Peugeot PSN 10
Bikes: Peugeot PSN 10 Mont-Cenis, Specialized Tarmac Disc Pro Di2 Carbon, Specialized Allez Compact, Specialized Diverge Comp Carbon, Specialized StumpJumper FSR 27.5 Alloy
As I said not to sure as to the exact date of my bike 1985, 1986, 1987 ( see earlier post in this thread), but the 1987 catalog picture and components list is what is on the bike I've got
Le savonnier
Bikes: I can count 'em on one hand
Quoted: 729 Post(s)
Liked 602 Times
Fortunately I had a NOS Stronglight BB with a Swiss fixed cup and a 120mm spindle. Also figured out the reason for 118mm vs 120mm wide Stronglight spindles... The 120mm spindles were for bikes with 126mm wide dropouts. They correct the chain line for 6 speed FWs! 118mm spindles were for 120mm wide dropouts...
verktyg
Quoted: 1036 Post(s)
Liked 1,238 Times
French Hub/Dropout Width Standards
So Chas, based on this info: my 1972 PX10 has a 118mm Stronglight spindle, and 123mm dropouts, but I am having them spread to 126mm. Should I be replacing my BB with a 120mm spindle? Glad I caught this info!
Front - 96mm OLN (Over Lock Nut)
Rear - 122mm OLN (5 speed)
118mm -120mm = 2mm = 0.079" or about 5/64" (less than 1/8")
Hold your fingers 1/8" apart and look between them!
In general. that is an insignificant amount but... a 120mm wide spindle may be a better choice, not because of any chain line hoodoo but because as crank arms are removed and re-seated, they fit further onto the spindle.
I put this Flickr album together one night about 10 years ago when I was building up a SS beater. It needs to be updated but check out the photos and click on any that look interesting. Scroll down to read my notes below the pictures.
https://www.flickr.com/photos/282672...57627678462359
One last point, when you have the rear triangle spread make sure the offset is equal side to side and most importantly the dropouts are parallel up and down, front to rear. Any ham fisted hammer smith can spread the dropouts but can they make sure the frame is properly aligned???
My best bike tool investment from back in 1975 - Campy Dropout Alignment Tools:
verktyg
Chas. ;-)
Chas. ;-)
Likes For verktyg:
Le savonnier
Quoted: 729 Post(s)
Liked 602 Times
Quoted: 656 Post(s)
Liked 469 Times
My PSN10 is my beater with a healthy rattle can layer to protect against the elements. I continue to be thrilled with the ride quality of the Super Vitus frame.
