Alternate tool or method For Park bottom bracket tool
Hello All. Wanted to ask if there is an alternate tool or method to remove the early style drive side bottom bracket bearing cup, Maybe more readily available/ even less costly than this Park brand bottom bracket tool? Anyone use just a good well machined adjustable wrench?( got this pic online)
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3890 Post(s)
Liked 6,488 Times
Yes, on occasion that will work. If not, I have the homemade tool that Sheldon describes here:
https://www.sheldonbrown.com/tooltips/bbcups.html
Quoted: 1372 Post(s)
Liked 1,752 Times
I use a 12" or 15" adjustable held snug with a big bolt and washers I used a 5/8" coarse thread bolt with a couple of washers. Works almost every time...
Remove bb spindle. Install non-drive side cup three quarters of the way in. With washer on bolt head, slide through the cups. Fit the adjustable to the drive side cup flat. Important: The jaws on the wrench must NOT be rounded. With the wrench adjusted as best possible to the flats, finger tighten the 5/8" nut. With caution, attempt to twist the cup free. Double check to ensure the wrench jaws remain tight or you run the risk of rounding off the cup flats. Best of luck.
Likes For randyjawa:
Quoted: 1088 Post(s)
Liked 1,026 Times
I just bought used, us made, wrenches. 32mm and 36mm. I found it worth it since the also work on headset locking nuts without marring or slipping.
Quoted: 472 Post(s)
Liked 1,028 Times
^^^^^. Fully agree but also caution that you must use a very good quality adjustable wrench due to the high torque that may be needed. I have found that a value priced or even a worn expensive wrench can cam off the cup or even distort the soft metal jaws of the wrench then cam off and damage the cup. However, a very good quality adjustable wrench can cost more than the Park tool or other such high quality BB tools. A lower quality purpose made wrench “inspired by” the Park tool can cam off the cup too if the metal is softer or tolerances too great.
Even with a nice, old school Crescent 14” industrial adjustable wrench, locked on as shown above, I’ve had to use a pipe to get enough torque. Be careful with that first 20deg of rotation.
I have had good outcomes with the Sheldon Brown assembly referenced above too. I use two socket wrenches, one on each end of the bolt/nut.
Bianchi Goddess
Quoted: 2934 Post(s)
Liked 2,930 Times
Sugar "Kane" Kowalczyk
Bikes: yes
Quoted: 512 Post(s)
Liked 409 Times
I've got that tool, but usually use a monkey wrench instead. Smooth jaws only.
Likes For Vintage_Cyclist:
Bikes: Bianchi Nyala, Bianchi Volpe, Bianchi Campione D'Italia, Trek 640, Luxus folding bike, Schwinn Speedster, Bianchi Torino, KHS Aero Sport, probably something else around here somewhere
Quoted: 117 Post(s)
Liked 198 Times
Turns out a big 32 mm is also needed on some motorcycles. I found decent quality 32mm cheap on Amazon.
Honestly the Park tool shown (and clone, 100% as effective) is worth owning. Sometimes those things can be stuck worse than a curse and as long as you can lock it in place with a bolt and washers it allows you to safely apply the most force in the most controlled fashion. I do have a large wrench that would work, the dedicated tool and the way it grabs all around wins.
There are some tools where it pays to get a Park tool branded one, this isn't one of them.
Likes For abdon:
Alternate tool or method for Park bottom bracket tool
alternate tool or method for Park bottom bracket tool
found this after searching for a couple hours purchased this on ebay the original tool by the looks of it. also has the spanner portion for the right side locknut. 15.00 but of course tax +shipping.
Likes For jzr756:
Quoted: 3241 Post(s)
Liked 2,512 Times
Mount it in a vise on the horizontal plane, and turn the whole bike.
Quoted: 4513 Post(s)
Liked 6,388 Times
I have the first one I ever bought 50 years ago and is always my go to, to this day.
Used correctly this is the most effective one and as stated above should be secured in place for the fixed cup if the cup is tight or stuck at all.
The hook side takes some finesse but is the best one, it can wrap around the lock ring for a very secure grip but is kind of spring loaded in the curve so it must be centered very well when you lean in.
I have them all, Campy, Park, old, new, generic, etc, this is the only one I ever reach for.
Likes For merziac:
Quoted: 380 Post(s)
Liked 541 Times
Cheap and make-do tools are the path to purchasing new parts. The Sugino tool is a good one and I've used one with the washer things for decades. The certainly superior Campagnolo tool found in the tool sets and VAR tools are mega expensive tho there are none that I would want more.
Likes For Steel Charlie:
Quoted: 1303 Post(s)
Liked 1,912 Times
I have the Var tools but also purchased a $20 36mm wrench from Menards (a local variety store specializing in building products). It is about 20"long and provides all the torque needed to break a stuck cup free. Smiles, MH
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
The Campagolo #793/A or VAR #30 are the best tools for removing a stubborn fixed cup. Beside the "big bolt" friction-type method described above, Stein tool makes a clamp for the common stamped-type tools from Park, Sugino, etc.:
https://steintool.com/portfolio-item...-wrench-clamp/
Hoards Thumbshifters
Bikes: '23 Black Mtn MC, '87 Bruce Gordon Chinook, '08 Jamis Aurora, '86 Trek 560, '97 Mongoose Rockadile, & '91 Trek 750
Quoted: 246 Post(s)
Liked 338 Times
Pleasantly surprised here, this is one of the tools that you absolutely not skimp on and the Sugino is the best IMO, especially the hook end.
Likes For jzr756:
Team Beer
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times
You can also use the Sheldon Brown method which is handy for a hard to remove fixed cup. Scroll down the page a bit.
I'm not one for fawning over bicycles, but I do believe that our bikes communicate with us, and what this bike is saying is, "You're an idiot." BikeSnobNYC
Quoted: 792 Post(s)
Liked 1,779 Times
I have used top end vintage American made adjust wrenches because I have them, But most 2 foot length precision adjust 2-90 mm buster wrenches should work nice to have worth buying nice American vintage $100 Amazon good enough $30. A nicer cheaper where ever what ever copy or specific spanner or set under $75 worth it if nice . Figure your labor is worth at least $15 hour save a couple hours pays your cost and you still have the tools so it may just be time to up your tool game. You can always use nicer tools on other bikes and stuff. There is no N+1 limit on nice tools in my book.
