can't rise HR above 92%HRm
You mean to use 92% of max 20 mins avg power?
(273 is my FTP, not 20mins avg power).
anyway, thanks for help and clarification, I'll just stick to power 105-120%FTP during VO2max, maybe with a hard start (first 30sec)
just another gosling
Quoted: 3889 Post(s)
Liked 1,938 Times
Seems to me that one of the reasons we use power for intervals is so we don't vary the power during the interval. If the first one seems too easy, increase power on the second one, etc., until it's quite difficult to hold that steady power the whole way. I usually find the first one quite difficult and the second easier and then succeeding ones have ascending difficulty, all done at the same power. If the last one is not super hard, I'll increase the power next time or on the next set if there's another one. The 120% or whatever is just a rough guide for the first one. Exact FTP may not have a whole lot to do with it, depending on the interval length. One's aerobic and anaerobic abilities may not be that tightly linked. Just my experience.
Results matter
Results matter
Newbie racer
Bikes: Propel, red is faster
Quoted: 1575 Post(s)
Liked 1,569 Times
So no, 273 isn't your ftp. It's simply an estimate of ftp off of the 20min you spent, based on how your posts reads. There is NOTHING wrong with that. It's just a convenience of choosing to do it a certain way. 273 is your ftp if you went out and did it for an hour. Did you? Your post above clearly says 20min.
The more honest you are with yourself about this % cut from 20min the better your workouts will go.
yes, my 20 mins avg max power = 288W
and it's used for FTP estimation: 288*.95=273
My question was: do you use 92% from my FTP estimation (as you did 273*92% calculation...), or from my max avg 20min power.
Newbie racer
Liked 1,569 Times
I did 95% for years and would bang my head against the wall in terms of not gaining what I thought I should and also failing workouts.
I started doing 92% of 20min or since I am a TT nut case doing a 40k and using that for the hour power. That's worked out a lot better for me. Just that 3% mattered that much. 3% matters a lot when you're hurting on the limit in those intervals.
I started being able to hold the power for the workouts better.
I've heard of some folks doing the whole "critical power" style setting workouts also. Like, keep track of your most recent PR's in Trainingpeaks and then do your shorter length sets by the power of the next longest duration PR. Like, do your sets of 3x3min at your 8min all out PR. Or do your 2x20 at power from an actual 40k. Or do your 3x9min at your 20min PR. I may have the term wrong for "critical power", but do know some folks do that. They don't "retest" at that stuff, it's the PR's from just riding in the most recent 3 month block or whatever.
