Why does everybody tell me i need to ditch my steel frame?
I'm planning to do some moderate touring with my old steel frame Raleigh Compettion and everyone is telling me i should have a lighter frame for going long distances.
I really dont see the advantage of having a lighter frame that bounces 5 feet into the air every time i hit a little bump. Heavier steel frame bikes can absorb the road a little better and seem to just stick to the road better
Am i wrong? My goal is not to break any records on travelling distances so Im beginning to think that lighter frame lovers are just buying into the fact that carbon frames are lighter newer and cost more so they are way better then older steel frames.
Im by no means a pro cyclist and Im actually kind of new to cycling so I would like to hear your opinions as to why you like a steel frame or lighter carbon frame is a better choice.
Quoted: 821 Post(s)
Liked 258 Times
Steel is just fine.
I'd worry about tires, a good saddle, and frame fit/individual fitness before I'd get worked up/worried over frame materials.
I rode this to our cabin and back this summer.
Three of us made the trip.
Round trip distance?
500+ miles.
500+ miles.
CL Addict
Bikes: '50s Leon Cattrysse - late 50s Raleigh Lenton Sports - 1960/61 Raleigh Lenton Grand Prix - '72 Canadian Tire Company Supercycle - '74 Raleigh International - '83 Nishiki Cresta - '84 Centurion Turbo - '86 v. Herwerden (Chesini) - '87 Specialized Sirr
Quoted: 85 Post(s)
Liked 96 Times
You know we're going to say 'Don't listen to THEM!'
Who's everybody anyway?
Btw - PICTURES please...
worst case scenario, your steel frame is 2lbs heavier. likely less than 1lb heavier though. i think that's the least of your worries.
Half way there
Bikes: 69 Hercules, 73 Raleigh Sports, 74 Raliegh Competition, 78 Nishiki Professional, 79 Nishiki International, 83 Colnago Super, 83 Viner Junior
Lighter? When you add the weight of the stuff you have to carry for touring, the weight penalty of steel is insignificant. Also, it's amusing to hear comments about saving a pound on a bike, when the person making the comment has 20+ extra around the waist.
If your bike fits and you are comfortable with it, by all means use it. BTW, I have a '74 Raleigh Competition and can say that it is certainly a nice riding bike.
-gmt
-gmt
Señor Member
Bikes: Bedford, IF, Hampsten, DeSalvo, Intense Carbine 27.5, Raleigh Sports, Bianchi C.u.S.S, Soma DC Disc, Bill Boston Tandem
I've found that the only weight that actually makes a difference is in the wheels.
I love seeing a weight weenie on a 16lb carbon bike where he meticulously and expensively shaved every gram possible, carrying two frame mounted water bottles weighing over a pound each...
Quoted: 659 Post(s)
Liked 7 Times
I agree with the comments above that an extra pound or two on a touring bike is insignificant and also wonder who the "everybody" is since many (most?) current bicycle tourers are still using steel frames and avoid much of the lightest equipment due to concerns about reliability. Your Competition should perform fine as a touring bike.
But I disagree with the idea that a lighter bike would be bouncing up into the air on bumps. In car racing it's very desirable to minimize 'unsprung weight' specifically because this allows the tires to maintain more consistent road contact. On a road bike the main suspension component is the rider and the whole weight of the bike is essentially unsprung weight. Reducing this weight relative to the rider's own weight actually makes it slightly easier to maintain control and avoid having the bike bounce into the air upon hitting bumps. But if you're on such bad terrain that this is a common problem then I'd suggest switching to a mountain bike with at least front suspension.
Wrench Savant
I think someone said "It is not about the bike."
If what you have works (safely), and you like it, who cares? Unless you are racing at a high level (Cat 2+), it does not matter.
Old fart
Quoted: 3616 Post(s)
Liked 3,446 Times
Bikes: Surly Trucker
For touring especially, you SHOULDN'T be straying away from steel. All the above information is also correct.
nans, Nothing wrong with what you have. Maybe an overhaul to freshen up the bits and bobs and some consideration to your gearing, which mainly relies on how much you'll carry and the terrain to be traveled.
