What did you learn on your ride today_
Bikes: Giant Defy 2
For me:
- Apparently, there is a correct way to mount a frame pump
- Checking that you have your water bottle before you're 15k into your ride is probably a good idea
- Headwinds are roughly 1E6 times more demotivating than hills
- Drop bars>Flat bars
- Check that your chosen route doesn't run into any road construction, forcing you to practice your cyclocross style flying dismounts in your road shoes
- Running prowess does not translate to cycling ability
Sua Ku
Bikes: Trek 5200, BMC SLC01, BMC SSX, Specialized FSR, Holdsworth Criterium
I am above average at cornering in the wet.
Trouble is I'm way below average between the bends.
Peloton Shelter Dog
In bike racing, somebody will always yell at you.
Bikes: Tommaso Aggraziato,Schwinn Varsity TT Custom
I learned that when i ride with my wife on a cold morning DRESS WARM because there is no hammering up hills/down hill or on flat, and i froze to near death!
Chases Dogs for Sport
I learned not to take that new road again. A gauntlet of somewhere between 25 and 30 loose dogs in a two-to-three mile stretch -- and a HONKING big crater, filled with mega-sized gravel, at the bottom of a plummeting, off-camber, blind corner descent (and there isnt' any stopping or even slowing down after you see it).
Bikes: 2005 Cannondale R700 CAAD7
When your riding along and hear a firecracker in the rear you probally should stop to check it out, in my case it was a blown tire and a pinhole in the tube lol
SLO-1
Bikes: '09 BMC Road Racer SL01
Bikes: Giant Defy 2
Being your school's star track and field athlete (not that I'm any good), to barely keeping up with the 100kg clyde on anything over a 1% incline is humbling, to say the least
Hah then you are obviously a much better runner than I, so you can imagine how unimpressive my transition back to riding in the spring is.
Bikes: Giant Defy 2
Rides with Scissors
Bikes: 2011 Trek Madone 5.2
That the weatherman doesn't know diddly......suppose to be 70 degrees F today. Left with it 38 degrees in shorts just knowing it would warm up. It was 42 degrees 2 and half hours later and I was freezing from the ride.
Bikes: '09 BMC roadracer, CAAD3, CAAD4,'88 Steel Custom, F moser track bike
dont be so quiet in a race, scraped a $400 front wheel today.. and the rider that caused it got out, and left four of us in a mangled mess.
oh and take a few min. to find your computer that landed ever so gingerly in the grass 50 feet from your bike.
Still can't climb
Quoted: 12 Post(s)
Liked 6 Times
badly potholed roads have a double hazard. The loose chippings and stones surrounding the hole is hard to spot and can be spread quite far and wide around the hole.
coasting, few quotes are worthy of him, and of those, even fewer printable in a family forum......quote 3alarmer
No @coasting, you should stay 100% as you are right now, don't change a thing....quote Heathpack
Nerd
Bikes: Cervelo R3 SL, Cervelo P2
If see something unusual and alarm bells start going off in my head - it's best to pay attention.
Pedestrians, even slow moving ones, can move a lot quicker than I expect.
If a van makes a u-turn and cuts you off, and you chase it down to yell at the driver, it's hard to stay angry when the driver is hot.
I attend a school of ~650 people K-12, so it's much less impressive than it sounds.
We seem to be learning a lot of the same lessons today.
pan y agua
Quoted: 1447 Post(s)
Liked 728 Times
That Zipp 808's can be ridden on a tandem with 2 broken spokes on the back wheel, and hardly out of true.
You could get lost and die.
You could hit a tree and die.
Bikes: Cannondale CAAD 9-4
I'm new to riding - People will try to pass you on the left even though you signal that you're going left. (can I give them the finger when they do this? I did today.)
And yes, I found that swimming and running prowess doesn't translate to cycling ability.
