Replacing Fork
Replacing Fork
Is it possible to replace a fork to go from suspension to rigid.
The fork we have can have the suspension locked out but I was wondering if it would it just be simpler to replace the thing?
Or thoughts on replacing both the fork and the brakes is why we were also considering a new or different bike.
Likes For Happy Feet:
Quoted: 1943 Post(s)
Liked 2,164 Times
If you like bike, you can replace the suspension fork with a rigid fork. But as Happy Feet stated, it would be good to know what bike you are swapping and where you plan to ride it.
If it is going to be used for paved surfaces, you don’t want to get a fork where ATC is too long as will slacken the head angle and might slow the steering too much.
I have found that it is less of an issue, but it depends on the bike, on trails.
John
John
At this point, does it really matter which model? It's an aluminum TREK something or other. The head set bearings are internal to the large diameter head tube.
Where do I go to review the replacement fork offerings for geometry and price?
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Maybe you should try, oh...I don't know, something like Google? You enter what you're looking for and it comes up w/ thousands of answers in a fraction of a second. Really quite amazing.
Likes For cxwrench:
Quoted: 3234 Post(s)
Liked 2,079 Times
FWIW, you want to determine the wheel size - 700C, 650B, 26" ?. Then the headset type - tapered ?, not ?, then decide on a carbon or steel.
Soma makes a bunch of steel forks for assorted bike wheels and systems, also look at Universal Cycles.
Bikes: Historical: Schwinn Speedster; Schwinn Collegiate; 1981 Ross Gran Tour; 1981 Dawes Atlantis; 1991 Specialized Rockhopper. Current: 1987 Ritchey Ultra; 1987 Centurion Ironman Dave Scott Master; 1992 Specialized Stumpjumper FS
Quoted: 209 Post(s)
Liked 178 Times
1993 StumpJumper FS. I went on a tour and wanted front panniers, and no one back in the 1990s was quite sure if you could slap panniers on a shock. So I got an old rigid fork from the LBS, off a GT. I switched back to the FS for a while, but once the seals failed and it needed maintenance, I put the rigid back on. I find I don't miss it much.
Thing is, I don't know that this bike was necessarily designed for the shock, or if they just slapped it on that year's regular model. Either way, I got used to it.
So, yeah, it can be done, not a big deal, to my mind.
Clark W. Griswold
Quoted: 4347 Post(s)
Liked 3,984 Times
If you truly want help, you can't just sit there and act combative when people ask for important info. People who come in and just act nasty for no good reason don't need to be here, be nice, be kind and be helpful to us so we can be helpful to you.
Bikes: Too many to list
Quoted: 1765 Post(s)
Liked 1,124 Times
this would limit you from putting on a generic rigid replacement. There may be some satisfaction out there with a smaller shop like Somafab.com. They sell replacement forks for a lot of applications
between this and the brakes, it doesnt seem like that Trek is being very good to you
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
Quoted: 1607 Post(s)
Liked 2,586 Times
Quoted: 5224 Post(s)
Liked 3,581 Times
simpler? ride what you got
Randomhead
Liked 3,694 Times
I have a Trek something or other and I'm in the process of replacing the fork with a Salsa suspension corrected fork. The original fork was really a bad 100mm travel suspension fork that is now being recycled into something else. It's easier to do this if the travel of the suspension fork is minimal like mine was.
Bikes: lots
Liked 2,932 Times
Gimme a break, he specifically asked where to look for options. I gave a reasonable answer and a couple of members even liked it.
ETA: And it was over a month and a half ago...
