Cinelli 1a stem handlebar bolt spinning
Quoted: 226 Post(s)
Liked 258 Times
This should be an easy one.
Picked up a Cinelli stem from the Co-op for some Cinelli bars I have (26.4).
Someone tightened the handlebar bolt down, and I can't unscrew it enough to remove it or get handlebars in. Turning the bolt from the back only causes the front to spin:
I tried leveraging the stem "open" as I unscrew to give some more purchase to the nut, but hard to do with just two hands and also makes it difficult to apply the right amount of pressure that lets me turn the bolt.
Bikes: Raleigh Classic 15, 84; Miyata 912, 85; Miyata Ridge Runner SE, 85; Miyata 610, 86; Miyata 100M, 86; Miyata Valley Runner, 88; Miyata Triple Cross, 89; GT Karakoram, 90; Miyata Elevation 300, 91; Marinoni Touring, 95; Long Haul Trucker, 2013
Quoted: 159 Post(s)
Liked 133 Times
Dremel a slot?
Quoted: 159 Post(s)
Liked 133 Times
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
If the entire bolt is spinning, time to drill the bolt out. You will need a drill press.
Quoted: 876 Post(s)
Liked 2,293 Times
Possibly hold the bolt with the wrench and carefully hacksaw through the clamping slot . I’m not sure how hard the bolt is but use a new fine pitch blade.
Quoted: 226 Post(s)
Liked 258 Times
Dang, was hoping this was easier than replacing the bolt.
What normally prevents the bolt from spinning? I assumed it was knurled in some way on the inside?
Quoted: 876 Post(s)
Liked 2,293 Times
Either knurled or keyed. I really can’t remember. You may try penetrating oil and tapping on it while gently turning the wrench back and forth . ATF mixed with acetone is great if you don’t have Marvel Mystery Oil. Vibration helps the penetrating oil penetrate. I use a brass hammer for this
Quoted: 226 Post(s)
Liked 258 Times
Okay, looking up replace bolts ($60! Bonkers) I now see what I'm working with here. For such a storied piece of equipment, this seems like one of the dumbest designs.
I suppose sawing through would allow me to salvage the nut (if it's worth salvaging; clearly it has no "bite" left) and maybe replace the bolt.
Would be nice if someone made little shiny Allen bolt caps. Then you could have an Allen head on either side and plug the cap when you're done. Plus think of all the money you'd make reselling caps when they eventually rattle out of the stem!
It seems like a whole new stem may be my cheapest option here, unless someone has some really creative ideas.
Quoted: 876 Post(s)
Liked 2,293 Times
Hit the smooth head with a sacrificial bolt and hammer to try to lodge it into the stem hole . The serration should still be there and may just need to be driven in.
Likes For Kabuki12:
Quoted: 876 Post(s)
Liked 2,293 Times
For sixty bucks you could probably buy a complete stem!
“Senior” Member
Maybe a SMALL drop or two of permanent loctite under the front cap delivered at end of a toothpick and apply pressure to create anerobic-ness so it will lock. Danger is too much and you lock the threads more.
Worth a try, but a long shot…
Do you think you might have a 26 bar in a 26.4 stem that created over-tightness?
Quoted: 226 Post(s)
Liked 258 Times
I tried hitting the bolt head into place with another bolt and it still spins, but I did a good job of marring the nice clean face of the bolt... Might try the locktite trick? I'm about ready to just find another stem.
Quoted: 1106 Post(s)
Liked 1,328 Times
a) Spread the clamp better:
Two large screwdrivers of the flat-blade variety may work, opposed, as wedges; arrange it so they will stay in position after you tap them together
I'd find a way to hold the stem in a vice and support the handle ends.
It should be pretty easy to adjust the amount and it may be enough to break the screw free.
b) Saw the screw & nut:
You'll need to keep the screw from rotating.
Put a hex key in the screw socket, and fix it to the stem with a hose-clamp, then put the stem in your vice and hack away.
Likes For oneclick:
Quoted: 2485 Post(s)
Liked 2,956 Times
Slide a handlebar into the stem and twist as if you were trying to get the handlebar to wobble, while turning the bolt with the Allen wrench. Maybe use a full-circumference soda can shim to protect the bar. (Probably a 3- or 4-hand operation, so have a helper nearby.) Make sure that the handlebar fits pretty tightly in the stem before applying the twisting pressure.
You should be able to apply enough pressure to force the stem farther open, thus seating the knurled portion of the stem bolt
I only use Cinelli 1A stems and most of the bolts were keyed. I only had one that was knurled. I just thought I would throw this in.
Likes For gearbasher:
Quoted: 159 Post(s)
Liked 133 Times
Is it possible that isn't the right bolt? Looking at it, I would have expected it to be closer to flush with the front of the stem.
Likes For John Nolan:
Bikes: '87 Serotta Colorado,'96 Moots VaMoots, Bertoni MAX, Eddy Merckx Grand Prix Team USA
Quoted: 171 Post(s)
Liked 338 Times
I would suggest using a non metallic wedge or shim to spread the opening, that would add some pressure against the forward nut.
You may find plastic shims or scrapers (that could be modified to the width you need) at the local hardware store.
Once wedged in, you should be able to work hands free.
Quoted: 3464 Post(s)
Liked 2,831 Times
Only if you have a drill press - punch center of stem nut and Kroil it, the hopefully enough depth to use an easyout. I do not see using this nut again, maybe the bolt.
‘I have one right now that is recalcitrant, but it is half way out. Hoping to avoid destructive methods. This seems to happen most often when the 26.4 stem was paired to a 26.0 bar.
Quoted: 1303 Post(s)
Liked 1,912 Times
I think there is an easier way than all of the destructive methods being proposed. Take a small nut and epoxy it to the spinning part. You can then use the nut as a leverage method to remove the bolt. When finished heat the epoxy, it breaks down at 350* so the nut can be removed. Then clean the chrome with something like Simichrome, or Quick Glo chrome polish. HTH, MH
Likes For Mad Honk:
Quoted: 876 Post(s)
Liked 2,293 Times
Likes For Kabuki12:
Quoted: 226 Post(s)
Liked 258 Times
Wow, lots of ideas here!
My sacrificial bolt marred the chrome a bit when K was trying to hammer it to get the knurls to bite.
I agree, it does look like the nut isn't flush with the end; maybe it's the wrong one? The stem is as I found it at the co-op, so no knowing if it was original or not.
I may try the epoxy trick if various wedges don't work.
Quoted: 1609 Post(s)
Liked 2,216 Times
One of my 1A stems
“Senior” Member
Another wild idea. What about using one of those little butane pencil burners that some people use to spot solder stuff and apply heat to the end of the female allen head sleeve bolt to maybe cause that to expand enough to loosen its grip on the smooth headed male bolt?
Causes in addition to a stem bar mismatch over-tightening, may be if washers are missing. But I’m not looking at my 1A and don’t remember if there were any in front or back?
if the epoxy would hold that idea from MH for the win!
