Broken Rear Quickchange Axle - Convert to Solid Axle or Not?
Old 06-20-07, 09:45 AM
kmcrawford111
50/50 Road/eBike Commuter
kmcrawford111's Avatar
Bikes: Specialized Roubaix, Specialized Fatboy, Specialized Sirrus, Nashbar Campus, Taga 2.0 Trike
Quoted: 5 Post(s)
My bike developed a problem where the shifting was getting sloppy, and there was a lot of resistance on the rear wheel. With the help of a coworker, I found that the rear axle was broken. My bike is a Mongoose SX 4.3 MTB, about 9 years old. It has quickchange for the wheels and seat. I was able to get a new rear axle from a local shop, but they only had a solid one - not the hollow kind (for the quickchange rod). I installed it and repacked the bearings in the process. I haven't decided if I'm going to stay with it or look for a hollow quickchange axle. I imagine the solid one is stronger, but the drawback is that I'll be carrying two 15 mm wrenches with it to be able to remove it if need be. I imagine going down some of the sharp curbs here helped the axle break. I know... I should ride in the street and understand why... but some of the streets here are simply too dangerous. What do you think? Know where to find some lightweight but strong (titanium?) 15 mm wrenches, preferably USA-made? Thanks for any comments.
kmcrawford111 is offline
Old 06-20-07, 09:47 AM
Eatadonut
You know you want to.
Eatadonut's Avatar
Bikes: Pinarello Prince, 1980's 531 steel fixie commuter, FrankenMTB
Originally Posted by kmcrawford111
My bike developed a problem where the shifting was getting sloppy, and there was a lot of resistance on the rear wheel. With the help of a coworker, I found that the rear axle was broken. My bike is a Mongoose SX 4.3, about 9 years old. It has quickchange for the wheels and seat. I was able to get a new rear axle from a local shop, but they only had a solid one - not the hollow kind I have (for the quickchange rod). I installed it and repacked the bearings in the process. I haven't decided if I'm going to stay with it or look for a hollow quickchange axle. I imagine the solid one is stronger, but the drawback is that I'll be carrying two 15 mm wrenches with it to be able to remove it if need be. What do you think? Know where to find some lightweight but strong (titanium?) 15 mm wrenches, preferably USA made?
Wingnuts - instead of the bolts on the ends of the axle, put on nice big wingnuts. Washers may be necessary. Then you don't need wrenches.
Weather today: Hot. Humid. Potholes.
Eatadonut is offline
Old 06-20-07, 09:54 AM
why2not
Carry one 15mm wrench & one small adjustable crescent wrench that can come in handy in a variety of spots.
why2not is offline
Old 06-20-07, 11:37 AM
ghettocruiser
Hollow axles don't break very often. I mean, it took nine years? I'd stay with the QR.
ghettocruiser is offline
Old 06-20-07, 12:06 PM
apocalypse
+1
apocalypse is offline
Old 06-20-07, 12:37 PM
JeanCoutu
ǝıd ǝʌol ʎllɐǝɹ I
JeanCoutu's Avatar
The axles I've broken were mostly due to a loose right cone getting screwed tighter until something broke, not from riding too hard on the bike.
You can fix a flat if you have a patch kit & tire levers, there's no need to remove the wheel for that. It's faster to put on a new tube though.
JeanCoutu is offline
Old 06-20-07, 12:52 PM
Raiyn
I drink your MILKSHAKE
Raiyn's Avatar
Bikes: 2003 Specialized Rockhopper FSR Comp, 1999 Specialized Hardrock Comp FS, 1971 Schwinn Varsity
Liked 3 Times in 3 Posts
https://www.rivbike.com/webalog/tools/19063.html
Raiyn is offline
Old 06-24-07, 10:50 AM
kmcrawford111
Quoted: 5 Post(s)
I like that idea, thanks! But where can I find wing nuts that will fit, they seem to be metric size M10, but nonstandard (finer) thread. Anyone know where to get some?
Old 06-24-07, 10:57 AM
Bob J
Bob J's Avatar
Bikes: 2007 Globe City 3.1
https://www.grainger.com/Grainger/items/6CE23
2007 Globe City 3.1
Bob J is offline
Old 06-25-07, 03:23 PM
Leiniesred
South Denver Commuter
Leiniesred's Avatar
Bikes: 2003 Spec. Epic, 200ish Bianchi Milano
I used to snap rear axles monthly. (I used to "cowboy it" a little too much.) I was able to have the local bike shop get me a chromoly axle shaft. Never broke that one.
Leiniesred is offline
