Recommend cheap strong rim?
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,417 Times
Due to my own stupidity, I'm shopping for a rim to replace a Velocity Dyad 32h (ERD 597).
I see I can get the exact same rim on eBay for like $80, but I'd like to pay more in the neighborhood of $40. Any recommendations for a cheaper, strong (heavy is ok) 32H rim with an ERD close enough that I can just move the existing spokes over? (what is close enough anyways? I know there are millions of ERD threads out there, but I never read them)
Or maybe even a cheap whole rear wheel with a shimao 8-9-10 freehub?
You should be able to find Dyad for $60 or so.Same with H Plus Son but I don't know what the erd difference would be. Also dt swiss has some affordable options.
Quoted: 850 Post(s)
Liked 344 Times
DT R460 is OE on a few bikes, so probably not terrible. $50. 460g. 32H available. ERD is 596, so 1mm less. May be fine, may be horrible. Depends on if your spokes have 1mm of visible threading beneath the nipples.
Quoted: 4559 Post(s)
Liked 2,802 Times
Weinmann Zac 19 is a good sturdy rim, but won't be quite as wide. I use one on my errand bike. I think it was one of those machine made wheels from Wheel Warehouse or someplace like that, generic cup and cone loose bearing hub for threaded freewheel.
Quoted: 350 Post(s)
Liked 122 Times
Looking at the Kinlin catalog, which isn't available unless you request it from a sales representative, the closest to 597 ERD I could find are
XD-230
ERD 595mm
inside 17.5mm
outside 23.5mm
height 19.5mm
weight 480g
probably disc only
(spacycles writes ERD 602mm https://www.spacycles.co.uk/m2b0s116p3788/KINLIN-XD-230)
MX4
ERD 595mm
inside 17.0mm
outside 23.0mm
height 20.0mm
weight 562g
probably disc and v-brake (vbrake is usually narrower outside for cnc cutting)
DDT32
ERD 595mm
inside 26.0mm
outside 32.0mm
height 20.0mm
weight 695g
disc and v-brake (vbrake was 31mm outside)
(on my 20" rims, I got ERD +4mm greater than stated and this is without eyelets)
(my 20" rim was 91% of the stated weight).
MD25
ERD 592mm
inside 18.0mm
outside 25.0mm
height 21.5mm
weight 570g
Probably disc only
(if the real ERD is like the others and +4 to +7mm, then this might match your spokes)
Alexrims has several models that more closely matches your current rim dimensions, but they don't state the ERD. You could ask them on Facebook. They reply very quickly.
https://alexrims.com/catalogs/
(edit: Alexrims website sometimes shows ERD but the website is a little bit broken.)
https://alexrims.com/products/x2200/
https://alexrims.com/products/xd-elite/
XD-230
ERD 595mm
inside 17.5mm
outside 23.5mm
height 19.5mm
weight 480g
probably disc only
MX4
ERD 595mm
inside 17.0mm
outside 23.0mm
height 20.0mm
weight 562g
DDT32
ERD 595mm
inside 26.0mm
outside 32.0mm
height 20.0mm
weight 695g
MD25
ERD 592mm
inside 18.0mm
outside 25.0mm
height 21.5mm
weight 570g
Probably disc only
working on my sandal tan
Quoted: 3870 Post(s)
Liked 2,563 Times
Quoted: 350 Post(s)
Liked 122 Times
Also, actual ERD might be very different than what the manufacturers or other people say. Different batches might have different dimensions. I had a difference of 2mm from the same model. The freespoke database linked above says the Kinlin XR-22T is 596mm, but the catalog says 588mm. Although spacycles gives 596mm. Another shop gives 595mm.
https://www.spacycles.co.uk/m2b0s116p3767/KINLIN-XR-22T
https://fairwheelbikes.com/kinlin-xr...less-road-rim/
offset version, but this would lengthen the drive side and reduce the non drive side.
https://www.spacycles.co.uk/m2b0s116...KINLIN-XR-22RT
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,417 Times
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,417 Times
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,417 Times
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,417 Times
Some wheelbuilding tools have databases for rim specs and other stuff. Here's the kstoerz rim database, filtered on rims with an ERD of 596-598mm: https://www.kstoerz.com/freespoke/rimfilter.php?erdmin=596&erdmax=598
And it's not like I can accurately measure ERD on a rim that's headed to tacotown
Or even if the rim was true, it's not like I could measure the ERD more accurately than the manufacturer, or Peter White
If I bought a Dyad as a replacement, would I even be able to be confident the ERD would match to within the spoke threads?
