Continental Terra Speed and Terra Trail
#51
Funny that Conti puts arrow on the TS, but not the GP5K that has directional-ish "tread" does not.
Mounted the Conti TS "40c" tires on 24mm internal rims, which is about as big as they get here; they measure 39mm. These are 38c tires at best, 37c would be most accurate. These are a full size down from 40c, it's visually obvious. That few mm might not seem like a big deal, but that the difference between carving through some surfaces and floating over it.
#52
Gravel Rocks
The only thing I can figure is maybe Continental calls them 40mm because they flatten out more at the contact point making them perform like a 40mm tire, although I haven't seen anything that supports that.
#53
Bikes: SuperSix Evo | Revolt
Quoted: 733 Post(s)
Liked 815 Times
#54
Quoted: 14 Post(s)
Two things: Firstly, these Terra Speeds are 39mm on 22mm ID rims. Too small. Conti messed up, but it's a good start because I've got 50 miles on mine and they are otherwise nice tires. They should make a set in the range of 42-44mm's which is what the vast majority of us would be using. Hopefully, that's coming.
Secondly, as far as the directional arrow, it could be related to the tread pattern or to the casing layup. Trek did research on the directionality of casing layup and how it affects rolling resistance. https://blog.trekbikes.com/en/2019/0...-and-training/
#55
Directional casing (as it relates to rolling resistance) is nonsense. I think they meant it is rotated relative to the tire (think latitude/longitude) not to tire spin direction. I did see something interesting... tread splice. There's an overlap of the rubber built into the rubber (and I assume other bits); you want it to tighten, not loosen.
#56
Quoted: 1872 Post(s)
Liked 692 Times
I think they're awesome. They did great at The Mid South, I finished with no tire issues. Enough grip in the mud and narrow enough to not build up. And they're supple enough to feel like 42s on the hard pack. I love this tire.
2019 Salsa Warbird
2019 Salsa Warbird
#57
Mine at 40 psi with less than 20 miles on GRX wheels (21mm internal if i recall?) close enough to spec for me.
Can't wait to start logging some miles soon, I have enjoyed so far.
Likes For GravelGurty:
#58
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
Sometimes they under size tires save weight making them seem lighter than comparable tires (that might actually be 42mm). It also allows them to be compatible with more frames. Doesn't bother me, as long as I know it before buying them!
Likes For chas58:
#59
Quoted: 733 Post(s)
Liked 815 Times
Don't care if they're a mil or two under spec, they're fast and grip well, works for me. FWIW, my Terra Trails measure a bit wider, just a hair under 40mm. But the Speeds will be my goto from now on.
#60
Liked 415 Times
Awright, I bit the bullet...
These things "roll fast" although I'm not sure I can feel the 3-4 watts difference in resistance compared to any other high end tire gravel tire. Not as swift as the GP5000 obviously (8 watts vs 22 watts).
Its dynamic performance does impress me.
I would not call the ride "supple" (although you could). What surprises me is not how soft it is, but how well damped the ride is. Putting a pair of these on is like going from an aluminum bike to a steel bike. I still feel the road, but the vibrations are very well damped. Its not so much a "twang" but more a "thump".
Its even more noticeable riding on a freshly graded road (with class 5 gravel chunks). It just smooths out the chunky ride. For grins, I've been riding at 70psi rear, and it feels as harsh as a 25 psi tire. Crazy.
The other thing that surprises me is the handling. Even at 30psi on the road, it is responsive, and carves a very nice turn with plenty of traction and no slippage or walking from the knobs. Yet off road it handles like a good gravel tire. Its very well rounded.
The vibration dampening and the consistent performance across multiple surfaces are impressive.
Yeah, they are labeled 40mm, but are 38mm. They are 2mm smaller than 40mm Ramblers or G-Ones. They are the same size as 38mm Ramblers.
Mounted up much, much easier than the 32mm GP5000 (which did not like my rims and took 2 professionals 30 minutes to mount). Work either hookless or hooked (unlike the GP5000). I road them for a couple of days before I got around to putting sealant in them. Held air nicely.
#61
The tests have different parameters and used different equipment. The 8w gp5k was at 120psi TL in one test and the 22psi was at 50psi tubes in another. At 60psi in that same test was closer to 12w on the GP5k. To roughly bridge the data, you need to look at BRR’s test of the One v-guard which was at 14w in BRRs test and 17w in the other - putting our GP5K at 15w. Now you need to take the tube out of the Terra Speed which is about 1w. Apples to apples, you’re looking at 6w disadvantage to the gravel tire rolling. Aero drag, you’re looking at about 15w at 25mph (1.5mph)
2) the reason it ride the same is that you’re stretching the crap out of the sidewall.
#62
Liked 415 Times
1) you’re not reading the test right/you’re commingling data that can’t be directly commingled.
Speed wise, my terraspeeds roll similar to my Gatorskins, which isn't too far off from my rambler in real world usage. The GP5000 is in a different league. I dunno, we can argue fine points all day if we are bored, but my impressions stand. Your impressions may be different.
#63
Gravel Rocks
#64
Liked 692 Times
2019 Salsa Warbird
2019 Salsa Warbird
#65
Prodigal Son
Bikes: Cervelo R3, Cannondale CAAD10, Brompton
What are people's experience with removing the tires? Is it hard to break the bead?
It was tortuous to remove WTBs from my wheels. Made me realize that taking the tires off is actually a really important thing to consider
#66
Gravel Rocks
It's very much going to depend on the rimset you put them on and your taping of the rim. Enve G23s it's not as easy as a road tube type tire, but it's certainly not tortuous, but i haven't had any real issues getting WTB Nano's off of these wheels either so perhaps not helpful in your question.
#67
Quoted: 733 Post(s)
Liked 815 Times
I'll never run a tire/wheel combo that I can't work on alone when out on the trail/road.
#68
Liked 415 Times
I'm realizing that a lot of the "tire" problems people complain about are really rim problems. There is a significant difference between my hookless carbon rims, and my Aluminum DT rims. Granted, back in the day with traditional tires, the tire/rim interface wasn't such a PITA.
#69
Anyone have the 35mm Terra Speed? I'm wondering how they measure up once mounted. I probably won't go for it if it comes in at 33mm the way the 40mm mounts a little narrower.
So do these mount easy on hookless rims?
#70
Liked 415 Times
The 40mm version mounted fine hookless, unlike the GP5000 which was a friggen nightmare. If you want 35mm, what's wrong with the 40mm (which measures 38)?
#71
Liked 692 Times
My buddy has the 35mm version and they're something like 33-34mm measured. My 40mm are now 40mm measured after some miles. But they aren't very durable. This dry Summer heat has made the roads a little harsher and I counted no less than 19 pinholes in my rear tire yesterday. Nothing catastrophic yet though.
2019 Salsa Warbird
2019 Salsa Warbird
Likes For shoota:
#72
What wheels does your buddy have these mounted on (what inner width)?
#73
Liked 692 Times
I think they're about 19mm ID. Basically, these tires are never going to balloon way out past their listed width.
2019 Salsa Warbird
2019 Salsa Warbird
Likes For shoota:
Likes For chas58:
#75
I ride a first gen Diverge carbon. 35-36mm is the limit if you want to preserve mud clearance. It's amazing how much tire clearance has exploded since not that long ago.
