Best bike shoes for flat pedals
Bikes: 1988 Bianchi, 2006 Fuji Absolute 3.0, 1973 Raleigh Sport, 1972 Bottecchia Professional
Quoted: 18 Post(s)
Liked 30 Times
I would like to ride my '88 Bianchi road bike with flat pedals with the option of using pedal straps. I am not interested in clip-less pedals. What should I be looking for in a good supportive bike shoe? I see a lot of mountain bike shoes for flat pedals but wonder if there is a difference when it comes to road biking. Any suggestions?
Just Pedaling
Bikes: YEP!
Quoted: 334 Post(s)
Liked 522 Times
There is a difference. I have a pair of Sketchers that literally stick to my flats. I think it's the soft sole that creates the grip. But I have a feeling you're going to be overwhelmed with all the suggestions here because everyone has their own preference and what works for one isn't necessarily right for everyone. Good luck,
Likes For SpedFast:
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,995 Times
If you are using clipped pedals the closest you will find are proper road shoes and cleats from Yellow Jersey however be warned it will be harder to get your feet out from them. That is why clipless was invented to make it easy to get out of the pedals but also provide the power and connectivity benefits of clipped pedals. You can leave them loose but then what is the point and it is another thing to catch either your shoe as you are trying to get out or have the straps catch on something while riding.
A mountain bike flat shoe could work quite well, they tend to have good grip but decent support as well if you just want to ride on a flat pedal and with the nicer wide MTB pedals that support your feet well they are a treat. With all the pins that can be adjusted my feet don't really tend to wander so I can get a secure footing without slipping and sliding and truthfully I can wear just about any shoe but some really soft stuff might wear into the pedals overtime.
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
Five-Ten Freeriders. Sticky sole, long-wearing, and no velcro or boa mechanisms.
Likes For Rolla:
Quoted: 18 Post(s)
Liked 30 Times
Clark W. Griswold
Liked 3,995 Times
I like wearing toe straps for security but also because it is easy to get your foot out of them easily. I do not think I would like the added difficulty of cleats. I have been looking at the SYLVAN TOURING NEXT pedals which are compatible with toe clips and straps. The manufacturer says that this "pedal works well for a wide variety types of shoes, as the cage plate tooth profile is grippy but not particular aggressive." So I guess any good MTB bike shoe such as the Five-Ten? What other options are there?
Five-Ten makes great shoes and knows rubber quite well.
Likes For veganbikes:
I used Five Ten Freerider for a while until I got caught in a rain storm and they absorbed water like a sponge and took 3 days in the sun to dry. I then switched to the Solomon XA pro, which worked out quite well. When those wear out, I am interested in the Shimano ET5
Likes For MarcusT:
Likes For Kedosto:
Quoted: 1944 Post(s)
Liked 2,164 Times
As I’ve aged, I abandon installing traditional cleats on my shoes. And typical road shoes are too slick to run with just straps. My solution has been to use a semi rigid touring shoe with a smooth rubber sole, but not one from the British Invasion.
I have tried a few and have settled on a Specialized Elite Touring. The toe box is a bit cramped, but I use shoe trees and that has helped, and the shoe uses Velcro straps and I’d like laces.
They are discontinued but I see them on eBay every now and then. It is more about an example of a road type shoe with a rubberized smooth sole so it doesn’t hang up.
John
John
Likes For 70sSanO:
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
That being said, if you want something that's casual and easy to walk around with after you finish riding, BMX racers have long seemed to like shoes with a waffle or honeycomb sole like Vans. If you want a stiffer sole for more pedal efficiency, touring or commuter shoes are indeed the way to go. Most of them have a full sole with the option to cut a chunk out to go clipless. Lower end mountain bike shoes have similar soles, but the tread blocks would be a pain to use with straps.
It's like riding a bicycle
Likes For urbanknight:
Quoted: 1364 Post(s)
Liked 1,678 Times
I've never used clipless. I've been riding with toe clips for almost 30 years. Last year I bought a folding bike with plain platform pedals without pins and no toe clips. It's amazing to me how well my feet stay on the pedals.
I like to bike in skateboard shoes...sneakers with firm soles.
In fact, a few years ago I added inserts with semi-rigid arch support and that is what works for me.
Likes For BobbyG:
Likes For Mr. 66:
Likes For SpedFast:
I'd stay away from Five Tens if you use clips and straps, because they seem to be too sticky to slip under the straps easily.
The 5-10s are great on pinned flat pedals. I believe that part of the pinned flat ideology is that you can use a wide variety of shoes on them without hotspots, because there's so much surface area that the pressure from feet spreads out; supposedly, sneakers work.
