Help with converting a 3x to a 1x
my bike is a 3x9 XC bike, but I only use the one chainring, instead of all three. it is a shimano groupset, and I'm wondering what size cassette will be able to fit on my hub. I've looked around and someone said that a 1x11 will fit, but I just want to confirm that. any help is greatly appreciated, thank you!
Bikes: Soma Pescadero, Surly Pugsley, Salsa Fargo, Schwinn Klunker, Gravity SS 27.5, Monocog 29er
Quoted: 186 Post(s)
Liked 234 Times
You don't have to change anything on the rear.
Likes For c_m_shooter:
Quoted: 590 Post(s)
Liked 445 Times
When in doubt, just replace the cassette (or any piece of equipment for that matter) with the exact same one, to avoid any incompatibility issues between 8,9,10,11,12 speed equipment. And it's common to replace your chain (in this case 9 speed) when you do get a new cassette (in this case 9 speed).
Likes For prj71:
You can go all the way to 12 speed if you want. What you can't do is run any cassette that starts with a 10 tooth gear but 11-whatever mountain bike cassettes aren't a problem.
