Broken rear derailleur. New or upgrade? Advice?
Hi Guys & Girls,
I am a newbie around here and more or less in road cycling as well. I sustained a snapped rear derailleur on my newly acquired second-hand bike. As I don’t have much of an experience with the different group sets, I would look out for some advice first before spraying out some serious £££. I’ll attach pics as well for better understanding.. edit: can’t upload pics as a newbie.
So, I bought a Mooda Stretto Carbon bike with Shimano 105 (10-speed) gears, Dura ace breaks, and god knows what shifters, carbon wheels. (see pics.. okay cannot upload pics as a newbie) I am fairly happy with construct however the shifters are very worn and left sided one has a long travel when breaking. The previous owner changed the chain and wiring.
The question is whether I should just replace the rear 105 (10) derailleur only (£40-60) OR upgrade 105/11 / ultegra piece by piece OR change the whole group set to either of the mentioned?
I read different blogs and forums regards the group sets and whether upgrade not to upgrade.... which did not helped deciding. I am also worried that actual physical break happened due to some shifting error which might need other components to change.
(so what happened is, I was coming to hill then decided to shift LOW at front while at the back it was around the middle I assume.... then it dropped off at the back I thought okay had this before reverse pedalling to insert back then push which basically ripped the rear derailleur down. I think the chain must have dropped from one of the small chainring and stuck. The gearing was not perfect on this first ride needed double push to make the shifts sometimes. It had died at 137km of a 160km ride.)
I am planning to bike around 300-500km / month. I have budget up to about £1000 if sensible investment as it would rise the overall value.
Quoted: 453 Post(s)
Liked 104 Times
You have 105, but which 105? as this groupset has been around for well over 30 years now in different versions. The current version being R7000, previous 5800 (both 11 speed), then 5700, 5600 (both 10 speed), after that getting spares will become difficult
Being as a 10 speed, that limits you to having 5600 or 5700, if your looking to upgrade to 11 speed, then you will need to look at replacing shifters, rear hub, probably the front derailleur and possibly the brakes as well.
Upgrading piecemeal won't work if changing speed, it's all or nothing.
When you say the shifters are worn, how & what are they? the long pull is an issue with the brake, not the shifter, if worn, are what part, the hoods (bracket covers) or all over?
Some more details of what you have would be real useful here!
It says RD-5701 on the back of the rear derailleur and it was attached separately with two screws (where it broke) rather than being on the main rear axis.. if this helps.
I am happy with a 10-gear setup, not after an 11-gear necessarily.
The breaks are fine in my opinion, and yes the rear brake has a long pull, I will change the pads whether that makes a difference will see. The shifters are worn on the outside quite scratched all over.
I would try share a link for photos but I just cannot being a newbie, neither uploading photos.
Quoted: 453 Post(s)
Liked 104 Times
Is it like one of the ones in this link? Gear hangers – Moda Bikes (moda-bikes.com)
-For the shifters, can you live with the cosmetic imperfections? as these are normally the most expensive parts to replace, an as you have 10 speed, you will run into a few issues with replacing them,
- Shimano no longer makes compatible 10 speed road shifters for your RD, the only current 10 speed road shifters Shimano make are 4700 Tiagra, which needs it's own unique RD
- Your limited by this to either NOS or 2nd hand, add to that the 1st gen under tape cabling shifters from Shimano aren't the most reliable, I have had a few sets of 6700, and they all failed, and this seems common, 5700 seem better, but your still looking at something with a unknown history.
- You have picked the worst possible time to look at upgrading/buying parts, since C19 parts have been in short supply, and expensive, it should calm down in a year or so, but since mid 2020 unless you were willing to hunt and wait, if you needed something specific, you are probably going to have to over pay for it, if you can get it.
Likes For toma01:
SE Wis
Quoted: 2746 Post(s)
Liked 3,390 Times
Likes For sweeks:
Quoted: 11 Post(s)
I have a similar upgrade question.
I acquired a new to me bike with Shimano 105 9 speed 11-34 cog. I am just getting back into cycling, after about 4 years out and have moved to where there are more hills. I felt I needed more low gearing so I got a cheap 11 speed 11-40 only to find out the rear derailleur would not climb to the low gear. I got a Shamono RD-M8000-SDS to take care of that only to find that the barend friction shifter would only shift to 9 speeds. I could do the lower 9 the upper 9 or the middle 9 but not 11 speeds. I tried to fix that by getting a Dura-ace 11-speed shifter to go with that and found out I could still only get 9 of 11 speeds. The cog set I have has the same spacing as the 9 speed I took off. They added 2 speeds on the spoke end of the free hub. I would like to get a shifter that would do 11 speeds. I am afraid that the only real way out is to go to a Dura-ace 11-speed cog. I would really like to be able to run a 9-speed chain. I am running a 10-speed chain now.