Quoted: 350 Post(s)
Liked 122 Times
No. you won't know if the ERD matches until you have it in your hands. Different people will give different numbers for the exact same item, depending on how they measure and where they measure to, where they end the spoke in the nipple. Also, some items of a model will have eyelets while another batch of the same model could have no eyelets. Different batches in production could have different dimensions too.
Even if the specs have the same profile height between different models, the ERD could be different due to how deep the bead seat sits in relation to the top of the sidewall. So you can't judge the ERD based on the overall height.
If your rim is that damaged though, I don't know if you'd be able to trust the old spokes. You could consider getting new spokes and nipples.
If you want to continue using the same spokes, you could look under the rim tape to see where the ends are in relation to the nipple on your current rim. I wanted my spokes to end at the bottom of the slot in the top of the nipple, but for some reason, when I built my wheels, they ended up at the top of the nipple and 2 of the spokes was 1 or 2 mm above the top, which meant it bottomed out. But even if it bottomed out and I continued tightening for 1 or 2 threads, i don't think it would make much of a difference. The 2 brass threads at the bottom of the nipple would simply deform to give way to the stainless steel spoke. But most people will tell you not to bottom out the spoke and nipple.
So the ERD of the new rim could possibly be +/-2 to 4mm compared to the old rim and still be acceptable, but depending on how far the old spokes went into the old nipples. But I don't think you want the ends of the spokes going lower than 2mmbelow above the inner wall of the rim. The bottom of the slot on my nipples are approximately 3mm above the inner wall of my rim.
Also, depending on how much lateral offset are in the holes of the rim, the ends of the spokes may change a little bit.
And when you measure your new rim, you might want to measure all 4 quadrants (take 4 measurements at 0, 90, 180, 270 degrees) and average them, because the rim might not be completely round when not tensioned.
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,417 Times
Peter White says of the Dyad
so at least that's not a worry
But it sounds like nobody could ever have been successful at swapping out just a rim on the same spokes except through dumb luck
We never see them developing cracks and they have no eyelets that can loosen. The V shape eliminates the need for reinforcing eyelets at the spoke holes.
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,417 Times
I've never built a wheel before, I figured the easiest way to do it the first time is to tape the old&new rim together, and move the spokes across to the new holes. That way I don't have to worry about lacing.
But because it's a first time, if the experiment is a total failure I don't want to be out a lot of dough
Likes For RubeRad:
Liked 2,563 Times
If it were my wheel, I'd try to reuse the spokes and nipples if they're not gouged up. It doesn't take a lot of side impact to taco a wheel, and per your account, it's just a little bent.
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,417 Times
Yes it's not a taco, it's a warped tostada. None of the spokes on the tight side were broken, and I've loosened them all since (and tried and failed to curb-stomp the rim into close enough to straight to let the spokes do the rest of the work)
Yes I'm assuming I can use the old spokes, otherwise I don't care about ERD
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,417 Times
No I have a bicycle and it can be upside down. I also have brake pads that can tell me when the rim is this way or that.
And I have a few cycling friends, probably one of them has a stand I can borrow if I get tired of doing it on the bike.
Even tension is also important, but you can get by without a tensionmeter by feel and sound (don't tighten to the point of stripping nipples, pluck strokes and listen for even sound all the way around). The more spokes you have, the more room for error there is when it comes to tension.
Also, if this is a rear wheel, note that spokes on the drive side will be shorter and higher tension than the ones on the nondrive side in most cases.
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
You may just want to bite the bullet and find your best deal on a Dyad rim. One benefit: you know your spokes will fit and you won't waste 20-30 (or more) on new spokes.
If you are willing to get much wider or narrower rims you have more options.
The Alex EN24s look pretty close.
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,417 Times
Wiz, thx for your PM with the link to the good deal on an actual Dyad. It's ordered, so I guess this thread can be done now (unless others find it useful)
Liked 2,563 Times
Even if the ERD varies between runs, that's probably the safest bet.