Brad
Brad
Quoted: 821 Post(s)
Liked 258 Times
The reason I don't build a full on tourer is the simple fact I don't like riding fully loaded rigs.
Nor do I like over built touring rigs w/o a load, as they quite often ride like tanks.
At least my Bruce Gordon was great off-road, so it had some redeeming "added" value in that regard.
The Hollands I have above is made from Columbus EL and is fairly light, yet super comfortable.
None of us on our ride brought tents, cooking gear, sleeping bags, or other "stuff."
Rain gear and our wive's credit cards were essential though.
I am losing weight through riding and fewer BBQ ribs.
Not by buying weight weenie super bikes.
Bikes: 1983 Trek 600 / 1984 Schwinn Peloton
Are you talking about the Raleigh Competition GS ? Pardon my ignorance but I thought they were racing bikes, when I think touring, I was thinking Trek 720 and similar. What are the Raleigh Touring or Sport-Touring bikes?
Location: Rhode Island (an obscure suburb of Connecticut)
Bikes: one of each
Quoted: 8 Post(s)
Liked 12 Times
One item I'd look at on a Competition frame in particular is the derailler hanger. Mine have Huret specific hangers. If the Huret is good enough for you, that's fine but I like a little more range than they were built for because I live in the hills. It's not an insurmountable problem, in fact it's a small one but one to be aware of.
Also check that it's got 24 TPI bottom bracket threading. Most of them do but there are a few that have 26 TPI. That's another problem for which there are several easy solutions.
Beyond that, I'd take a Comp over just about any other bike except maybe my Super Course. It's not about the weight except when you're accelerating or hill climbing. It's about the feel of the thing. Nothing feels better than a 531 Raleigh.
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
I was looking at https://sheldonbrown.com/retroraleigh...mpetition.html, supposed to be pretty comfortable and not all that heavy.
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 541 Post(s)
Liked 1,042 Times
People were telling me I should get rid of my old steel bike, so I bought a new steel bike.
https://www.jamisbikes.com/usa/thebik.../11_quest.html
Hogosha Sekai
Bikes: Leader 725, Centurion Turbo, Scwhinn Peloton, Schwinn Premis, GT Tequesta, Bridgestone CB-2,72' Centurion Lemans, 72 Raleigh Competition
Quoted: 70 Post(s)
Liked 21 Times
Steel is sexy, especially a Raleigh Comp! I rock a Super Course as one of my "lighter" bikes and I have no issues going all day...
Quoted: 1869 Post(s)
Liked 666 Times
If you're doing lighter day or credit-card tours, I'd even recommend you stay with the tubulars if all is in good condition. But if you're going to carry heavier loads, consider that a set of 36-hole clincher wheels might be more sturdy.
So: frame no issue, but make sure the rest of the equipment is up to the job.
Same as setting up for a tour with any other bike.
Bicycle Repair Man !!!
Beat me to it...
The preferred material for touring bikes is still steel and I do not see this changing any time soon... and in this I am talking about real touring bikes that are expected to carry some weight besides a credit card and a few water bottles.
The Competition is a beautiful bicycle... we will need pictures.
Bikes: Monark sportser 1970, Monark sportser 1970ish, Monark folder, Mustand 1985, Monark Tempo 1999, Monark 318 1975, Crescent 319 1979, Crescent 325 c:a 1965, Crescent Starren 2002 (hybrid/sport), Nordstjernan 1960`s cruiser.
Comfort beats weight anyday. If longer touring is your game wheels (rims,tyres) is significant. And as always, a saddle a la carte!
Bikes: Casati, Look, Torelli, Ridley, and a bunch of steel bikes from the 80s and the 90s..
Quoted: 11 Post(s)
That's funny. I remember when I was about 16 sitting on the grass at the start line waiting for my race to start with my Puch, a Senior III rider said, look that Medici there, it is the best touring bike ever made. Not a Raleigh.
Nans,
Haven't you learn by now, everyone has to have something to say when they only know just a little about the subject.
Nans,
Quoted: 3026 Post(s)
Liked 3,902 Times
