First bike build help!
Old 06-15-21, 09:01 PM
Rtmackeil
Hey All,
this is my first post. I recently bought a Peugeot St. Laurent in hopes of learning the ins and outs of bike mechanics. I intend to pull it all apart, clean and reuse (what’s worth reusing) crank and headset bearings.
I would like to update the shifters (currently original thumb shifter), cassette (currently 3x6 would like to maybe go 3x8?), and derailleurs to some more modern and smoother operating components.
I am intimidated by picking new components and making sure they are all compatible (I will likely need a new chain too).
Any advice on choosing components that will be compatible with each other? Also can I just take off the old cassette and put in a newer one with more gears without getting a whole new hub/free wheel assembly?
thanks I’m advance! I will try to take some pictures soon to make this process a little more gratifying for everyone involved (including myself)
Ross
Rtmackeil is offline
Old 06-15-21, 09:08 PM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 4206 Post(s)
Liked 3,870 Times in 2,314 Posts
One of the early steps will be to discover all the interfacing dimensions that the new parts need to fit with. Tubing diameters, BB shell specs, rear drop out spread, Brake reach and mounting bolt/nut options. Seat post and stem specs. Rear der hanger tab specs.
Your Peugeot might have common English/ISO based fittings. Or be old enough to still have been French dimensions. Knowing which and what the specs are will go a long ways to reduce buying twice (after the first assumptions prove wrong) Andy
AndrewRStewart
Andrew R Stewart is online now
Likes For Andrew R Stewart:
Old 06-15-21, 09:34 PM
Rtmackeil
How do I go about getting these measurements? Calipers?
Old 06-15-21, 10:09 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds. 2019 Giant Explore E+3
Quoted: 1795 Post(s)
Liked 1,269 Times in 876 Posts
Look at the fixed cup of the BB.
French is 35mm x 1mm and RH threading.
BSA is 1.375" x 24 TPI and is LH threaded.
IF French, it can be a real PITA can of worms with the odd threading. Else, it's a can of worms converting a 6 speed Free Wheel to an 8 speed Free Hub.
You have to cold set the stays for the increased width of the hub amongst others.
Freewheel or Cassette?
Best to look for an early 90's bike with the proper spacing.
Bill Kapaun is offline
Likes For Bill Kapaun:
Old 06-16-21, 03:10 AM
Geepig
Geepig's Avatar
Quoted: 194 Post(s)
Liked 204 Times in 151 Posts
The first task is to take pictures of everything, then remove all the minor items and then begin to work toward the more difficult ones. This not only helps build confidence but also gives you a bit of time to notice stuff that we can often miss in the glow of a new purchase. I have rebuilt many bikes, but I am still surprised - only last week I discovered that some cranks do not need a puller, just a suitably sized bolt from my local DIY store. Anyway, the more that you remove, the easier it can be to work on.
Geepig is offline
Old 06-16-21, 03:17 AM
Rtmackeil
sounds like a great start, thanks for the advice!
Likes For Rtmackeil:
Old 06-16-21, 11:04 AM
2old
Quoted: 883 Post(s)
Liked 823 Times in 622 Posts
Also, don't be surprised if some of the parts like headsets, bottom brackets (who knows) are reusable with a little cleaning/polishing and grease. I just put together a 1984 Schwinn for my granddaughter and was able to use every metal part from the original bike.
2old is offline
Likes For 2old:
Old 06-16-21, 01:51 PM
SJX426
SJX426's Avatar
Quoted: 1608 Post(s)
Liked 2,216 Times in 1,103 Posts
@Rtmackeil - So you have a 6x3? So your rear hub is likely a freewheel. Can you go to 8? Well yes but it is not advised as 8V rear freewheel configurations tend to bend axles. This implies a new rear hub or wheel. Then there is the issue of the spread between the drop outs. 6 V typically is 120 8speed needs 130. You can spread the frame but.... Do a google search on that topic.
8V chains are readily available. You should check that your chain rings will work, likely.
Picking an RD must include if it will span the the number of sprockets and will work with the largest you want.
Bottom line is that a lot of research and decision need to be make, including where are you going with this and to what benefit.
SJX426 is offline
Old 06-16-21, 02:01 PM
icemilkcoffee
icemilkcoffee's Avatar
Quoted: 1562 Post(s)
Liked 1,734 Times in 974 Posts
120mm was for 5 speed freewheels and occasionally 6 speed 'Ultra' freewheels (it's a 6sp freewheel designed to fit in the same space as a 5sp freewheel). Regular 6 speed freewheels typically went with 126mm drop outs. If the freewheel is a british threaded spin-on, you can replace it with a modern 7 speed freewheel with HG style cogs. If it's a Maillard type then you are out of luck.
But to the OP, the best way to learn about older bikes, is to read Sheldon Brown's website end to end:
https://www.sheldonbrown.com/
icemilkcoffee is offline
Old 06-16-21, 02:05 PM
Rtmackeil
Your bottom line statement is valid, it may be that I end up just keeping it a 3x6. I see now to go 8 would be a little more involved than I care to go. As long as it shifts well and can handle the incredible amount of torque I’ll be putting on it 😏
Old 06-16-21, 02:12 PM
Rtmackeil
Awesome! The external resource is much appreciated. I hadn’t realized all the nuances of different part sizes between makes/countries. It’s amazing how much I’ve already learned without yet getting my hands too dirty!
What a wonderful community this is, all the help and suggestions are much appreciated!
Old 06-16-21, 02:52 PM
alcjphil
alcjphil's Avatar
Quoted: 1819 Post(s)
Liked 1,694 Times in 975 Posts
It is very likely that your Peugeot was built in Canada
alcjphil is offline
Old 06-17-21, 10:45 AM
Ironfish653
Dirty Heathen
Ironfish653's Avatar
Quoted: 889 Post(s)
Liked 906 Times in 534 Posts
It looks like your Pug is an early 80's style 'ATB', so it's likely to have a lot of BSA/ISO standard parts, rather than the more isoteric French stuff. Depending on what kind of shape it's in, many of the ' greasy parts' like the BB, headset and even wheel hubs can be cleaned, repacked and put back into service.
Like it's been said above, converting to 8-sp indexed shifting might be more trouble than it's worth, unless you've already got a bunch of parts on hand.
If the derailleurs and shifters are in good shape, an easy bang-for-the-buck upgrade is a modern freewheel and chain; the ramps and bevels designed into the cogs and chain profiles that make SIS-indexed shifting work, also improves shifting performance with friction shifters and vintage derailleurs.
Shimano MF-TZ 6-sp freewheels are inexpensive and will fit the wheels and frame as-is. Any "8-speed" labeled chain will work; I like the KMC Z-series, as they're (also inexpensive, lol) and play well with the mix-n-match drivetrains you find on vintage bikes.
Ironfish653 is offline
