I stripped the CRAP out of my Chain ring bolts....
King Hoternot
Bikes: 2015 Cannondale Evo Hi mod
Quoted: 127 Post(s)
FSA SLK crankset. Swapping out stock for praxis works chainrings. front FSA bolts are a t30 and the rear is a 6mm. I got 3 of them out easily but 2 of them buggers are really stuck in there and now that I have stripped both the T30 AND the opposite 6mm, they are REALLY in there.
WTF do I do now?
WTF do I do now?
WTF do I do now?
WTF do I do now?
Quoted: 5773 Post(s)
Liked 2,569 Times
I assume you're talking about typical chainring nut and bolt pairs. If so the easiest way is to use a countersink (you need a power drill) from the back. As the countersink enters, it separates the back flange from the nut and the bolt pushes through.
Buy a new set of 5 and you'll be good to go. The nut should be dry where it meets the chainring (helps prevent spinning) and the screw greased.
FB
Chain-L site
FB
Chain-L site
Quoted: 2026 Post(s)
Liked 1,096 Times
I've used an ovesize standard drill bit to do the same thing. Use a bit large enough to overlap the original hole and drill just deep enough to separate the flange (or bolt head) from the nut (or bolt shank). I've never had to remove chainring bolts this way but I have safely removed clipless pedal cleats from shoes where the bolts' 4 mm recesses are too damaged to fit a hex key.
