°, with the added benefit of being offset, to ensure the vehicles on the minor road come to a stop.
Too much math but a good looking woman is hard to beat
Quoted: 5781 Post(s)
Liked 2,577 Times
This is an important and worthwhile article for anyone wanting to improve his own safety on the road. I strongly recommend that people read the original in it's entirety.
While the car's pillar is a factor, these collisions also happen at sea where there's no visual obstruction.
The reality is that humans are not good at calculating the vectors involved and predicting the future positions of themselves and crossing objects. When the speeds and angles are right a crossing object will appear to stay in the same place (angle in the field of vision) and so it's very easy to underestimate it's speed (it's not moving at all, right?) and not be aware if the risk of collision.
When you and a car are approaching an intersection at right angles, odds are that you'll under estimate it's speed, but much more important is that the driver will greatly under estimate yours, so neither of you won't make the adjustment to avoid collision.
There's not much anyone can do about this, but awareness will ensure that at least one party (you) will make the necessary adjustment, or at least be prepared to if the other party doens't do so first.
FB
Chain-L site
FB
Chain-L site
What about gravity? Not only is it a good idea, it's the law!
Kidding aside, it was a very interesting article. I would surmise the strange angle is somewhat of a fluke which made this particular phenomenon particularly prevalent there. Seems it would be a simple and relatively inexpensive fix.
Liked 2,577 Times
As an example, I was sailing on a large schooner, and we were slowly passing another sailboat that seemed to be on a parallel course. Turns out it wasn't and both crews were watching a collision in slow motion until it became obvious and we altered course at the last minute.
FB
Chain-L site
FB
Chain-L site
Non omnino gravis
Quoted: 18375 Post(s)
Liked 4,510 Times
Oh, I can imagine the return of the bubble shaped Pacer.
Perhaps a little more work to reduce the pillars. There are quite a few cars with frameless windows on the doors, but still have the main pillars.
That is one thing I dislike about Mom's Prius, really bad rear visibility
Liked 2,577 Times
Intersection accidents are usually the result of 3 incorrect assumptions.
1- I've correctly estimated the speed and position of the approaching vehicle.
2- the approaching driver has correctly estimated my course and speed
3- I have the right of way and the crossing driver will recognize that and yield
We can blame intersection design, but the fault is human, not technical. I'm sure that I'm not the only one who's come to an intersection where the crossing driver is dutifully stopped at a stop sign. Then at the last, and most inconvenient moment has decided it was a good time to proceed.
Stay alive by being ready to react not only to what drivers should do, but what they might do.
FB
Chain-L site
FB
Chain-L site
Liked 2,577 Times
While drivers were at fault here, the bicyclists contributed by relying on false assumptions about what those drivers were going to do.
FB
Chain-L site
FB
Chain-L site
Liked 2,577 Times
Assumption no.3 in my post immediately above yours.
FB
Chain-L site
FB
Chain-L site
Quoted: 4806 Post(s)
Liked 3,928 Times
I should point out that the crash in the scenario Joey is using as an example is different; it wll lead to a single vehicle crash. Cyclist will veer toward the right as he focuses all his attention to the right hoping to see that woman. This rightward veer will take him into the tree. Woman walks past unharmed.
Ben
Liked 4,510 Times
It's a shame that the article focused so much on the main pillar. Has it occurred to anyone here that bicycles don't have these pillars?
A basic rule of driving is to assume all the other drivers are going to do something entirely stupid. So, for example, when sitting at a stop sign, you see a car signalling a right turn. One should assume they're not going to turn until it is proven otherwise.
So, there are two cases...
- Car never stopped, and blew the stop sign. Cyclist had right-of-way, not stop. The cyclist SHOULD have seen the car approaching and not stopping, and should have simply stopped and yielded to the car.
However, that does require a little extra attention on the part of the cyclist. Perhaps an accident can be avoided 99 out of 100 times, but there is always that 1/100 time. - Car did a quick stop & go stop. These are the least predictable. Car appears to be stopped, but when one gets right in front of them, they start moving again.
Fortunately these stop and go stops are the least lethal as speeds are often reduced, and both parties often note their error and take evasive actions before an accident occurs. This may also be the reason why the first cyclist in the article was spared serious injury.
I'm not sure the staggered intersection favored by the author is the answer. I find them to be quite annoying. Yes, they should slow traffic, and that might be worthwhile considering. Although, for a cyclist, it often means merging onto a busier street for a block or so.
I hit this one a few times a year.
Ok, similar, but slightly different from what the author is proposing. The main road (219) goes through a jog without stops, and the side road merges onto the main road, then off again. Somewhat odd for a block for the cyclists on back roads thrown onto a busy road for a block, then back onto the back roads (Willamette Valley Scenic Bikeway). Does it reduce the forward view of the cars going through the jog at speed?
As I frequently cut a diagonal course through Springfield, I have wondered about one stop sign that it can be easier to take a right onto the main street, cut over to the center turn lane, and left back onto the next residential street, rather than trying to cross two lanes of busy traffic on the one street.
Riding Eastbound on F street, right on 14th, then left on E street can be easier than going straight through eastbound on E with a stop at 14. I think there is a bike lane on 14th, so the right onto 14th is somewhat protected, and again the left onto E is from a center turn lane, so one has a whole block to choose the best place to cut left.
https://www.google.com/maps/@44.0504...9955297,16.23z
Further Eastward, 21 & E, there is a funky jog in the street. Usually not a problem, but the short jog tends to encourage a diagonal across the streets, and perhaps not as safe as going straight across.
For the intersection in the article, another option would be to add a 4-way stop, perhaps with big red flashing lights in all directions. And, enforce drivers actually stopping.