Should I get a Shamao 11-speed 11-42 to fix this?
Bikes: Bianchi Ti Megatube; Colnago Competition; Planet-X EC-130E; Klein Pulse; Amp Research B4; Litespeed Catalyst; Trek Y11
Quoted: 605 Post(s)
Liked 480 Times
That is, in order to guarantee compatibility: if you want an X-speed cassette, you will need an X-speed chain, an X-speed shifter, and an X-speed rear derailleur.
(There's some level of backward compatibility in that you can run a thinner chain on a system that accepts a wider one, but not vice-versa; or you may be able to kludge some things together if you're lucky - but that's getting more complicated than we need to for this discussion.)
Likes For ridelikeaturtle:
Quoted: 6193 Post(s)
Liked 4,808 Times
If your rear DR is a RD-5701, you only need to figure out it it is a short cage (ss) or a medium cage (gs) and you can still get them new.
https://www.universalcycles.com/shop...s.php?id=53901
Unless you have an overriding reason to upgrade, put back on it what you know worked. It did work correctly at one time didn't it?
You do need to figure out if you need a hangar or if this was a direct mount on the dropout, then is that bent.
Quoted: 11 Post(s)
In short: you cannot mix 9, 10 and 11 speed components. Your shifters, rear derailleur, chain and cassette must be compatible according to 9, 10, or 11 speeds.
I have an 11-speed cassette, an 11 speed derailleur, and an 11-speed shifter. My problem is that the cassette has 9-speed spacing. It is 2 gears wider than a standard 11-speed cassette. The derailleur will make the shift if the shifter will pull enough cable to do it but it only pulls enough to shift the full range of 9 gears. I can manually pull enough cable to shift from 11 to 1 but the shifter will only pull enough to shift from 11 to 3. The 10-speed chain is not a problem because the chainrings and cassette are 9-speed spacing.
Quoted: 11 Post(s)
I am more than $300 into this upgrade and the overriding reason is that I have not ridden much the last few years and I have moved into an area where there are hills and I have been a flatlander for the last 20 years. I really need to have some lower gears.
(Also service booked for the weekend)
Likes For toma01:
Quoted: 350 Post(s)
Liked 122 Times
Thank you for your input.
11 and 9 speed cassettes have different spacing between cogs. Combinations of 11 or 9 speed derailleur and shifter will pull different amounts of cable per shift, which is why 11 speed derailleur and shifter cannot give you 9 speed spacing.
If you truly have all 11 speed components, no 9 speed components (especially 11 cogs with 11 speed spacing), and you can only shift 9 cogs, I recommend redoing the cable adjustment and indexing by releasing the cable, set index to 11, adjust high limit screw until derailleur is aligned to outermost cog, reattach cable, and adjust barrel to take up slack and fine tune.
If you can only shift 9 cogs, Are you on the highest index when shifting to the outermost cog or are you perhaps on the 9th index?
Which 2 cogs can you not shift to? The innermost or outermost? Is the derailleur hitting the low or high limit screws?
Likes For tomtomtom123:
Quoted: 350 Post(s)
Liked 122 Times
If you would like to learn more about bicycle mechanics, you could also try to install the hanger yourself. Mounting it would only be 3 screws. Adjusting the limit screws, attaching the cable, and further adjustments. You may also need a hanger alignment tool.
Quoted: 11 Post(s)
You need to be more clear how your 11 speed cassette has 9 speed spacing. How did it get like that? If you bought an 11 speed cassette then it should have 11 speed spacing. If you have 11 speed derailleur and shifter then it will only shift on 11 speed spacing. It will not shift with 9 speed spacing.
Quoted: 350 Post(s)
Liked 122 Times
I really do have an 11-speed cassette but the spacing matches the 9-speed cassette I took off. This is the description "Bibike 8/9/10/11 Speed Bike Cassette 11-40T/11-42T/11-46T/11-50T Mountain Bike Cassette Compatible with Shimano Sram(Except Sram XD)" I picked the 11-speed 11-40t.
Even if it were true, you wouldn't be able to use your 11 speed derailleur and shifter to align with a cassette that has a 9 speed spacing. Do you realize that this concept is contradictory? If the 11 speed derailleur is shifting a different distance each step than the distance between cogs of a cassette that has 9 speed spacing, how are you able to get 9 precisely aligned shifts if the distances don't match?
Quoted: 11 Post(s)
I don't see anywhere that says the 11 speed cassette has 9 speed spacing. Could you please copy and paste what you see?
