Those running a single brake lever: which side?
Bikes: Felt TK2, Felt Z5
Quoted: 943 Post(s)
Liked 20 Times
Currently I am running a front brake with an All City cross lever on the left. I find myself when I carry stuff in hand on the bike (sometimes unavoidable - long story) I steer with my right hand as I am right hand dominant. Kind of thinking about flipping that lever over which will then be upside down and running it like that.
Those of you who do run a brake, which side? I saw a photo just now in the post a pic of your ride thread that got me thinking about it. Dude is running it on the right.
I don't run a brake, but when I do it's always on the right side, so you can still signal with your left hand.
Veteran Racer
Bikes: 32 frames + 80 wheels
Quoted: 1331 Post(s)
Liked 764 Times
It depends. If it's a cross lever near the stem, then on the left. If it's a hooded lever on a drop bar, or a mtb lever on a riser/flat bar next to the grip, then on the right.
What, Me Worry? - Alfred E. Neuman
I see the light at the end of the tunnel, but the tunnel keeps getting longer - me
Calamari Marionette Ph.D
Right. Just like a motorcycle.
Your cog is slipping.
When I use just a front lever, it's on the left. Having you're left hand free to signal is useless in this city because everyone driving is looking at their phones instead of paying attention to bikes, pedestrians, other cars or anything else.
Quoted: 1332 Post(s)
Liked 398 Times
Front to the left, right to the rear, always. I get confused otherwise. Plus I signal right with my right hand, because otherwise people just think I'm asking for a high five.
Quoted: 71 Post(s)
Liked 12 Times
Run it on whatever side is comfortable.
I used to run it on the right because that's what was comfortable after riding motorcycle.
I always saw bikes with 2 brakes set up left/front, right/rear but with a fixed gear bike you only need one if any so which side it's on doesn't really matter.
Quoted: 943 Post(s)
Liked 20 Times
Buddy of mine had me set it up on the left in case I panic grab the brake I will be less likely to go otb. On one hand I appreciate and understand that. On the other.......why not try the right? Gonna go swap it right now.
Veteran Racer
Liked 764 Times
Your bubby's logic is flawed. If you are right dominant, you have better control with your right hand than your left, so you can better modulate the brake force with your right hand.
Quoted: 943 Post(s)
Liked 20 Times
I tend to agree with that. Swapped it over and really want to ride it today but storms are probably going to prohibit that.
Location: Traveling through time, will return last week.
Bikes: Bare Rum Sword Knuckle Runner
Quoted: 278 Post(s)
Liked 122 Times
I run only a front brake, have it on the left side. Mainly because my mtn bike which has two brakes is set up with the front brake on the left as well so keeps things the same. I had a motorbike for 8 years until it was stolen and the front brake was on the right though, so who knows. I never had an issue either way don't think it matters.
Quoted: 943 Post(s)
Liked 20 Times
Did a few rides with it so far and it felt alright. Taking a bit to get used to and only forgot once that I moved it.
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
It doesn't matter. Left like a road bike, right like a motorcycle, if there were any overarching reason one was better then they'd all be the same.
^ This.
Personal preference. My dominant hand is right so right it is.
Happy to have helped inspire the thread (maybe?).
^that guy^
I have mine on the left, cable bend isn't as tight
Liked 398 Times
The cable enters the caliper on the right side, so a cable routed from the left facilitates a more gentle contour for a better braking line.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Left for me, I've never cared to switch all my bikes around for some kind of Euro or "I used to ride motorcycles" cred. Since it's a fixed-gear, I'm still able to do all the signalling I need with either hand.
mechanically sound
Right side, because sheldon.