Personally, I like pinned flats (like DMR V12s, VP1s, Raceface Chesters, etc.) and 5-10s better than clips and straps, but if I had found something like the Puma touring shoes when my old ones disintegrated, I'd probably still be using clips and straps. I double-tie the bow to protect the laces, shoes, crank, and chain. I think I've ridden 6K miles without a problem.
Today's shoes seem to be either road shoes that are too slippery to stay on any traditional pedal or MTB shoes which are too tall for many clips and which have rubber-like soles that compress when pedaling.
BITD, some people raced, some people rode for pleasure. If you raced, you probably used toe clips, straps, and cleats and tightened the straps. It was difficult to get out of that combo. Most people used clips and straps, but the straps weren't all that tight. They were a lot easier to get out of than 'clipless', IMO. I found the twisting needed to get out of SPDs to be a bigger problem than just pulling my feet back to exit clips & straps.
I would think it's getting into pedals, not getting out of them explains why the Look pedals quickly took over the peloton - it's much easier to clip in with Looks, etc., than with clips, straps, and cleats.
Likes For philbob57:
Just Pedaling
Bikes: YEP!
Quoted: 334 Post(s)
Liked 522 Times
I'm rethinking my Sketchers after checking these out. The Sketchers have elastic laces so no knots or extra string hanging loose, but these are interesting and waterproof. Heck yeah!
Are 5'10 shoes waterproof?
The Five Ten Trailcross GTX shoes are the brand's and industry's first waterproof winter cycling shoes for flat pedals with a Gore-Tex membrane. They've been built on the lightweight Trailcross platform aimed at blending flat pedal performance and grip, and all-day comfort on and off the bike.Nov 8, 2021
Likes For SpedFast:
Henderson, NV
Bikes: Trek Alpha 3700, GT STS DH, Raleigh Grand Prix, Fisher Montare, Fisher CR-7, Fisher Aquila, Diamondback Sorrento, The Bike Beat Revolution, KHS XC 504R
Quoted: 322 Post(s)
Liked 596 Times
I use the Specialized 2FO 2.0 for flat pedals. Most comfortable with these and flat pedals or even vintage Specialized MTB toe cages/straps.
It's what I grew up using.
I have a set of SPD pedals and a pair of Giro Chamber II's that I may try. I've never ridden clipped in.
Likes For Desert Ryder:
Bikes: Wife says I have too many :-)
Quoted: 327 Post(s)
Liked 250 Times
Here's what I use on my jump on and go to the store mountain bike.
They mount on the front of the flat pedals and hold the shoe nicely in place plus super easy to get out of.
https://www.amazon.com/Zefal-Cristop.../dp/B0048HWQKS
Likes For frogman:
Passista
Quoted: 868 Post(s)
Liked 721 Times
I don't overthink it. On my commuter with VP City pedals I use any shoe/sneakers except leather sole ones - even Dr. Martens. Never had any problems, wet or dry.
Likes For Reynolds:
I don't have a lot of experience with a variety of shoes, but I bought a pair of Puma athletic shoes I wear all the time. I don't ever clip in, all my pedals are flat, and I've found these shoes to be pretty good for what I'm doing. I participate in triathlons and wanted a pair of shoes that were good for both biking and running. These are a really good dual purpose shoe if, like me, you're not interested in clipping in.
Likes For VegasJen:
Guest
Liked 3,270 Times
I agree that the larger surface area is great for hotspots, but I still want a fairly robust sole. A lot of sneakers like Converse and Vans are so pliable you can practically feel the pins through them. Good adhesion, but too soft.
Likes For Rolla:
I’m a little Surly
Quoted: 699 Post(s)
Liked 1,294 Times
I have a couple pairs of five tens that I like so I’ll probably stick to those for flat pedals
Likes For Germany_chris:
Likes For BikeLite:
Quoted: 4414 Post(s)
Liked 4,867 Times
Five-Tens for flat pedals here. I currently use Freerider Pros for mtb. I find ordinary trainers/sneakers too flexible and squishy for cycling.
For The Fun of It
Bikes: Lynskey GR300, Lynskey Backroad, Litespeed T6, Lynskey MT29, Burley Duet
Quoted: 2135 Post(s)
Liked 1,647 Times
The short answer is that it doesn't matter a whole lot which shoes you use.
My personal preference is for a shoe that has very fine/shallow depth tread rather than lugs. A flat bottom shoe with little rise in the heel. A shoe that has a somewhat rigid sole rather than one that's overly flexy. Some modern shoes have a sole that is much wider than my foot where I make contact with the pedal. I avoid those shoes for riding. Don't worry about laces, they are easy to tuck away. I also prefer a lighter weight shoe. Weight can matter over the course of a longer ride.
Likes For Paul Barnard:
Likes For coffeesnob:
